Playing Wave File Using Arduino
308,653
428
216
About: Electrical Engineer
This is a simple circuit to play wav files using arduino Nano V3.0 ,it consist from 4 buttons ,each one play specific wav file loaded to SD card.
Step 1: Parts
1- Arduino Nano V3.0 (I used the chines version called Funduino Nano).
2- SD card Module.
3- SD card.
4- Bread Board.
5- four push Button .
6- four 22K resistors.
7- one 4.7K resistor.
8- BC546B NPN transistor.
9- Speaker.
10- wires.
Step 2: Prepare Your SD Card
1- Format SD card and make sure the setting as attached picture.
2- Convert your music to .WAV files and make sure the below:
-Samples Per second(Hz):16000
-Channel :Mono
- Bits Per Sample: 8
I use Wav Sample rate converter software (picture attached).
3- Wave files samples attached.
Step 3: Circuit Digram
Step 4: Source Code
1-Before writing the code you need to install TMRpcm library from below link:
https://github.com/TMRh20/TMRpcm/wiki
all information how to install and use the library included in the website .
2- Download the attached WavSW_ino.zip file and open it with arduino sketch ,I tried to copy and paste the Source Code from arduino sketch to instructable but for some reason the text convert to rubbish.
Step 5: Troubleshooting Update 29/5/2016
For people whom unable to make this circuit work ,I created the attached folder "for test" for troubleshooting purpose .
The folder includes tested code for Arduino Nano ,UNO and MEGA.
No need to connect the push buttons,the sounds will play automatically.
No need to connect the transistor ,Connect a small speaker or headphone directly to pin 9 for arduino nano or pin 11 for Mega .
Copy the .wav files directly to SD card ,Do not put them inside folder.
Pin Connection:
Arduino Nano ---------> SD Card
12 -------------------> MISO
11 -------------------->MOSI
13 -------------------->SCK
4 ---------------------->CS
9 ---------------------->Speaker
GND ------------------>GND
5V ------------------> VCC
Arduino MEGA ---------> SD Card
50-------------------> MISO
51-------------------->MOSI
52 -------------------->SCK
53---------------------->CS
11---------------------->Speaker
if the tested code worked fine do the following for the push buttons code file to make it work:
1-If you faced problem in compiling the original push buttons code file ,please add line #include<SPI.h>
in the 3rd line of the code.
still have no sound add a delay command between the play commands delay(1000);
Good luck
Husham
16 People Made This Project!
  • Gardening Contest
    Gardening Contest
  • Party Challenge
    Party Challenge
216 Discussions
AminA81
Question 7 weeks ago
If I add another 30 buttons do I need to do something about the transistor too or should I just connect it to the same transistor?
haojuuestc
7 weeks ago on Step 5
Hi there,
I'm not quite sure what happened: I ran the troubleshooting codes (and added a short piece of music in wav format myself) on my arduino pro mini, but it just doesn't work... All pins were connected in the same way as your demo (except that I changed CS to pin 10 both in the codes and in the actual circuit. I uncommented #define DISABLE_SPEAKER2 in the pcmconfig.h file, too.). I connected the speaker directly to pin 9 without amplifying the signal input.
I am sure that the SD card and the speaker both work --- I can read and write txt files on the SD card, and the speaker works fine with the tone function.
The waveform on the oscilloscope tuned out as such: (see fig 1)
which should have been like this (original file opened in matlab): (see fig 2)
Wonder if you have any suggestions?
Thanks a million!
markl329
Question 7 months ago
Does the speaker need a amplifier?
Suyogpatange7
1 year ago
Why you use analog pin as digital pin instead of original digital pins?
geo-sun
1 year ago
I need help, mine works with sample files but If I try to play music it just makes buzzing sound.
ParkerO
1 year ago
I need help. Im using the UNO and i uploaded it and no audio. No static. Nothing. Im using a 5W 8Ohm speaker.
revlied
1 year ago
I'm done i press the buttons, nothing happens. No errors in the script.
ĐorđeM2
1 year ago
I have connected all as you, but my speaker is too quiet. But if I change volume, then quality goes horrible, I can't hear anything. Help?
HaqiK
2 years ago
Hey guys I love your tutorial and thanks for great help :) anyway I tried with my own sound and have some problem with the sound, the sound doesn't clear to hear and I tried to volume up the sound with potentio too but no luck, anyone knows to volume up with this library?
Thanks for your help :) :) :)
Autoraf
2 years ago
Hello everybody! I made this project but there is a noise like motorcycle wirh the sound from sd card. Can you help me? Tks!
tuang.pingfavilunda
2 years ago
the "For Test.zip" has no UNO file. Can you provide that ? I have been struggle with this project for weeks now. I need some sample with .wav file and yours seems nice. Ps. I tried change pin 4 to 10 already since I have read somewhere that UNO needs pin 10
YusdiI
2 years ago
Thank, n nice project
tsnijder
2 years ago
Hello,
Is it possible to play each sound on a different speaker?
domdomgin
2 years ago
spi was not declared in this scope..please help..
hungrycatzdomdomgin
Reply 2 years ago
try including the spi library - #include <SPI.h>
Nolan Cash
2 years ago
hey, just a heads up, when pinning the transistor be sure to look up the pinout and double check before soldering. or you can do what i did and just look at the shape and trust the rest. then spend 3 days trouble shooting. the transistor in the diagram is inverted.
aside from that learning experiance, this is an awesome project and im not sure how but i would like to post a video when i get the entire project done.
badedinNolan Cash
Reply 2 years ago
husham seems like not here that often ..
can you possibly help me nolan?
Nolan Cashbadedin
Reply 2 years ago
sorry for the late reply, and ill try and help as best i can. is your question about the one button making random wav files play?
