Pine Wire Tree
2,205
53
5
About: I Love Making Awesome Stuff
Materials:
  1. Magnet wire 25 gauge
  2. Wire cutter
  3. Some object having a circumference of 22 inches
  4. Wooden base
  5. Linseed oil
  6. Toothpick
  7. Drill machine.
Step 1: Preparation
  1. Make round piece of wood make a groove in it from back side.
  2. Finish it with linseed oil.
  3. Take some object having a circumference of 22 inches.
  4. Wrap the wire around it.
  5. Take off the wire from it.
  6. Cut from one side only and make it straight.
  7. Mark the dots on wood center and drill them.
Step 2: Structure
  1. Take some wire from bunch of wires, twist from end and put in the wood hole.
  2. Do this to all wires.
  3. Now grab the wood base with one hand and wires with other hand (Grab the wire close to wooden base approximately 4 inches apart from wooden base.) and twist them.
  4. Note: Don't twist them all. Only twist 4 inches and then take out some wires for branch and twist them.
  5. Take out same amount of wires from opposite side of the previous branch.
  6. Repeat step 4 and 5 till the end of wires.
  7. Bend the wires which are underneath the wooden base and cut extra wires.
Step 3: Leaves
  1. Split the branches.
  2. Take only one wire and wrap it around on toothpick.
  3. Now take out the wire by sliding toothpick. The wire becomes like a coil spring.
  4. Follow the images to make leaves
Step 4: Final
Step 5: Done!
    • Woodworking Contest
      Woodworking Contest
    • Party Challenge
      Party Challenge
    5 Discussions
    SusieD15
    Question 5 months ago on Introduction
    Can I buy this wire at a hardware store? How much wire is on the spool? This is such a stunning tree! I want to make one as a gift for a coworker. Thank you for sharing this beautiful idea.
    Amaries
    1 year ago
    I often have seen wire trees but never a pine. This is the best wire tree I have seen. Thank you for sharing!
    AmariesAmaries
    Reply 1 year ago
    I regret my comment, I looked at you page and your bonsai trees are also awesome!
    KJS231
    Question 1 year ago on Introduction
    Do you mean a circumference of 22"?? Radius of 22" would be huge. Also how much wire are you using?
    1 answer
    Awesome CraftsKJS231
    Answer 1 year ago
    Circumference is the right word. I have made a mistake. Thank you for figure it out. I did not measure the length of wire because the wire is too long and quite thin.
