Pocket Plant
51,783
312
178
Not much of a green thumb? Not a really responsible? Tried to grow plants but they died cause you forgot to water them? A new, easy way to grow little plants that efficiently use the water you give them. I personally gave up on this project about a week ago. Then I saw they were growing, I haven't watered them for a week and they're growing! Using a tiny vial not only doesn't let the water evaporate and escape like normal pots, it also creates a continent carrying case.
This project was suggested by tech-king. Oh, and you can't grow cactuses in here (thanks tech-king)
Oh, and if you like this project please rate/vote then! All I want is a Robot T-shirt to look spiffy in.
UPDATE: I will try and add pictures everyday in the intro to show the progress of growing.
Supplies:
Step 1: Items
What you need is:
Seeds (I chose Basil since it grows really fast)
Tiny vials (I just found these, I used 4 in this project)
top soil (or dirt)
pipette or syringe (some way of watering the plant)
This project costed be nothing cause I found/had everything.
Step 2: Insert Dirt
take a tiny bit of soil at a time and push it through the neck with a stick, it should take you about 2 minutes per bottle. Put about 3/16 of an inch of dirt (approximate)
Step 3: Insert Seed
need I say more?
Step 4: Fill the Rest
put about 1/4 of an inch on top of the seed using the same method as in step 2.
(I know it's the same picture, but it's dirt, not much to show)
Step 5: Water
Drop about 2-4 drops of water into the vial using either a pipette of a syringe. I only had to water it once for the first week.
Step 6: Put It Under the Sun
or in this case a light. Let it grow for about a week, I used my mom's orchad stand. It took about a week for it to grow.
Step 7: Enjoy!
Enjoy your pocket plant!
Runner Up in the
Pocket-Sized
    • IoT Challenge
      IoT Challenge
    • Gardening Contest
      Gardening Contest
    178 Discussions
    Rubens??
    2 years ago
    why can't I grow cactuses? May be just a tiny little bit of water on sand and gravel? No?
    humxa
    4 years ago
    Hey, heres my plant roughy 10 days old, should I remove the one of the two plants?
    becks2004rlhhumxa
    Reply 3 years ago
    humxa yeah i would if i were you, the plant needs to be taken out or it will die because there wont be enough room for the roots.
    becks2004rlh
    3 years ago
    amuna1
    5 years ago
    would millet seed be good to use?
    PINKmonster325
    7 years ago on Step 2
    You should add an LED to the top so it gets more light.
    atralheaven
    7 years ago on Introduction
    Can I use a darker vial with a blue LED inside? I searched alot but I just found dark brown vials
    HamenChips
    8 years ago on Step 7
    I'll try this one but i'm gonna put some blue LEDs to make my flowering seeds grow fast.
    ilpug
    8 years ago on Introduction
    lol interesting use for a crack vial. nice instuctable though. i might do this.
    RobertoH
    10 years ago on Step 7
    Great instructable! i'm gonna try this with mushrooms when i have a chance
