Pong With 8x8 Led Matrix on Arduino
113,871
73
61
Game Pong created with 8x8 Led Matrix on Arduino Diecimila (microcontroller Atmel ATMega 168). For more informations https://labs.bsoares.com/ping-pong-com-matriz-de-leds-8x8-ee13cce39007
Supplies:
  • Party Challenge
    Party Challenge
  • Arduino Contest 2019
  • Fandom Contest
    Fandom Contest
61 Discussions
JasonL172
2 years ago
what if my LED matrix was driven by MAX 7219? how would i change the code?
MarcelM11
3 years ago
Olá, pode me dizer como foram feitas as ligações dos pinos? Pois tentei o mesmo projeto mas não tive sucesso ainda, obrigado desde já, abraços!
Obs.: A minha Matriz de led 8x8 tem linha como catodo, carreguei mesmo assim a mesma programação que você usou, desconfio que o problemas esteja aí!
bsoaresMarcelM11
Reply 3 years ago
Olá, já faz um tempo que eu não brinco com Arduino, não sei se vou poder te ajudar. Tente trocar Low para High e High para Low no método doubleBuffer. Essa forma você troca o que seria positivo para negativo.. e vice-versa.
stu.tg
4 years ago on Introduction
http://blog.bsoares.com.br/arduino/ping-pong-with-8x8-led-matrix-on-arduino
This link doesn't seem to be working? Could you post the source code please?
Rana420
5 years ago on Introduction
hii, i tried to make but its showing some random pattern on the matrix but not the game ......... please help me out.
Jurie VorsterRana420
Reply 5 years ago on Introduction
You may have the matrix plugged in upside down on the circuit board.
This was the case when I assembled the circuit board first time.
lovelyazka
how if im add AI (artificial intelegent) for this game ? and made this 3 level easy,medium and hard ? and i think this is COOL !!!
gzhang1
7 years ago on Introduction
would you please show the diagram that how you connect the pin of the matrix to the Arduino?
bsoaresgzhang1
Hello, pins configuration here: http://www.arduino.cc/playground/Main/DirectDriveLEDMatrix
kierstbsoares
Did you use that pin configuration to make this ping pong game?. or it is just a basis for the project?.
kierst
Can i see the schematic of this? that would be a great help Thanks!!
clayman987
6 years ago on Introduction
In arduino playground it suggests we use resistors, because it might break, so do you have to because i dont have enough resistors?
