Play Music With Arduino!
9,173
44
12
About: Photonics Engineer
In this instructable I will show you how I play music using an Arduino UNO and a SD Card module.
We will use the SPI Communication.
Let's get started!
Step 1: Parts
We will need the following parts:
Arduino UNO
SD Card Reader
Jumper Wires
Audio Amplifier
Speaker
Step 2: Code
The code its very simple, you can use it to play pretty much any sound that is on the SD Card but with an specific format, thats on the next step.
You need to download all the libraries frist, if you already have it then just copy and paste:
#include "SD.h" //SD library
#define SD_ChipSelectPin 4 //Select the SS pin for the SD module
#include "SPI.h"
#include "TMRpcm.h" //The library to play the audio files
TMRpcm Memoria; //Here you put the name you want
void setup(){
Serial.begin(9600); //Initialize serial com
if (!SD.begin(SD_ChipSelectPin)) { //If the SS pin is in a LOW state it will send a Fail message Serial.println("SD fail");
return;
Memoria.speakerPin = 9; //The pin where you will put the speaker, usually the 9
void loop(){
Memoria.setVolume(5); //You can set the volume here up to 7
Memoria.quality(1); //only accepts 1 or 0, 1 is for better quality
Memoria.play("1.wav"); //Here you place the name of your audio
delay(10000); //This delay should be at least of the same lenght of your audio,
//This library can play the music while the arduino is in other task so you can play it background
//or wait for the audio to finish
Step 3: Transform the Audio Files
This will work with .wav audio files but you have to make som adjusments to it.
For that you can use the following online converter.
https://audio.online-convert.com/convert-to-wav
So, in this page you will need to change the settings like is shown on the picture then you just click in "Convert File" and wait until the convertion is done and the new file is downloaded!
Then you have to put all this audio files on a SD card and plug it into the arduino module.
There are also other features on this library like in the image above so you can use it and make a music player with buttons for the volume, next song etc, etc. Or pretty much aniything you want! The sky is the limit!
Step 4: Diagram
This is the pin setup for the arduino and the SD module:
Arduino >>>>>>> SD Module
4 >>>>>>>>>>> SS
11 >>>>>>>>>> MOSI
12 >>>>>>>>>> MISO
13 >>>>>>>>>> SCK
5v >>>>>>>>>> 5v
Gnd >>>>>>>> Gnd
9 >>>>>>>>> PWM Audio Out
The audio output can be connected to an amplified speaker beacuse is low power, also the currect consumption could damage the arduino if you connected directly.
And... you are done!
Let me know if you have any doubts, I'll be happy to answer,
Thanks for reading my instrctable!
Step 5: Results
If you have an osciloscope you should be able to see the PWM signal at the audio output like this.
Thanks for reading my instructable!
    • Arduino Contest 2019
    • Trash to Treasure
      Trash to Treasure
    • Tape Contest
      Tape Contest
    12 Discussions
    Lindermann95Rupeshkadam
    Answer 4 months ago
    Well is really easy, there are plenty of tutorials of how to read a IR remote control with arduino, there is a library for it.
    Then you only need add some “if” sentences. (This is one way to do it)
    “If(bla bla bla IR read == Up){
    bla bla bla.play(music);
    Something like that
    RupeshkadamLindermann95
    Reply 4 months ago
    Another question, I don't have SD module. Can I use Intel Galileo instead of Arduino because it has an SD card slot?
    Thank You!
    Reply 4 months ago
    Hi there,
    Well... I've never use an Intel Galileo but the most important thing here is the audio library, if there is one for the Galileo board and there is a functional output pin then it would work, I think...
    The pin is very important, in the Arduino Mega there is only 1 functional pin, the 46, even when almos all the pins are available for PWM, not all of them will work as a speaker, I think this is something that is declared in the library.
    Give it a try and let me know :)
    Mister Gears
    7 months ago
    Finally !!! An instructables about it ! thank you very much ^^
    Lindermann95Gadisha
    Reply 7 months ago
    I'm glad you like it, I’m using it to make my arduino respond to me when I use a voice command, but thats a topic for another instructable, I'll upload it it soon
    Lindermann95Elaya1
    Reply 7 months ago
    That could be an option but... what would you use the arduino for?
    Maybe I can add the bluetooth and control the music commands from there (Play, Stop, Next... ), but I wouldnt send the audio from my phone, for this you can use basicly any bluetooth audio module.
