Pocket Rocket Launcher
13,318
41
111
This is a real rocket launcher that fits in your pocket. It is easy and cheap! If you like it, vote for it!
Supplies:
Step 1: Parts and Tools
Almost All Of These Can Be Bought At Radioshack:
Altoids Tin
DPDT Heavy Duty Rocker Switch
Mini SPST Momentary Pushbutton Switch
Red LED With Holder And Built In Resistor
9 Volt Battery Snap
9 Volt Battery
9/16th Inch Wide Copper Tubing (Can Be Found At Radioshack)
Alligator Clip Test Leads
Wire
A10-3T or A10-PT Rocket Engines (Available At Hobbytown)
Tools:
Wire Strippers
Pliers
Metal Snippers
Pocket Knife
Soldering Iron
Hot Glue Gun
Pipe Cutter
Drill
Large Drill Bits
Small Drill Bit
Block Of Wood
Clamp
Step 2: Getting the Tin Ready
This step is creating holes for the rocket and switches to go through.
Parts And Tools: Altoids Tin, Pliers, Metal Snippers, Drill, Large Drill Bits, A Small Drill Bit,Round File, Clamp, Wood Block
Step 1: Bend the metal tabs holding the lid on back. Remove the lid. Bend one tab so it there is no hole in the tin. Then bend one tab so it is flat against the tin. (Photo 1)
Step 2: Cut off the bottom metal on one of the holes on the lid. (Photo 2)
Step 3: Mark the size of the holes for the switch and tubing. Put a block of wood in the tin and clamp it down. This makes the tin not bend. Drill them out. If the holes aren't big enough, file them out.(Photos 3, 4, 5, and 6)
Step 3:Drill a Hole in the back for the LED using previous techniques. (Photo 7)
Step 4: Shave off some of the screw on ring of the rocker switch. (Photo 8)
Step 5: Cut an approximately 3 in. piece of pipe. If the pipe cutter made an indent on the pipe file it out. (Photo 9 and 10
Step 6: Check and see if everything fits. (Photo 11)
Step 3: Solder It
This is the step when you solder the switches and stuff.
Parts and tools: Rocker Switch, Push Momentary Switch, LED, 9 Volt Battery Snap, Soldering Iron, Solder, Wire, Wire Stripper
Step 1: Cut the alligator clips in half so you have 2 alligator clips with wires.
Step 2: Solder the battery snap's black wire, the LED's black wire, and 1 alligator clip together. Be sure to slip on shrink wrap before you solder it. Then shrink the shrink wrap. (Pictures 1 and 2)
Step 3: Solder the red wire from the battery snap to 1 of the tabs on it. Be sure to shrink wrap it. Then, solder a short piece of wire to the other tab. (Pictures 3, 4, and 5)
Step 4: Solder the red wire from the LED, a short piece of wire, and the wire from the rocker switch together. Shrink wrap it all with the short piece of wire sticking out back towards the switch(Picture 6 shows what I mean).(Picture 6) *Disregard the color of the wire, it was just some salvaged wire.
Step 5: Solder the short piece of wire to one of the tabs on the momentary switch, and shrink wrap it. Solder the other alligator clip to the other tab of the momentary switch and shrink wrap it.(Pictures 7 and 8)
Step 6: When you turn the rocker switch on, the back LED should light up. If the alligator clips are touching and you press the momentary switch, the LED should go out. (Picture 9)
Step 4: Finishing Touches
For the finishing touches you need:
Hot Glue Gun, Hot Glue Sticks, Soda Can, Scissors, Metal Snips, Electrical Tape(Optional), Scissors
Step 1: Measure and cut a piece of soda can metal the length and height of the tin, with a notch big enough for the wires to go through. Cover with tape for a "stealthy" look. This is the blast shield.(Picture 1)
Step 2: Glue all of the solder points and wires down, except for the alligator clips and battery snap. Also, glue the blast shield and launch tube. (Picture 2)
Step 3: Cut out a slot on top for the rocker switch so you can close it all the way. (Pictures 3 and 4)
Step 5: Launching!!!!
This is what you need to launch it:
The assembled launcher, rocket motor, rocket ignitor, ignitor plug, gloves, common sense, a properly functioning brain
Step 1: Insert the ignitor and plug into the rocket and slide down the tube. Connect the alligator clips. Put on your gloves and turn on the rocker switch. Make sure the LED comes on. (Photo 1)
Step 2: Use your brain and common sense. Point away from people, pets, and flammable things. Press the button. After a little delay and a puff of smoke, off it goes!!!!! (Photo 2)
HAVE FUN!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
and be safe
    • Woodworking Contest
      Woodworking Contest
    • Arduino Contest 2019
    • Party Challenge
      Party Challenge
    111 Discussions
    konosuke
    2 years ago
    This is prohibited by model rocker code and most laws. YOU NEED TO BE AT LEAST 15 FEET AWAY FROM THE ROCKET! This is violation of model rocketry code. SOMEONE REMOVE THIS! THIS IS IN VIOLATION OF THE LAW!
    ROCKETMAN
    11 years ago on Step 5
    This instructable needs to be removed! Launching a rocket motor without any stablization and recovery system is an uncontrolled weapon!!!! It is also prohibited my all model rocket safety codes. It may also be ilegel in most jurisdictions.
    zrockerROCKETMAN
    yea well you only get one life on Earth, you have to die sometime. Might as well be while launching a frikin awzum rocket then dying alone in agony at age 94
    who cares. if a kid get smacked in the face by a rocket engne its their own fault not the instructables.
    skatattookidROCKETMAN
    I got 3rd degree burns on my face chest and hands from lighting a rocket engine on fire, still have scars.........5 years later. yea not a good idea.
    aplaucheROCKETMAN
    Reply 9 years ago on Step 5
    OH NO!!! it breaks model rocket codes??? some one report this! rocketman call 911 right now that way we can report this felony. im sure the police will put this case of model rocket safety code violation at the top of their priorities. sorry robot. this guy had it coming
    ROCKETMANmr j124
    I know that there are ways to stablize it. My point was that it lacked any stablization or recovery system as presented in the Instructable.
    darth acexxacerROCKETMAN
    Reply 10 years ago on Step 5
    in that case lets add fins to it and a F***ing little parachute to it so we can ruin all the fun is that what you want?
