Popsicle Stick Swiss Army Knife Prop
10,558
89
48
About: I'm trying to figure out how to be the best possible version of me. I work for Rotor Riot, a company that specializes in FPV Freestyle Drones.
Swiss Army Knife made out of popsicle sticks!
This is a Swiss Army Knife prop that YOU can make using only a couple of popsicle sticks (tounge depressor type).
NOTE: I do not know how to make the blades stop when fully extended. You can turn them until they hit the other side of the stopper. I did not have a Swiss Army Knife available while making this Instructable.
Please post a solution if you can.
You will need:
 - 6 popsicle sticks (wide type)
 - Superglue
 - Drill
 - Jigsaw (optional)
 - 1/2cm drill bit
 - Sandpaper 150 grit and 280 grit
 - Pen or marker
This is not a Step-by-step Instructable, so I'm hoping you understand the process from the image notes.
Don't forget to Subscribe and Comment!
    • Gardening Contest
      Gardening Contest
    • Fat Challenge
      Fat Challenge
    • Pie Contest
      Pie Contest
    48 Discussions
    TheGeek1984
    7 years ago on Introduction
    OK, after I drew that up, I had to try it. So since I had some popsicle sticks lying around, I grabbed one and this is what I got.
    1. Just like the picture, there is a notch on the same side as side C. Sides A and C are roughly the same length, and B actually came out pretty even too.
    2. I found that it was easier to leave side A rather long, then drill the hole out, and then shorten it to match C.
    3. The dotted line is just where I tapered the blade, and I colored in the notch for the thumb to pull out the blade. The other notch...I'm not really sure why that's there, maybe aesthetics? I was going off of my little Swiss Army blade.
    Again, this is just a rough work up of what I drew last night. I just wanted to make sure that it was possible. Good luck on version 2!
    Thanu03colorex
    Reply 2 years ago
    can you please look at my tutorial
    TheGeek1984
    So, from what I gather from looking at my knife and opening and closing it, this is how you make the blades stop when opening them.
    I apologize for the crudeness and poor handwriting...
    TheGeek1984colorex
    Not a problem. I wasn't sure if you'd had a reply yet, and I knew from watching shows like "How It's Made", the mechanics of it. But I had to see it in action by opening and closing my knife before I felt like I could even try to articulate it. I hope it helps!
    mrsmerwin
    2 years ago
    I have to try this soon.
    ansh90
    5 years ago on Introduction
    you know you can break an actual knife and drill a hole and replace the traditional wood right?
    but be careful when breaking the knife
    use the small ones on not the bud bread knife or something like that
    nattyclem
    brilliant instructable, I love it and are probably going to make one.
    well done and I really hope you win a prize. with you all the way.
