Portable Bluetooth Speaker (FREE PLANS)
54,025
347
50
About: Nice to meet you! I'm Donny from Lithuania and I have a passion for designing aesthetic, yet durable and practical projects. Check my YouTube channel for more! ▶ http://www.youtube.com/c/DonnyTerek
Hello everyone! In this Instructable I will show you how I built this Portable Bluetooth Speaker that sounds as good as it looks. I have included Build Plans, Laser-Cut plans, all the links for products that you would need in order to build this speaker by yourself and the Wiring Diagram is free download and you can find it at the end of this intro or in the Electronics Step. Make sure to zoom in to see the connections up close!
I was always astonished by the design of Bose - the manufacturer of amazing speakers. With that I mind I wanted to create my own portable speaker for the fraction of the price. Many hours were spent designing the speaker and sourcing materials in order to build this speaker. Therefore I will share the whole building process with you!
Supplies:
Step 1: Idea and Design
To begin with I created a 3D model of the speaker in Sketchup keeping in mind the inner volume of the speaker enclosure required for the drivers. Sketchup is a great tool for visual assembly and designing of the speaker. I then made drawings in CAD for the panels needed for the build and brought them to my local laser-cutting company to cut the panels out of 4mm plywood. The laser made incredibly accurate and clean cuts in the plywood resulting in perfectly fitting parts and easier assembly.
Step 2: Parts and Materials
The materials and parts for this speaker are available from the links below and/or your local suppliers. For the enclosure of the speaker I used 5 layers of 12mm MDF. The main and supporting panels where cut out of 4mm plywood sheet. The Wiring Diagram for the electronics is provided so make sure you take a look!
Sign up for 5$ off! : https://givingassistant.org/?rid=nT0ik2kFki
COMPONENTS:
TOOLS and MATERIALS:
      Step 3: Speaker Enclosure
      I have uploaded free build plans for this speaker! You can find them at the end of this step. Make sure you print the plans and make sure that the measurements are correct using a ruler! Also you can download the .dxf plans and ask your local laser-cutting company to cut them out for you in few minutes instead!
      To build the enclosure I used a router and a laser-cutter to achieve almost perfect results with minimal effort but I have also uploaded a set of plans for those who may not have access to such tools. Using the plans provided, the speaker can be built using the same materials (12mm MDF and 4mm plywood) and simple tools, such as a jig saw and a drill. The most important thing is to make sure that you print the plans at the correct scale. To check if you have printed the plans correctly, simply print out a page and using calipers or a ruler check whether the speaker holes match the dimensions written.
      I traced out the plywood template on all 5 MDF pieces. Four holes where then drilled through the boards with a decent sized drill bit and a jigsaw was used to cut around the template staying as close to the edge as possible. Once I had the 5 pieces cut out, I applied narrow double sided tape on the plywood template and stuck it down on the MDF cutout. A spiral flush trim bit was loaded in to my router and the height adjusted to cut the MDF only. Turning the router and dust collection on, made the job of creating five copies of the template quite easy. I lightly sanded both sides of the enclosure pieces to get rid of any burr left on the edges. Using a plastic card I spread the wood glue on the enclosure piece and glue one on top of another stacking 5 layers of MDF together. Once the glue has dried, I sanded the enclosure for a smoother finish. I then took a flush trim bit, removed its bearing and replaced it with a smaller one in order to cut very little into the MDF enclosure. The lip that is carved out by this process on both sides, ensures that the supporting panels sit nice and tight in the enclosure. I made sure to use sufficient dust collection because trimming MDF with a router makes a LOT of nasty dust. After that I used a roundover bit to roundover the edges of the enclosure. This makes the enclosure a lot smoother and nicer to hold in hand and also provides curves that are more easily wrapped in vinyl later. I then proceeded by drilling a 16mm hole in the enclosure for the main switch. A step drill bit was used to drill the hole – this tool is amazing! A healthy amount of wood glue was then spread along the edges created by the router bit and the support panels put in place and allowed to dry.
      Step 4: Plywood Panels
      I then sanded the faces of the laser-cut plywood panels using fine grit sandpaper to remove any burn marks on the wood from laser cutting. I placed both panels on a sheet of paper and sprayed couple of coats of lacquer. This brought more depth in the wood grain, highlighted the text and created a protective layer on the plywood.
      Step 5: Gluing in the Plywood Panels
      I then applied glue around the edge of the speaker enclosure, spread it out and pressed in the supporting plywood panels which sit nicely on the edge that is made with the flush trim bit with a smaller bearing. The panels are pressed in place for a few hours until proceeding to the next step.
      Step 6: Covering in Leather Vinyl
      For this process it is necessary to have good ventilation and to cover both sides of the speaker enclosure in masking tape to protect any plywood surfaces from unnecessary contact adhesive on the edges which would later prevent the plywood panels to be attached close together. It is important to only cover the MDF in contact adhesive. Once both sides of the enclosure were covered in tape, I started applying the contact adhesive with a soft brush, making sure to cover the whole enclosure where the leather vinyl would wrap around.
      Once the enclosure was covered in contact adhesive, I cut a long and narrow piece of vinyl leather and applied the same adhesive on the back side of the fabric itself, being careful not to apply any glue to the leather side of the vinyl. Once the glue has become dry to the touch on both surfaces (drying takes only few minutes), the vinyl can be applied.
      Unfortunately, I have lost the footage of me wrapping the material around the enclosure and gluing in the passive radiators, but I will try to explain the process as best as I can.
      It is important that the leather vinyl piece is a rectangle with straight edges on all four sides. That is important because when wrapping the enclosure in vinyl we will end up with a seam on the bottom side of the enclosure. This seam can be almost invisible if the edge of the vinyl is cut as straight as possible and the tucked into another side of the vinyl piece once the vinyl is wrapped all the way around the enclosure.
      The most difficult and skill-requiring part of wrapping the enclosure is taking care of the corners. Using the roundover bit in the previous step helps a lot since it creates soft curves which are more forgiving for wrapping the material. The key is to pull the vinyl with a lot of force and tuck in the inside of the speaker and slowly working your way down to avoid any wrinkles and bumps. A plastic gift card is a great tool here.
      Once the vinyl is tucked around the edges, a sharp (brand new) blade is used to cut along the plywood support panel in order to remove the excess of the vinyl.
      Step 7: Electronics
      Feel free to download the wiring schematic and zoom in for a better view!
      These tactile momentary button switches were used to turn on the Bluetooth and the battery capacity board. The face of the button was lightly sanded and two-part epoxy was used to glue them in place. It is important to seal the edges so that no air leaks out of the speaker once it is done. A dab of epoxy was placed on the switch and the plywood disc pushed in place. I also used epoxy to glue in four (1 red and 3 green) LEDs. Four 330 Ohm resistors were soldered in place of the LEDs that were on the battery capacity tester board. The shorter wires that were soldered to the board will later be soldered to the switch. The longer wires that were soldered to the board will later be soldered to the outputs of the BMS (Battery management system) board. Then four pieces of wire were soldered to the board which will be connected to the four LEDs glued on the panel. A piece of double sided tape is used to attach the board to the panel. Three 18650 cells were then glued in a triangular arrangement for better fitment inside the enclosure. Then the cells were connected to the BMS board. The wiring diagram is shown above. I then soldered black (negative) and red (positive) wires to the DC jack for charging. I then proceeded to wire up the audio sources. I began with soldering the blue LED to the KRC-86B Bluetooth audio receiver board. I then took a 3.5mm audio jack and soldered two 1kOhm resistors. One from Left channel to Ground and the other from Right channel to Ground. This almost entirely eliminates any background noise when using the AUX port. The wires from the audio jack were then soldered to the Bluetooth board to the according terminals. I then soldered wires to the ‘GND’ and ‘VCC’ pins of the Bluetooth board from a 555 timer chip and a few components to create switching circuit that only turns on when a button is pressed and that way the battery energy is not consumed when the speaker is not in use. A step-down converter and an isolated converter was used to supply power to the Bluetooth board and eliminate any ground-loop noise. I then took the White LED switch and soldered two of its pins together to make the LED turn on when the button is pressed in. The remaining wires were then soldered to the PAM8610 amplifier. The two remaining wires from the battery capacity baord were soldered to the DC jack. The blue LED from the Bluetooth board was then glued in place and the wires from the switching circuit soldered to the button. The audio jack was ten attached in place and the wires from the DC jack soldered to the ‘P+’ and ‘P-‘ terminals of the BMS board. The remaining wires were soldered to the main LED switch which was the pushed in place.
      Step 8: Final Assembly
      For the final assembly the full-range speakers were bolted down using M3 bolts and nylon nuts from behind. This creates an air-tight seal around the drivers. Once the speakers were bolted in place, the output wires from the amplifier were soldered to the speakers. Wood glue was spread around the edges of the panel and pressed in place for a tight fit. I then stuck a long piece of double sided foam tape around the back panel support to create an air-tight seal once the back panel is screwed in place. Four adhesive rubber pads were put on the speaker bottom. With that done the speaker is now ready for a quick charge and proper use.
      Step 9: Finished Product
      Once the speaker is charged it is ready to produce some noise. The battery indicator lights show that the battery is now full. The white LED switch is pushed in turning on the speaker. With the button pressed, the Bluetooth is enabled and the speaker is ready to pair with an audio device. Once paired, the music can be streamed for up to 6 hours on full volume and nearly 5 days on 50% volume! The battery life on this speaker is stellar due to high capacity Lithium-Ion cells and very efficient class-D amplifier board.
      The audio recorded on my end and then played through your speakers may not be the best depiction of audio quality but I can ensure that this speaker delivers great sound quality and decent bass filling an entire room.
      Thank You so much for following me through this tutorial! I hope I have managed to inspire you to create your own speaker using my or your own design :)
      And that's how my Portable Bluetooth Speaker came to be! It was a pretty cool project that helped me improve my skills, and I truly hope that you learned something new as well. If you have any questions, feel free to ask in the comments. Also consider visiting my YouTube channel for more videos. Thanks!
      Also, take a look at my Etsy shop!
      Thank You!
      - Donny
      • Woodworking Contest
        Woodworking Contest
      • Arduino Contest 2019
      50 Discussions
      Robear51
      Question 5 weeks ago
      Hi Donny,
      I have a question regarding the electronics for the bluetooth momentary switch.
      Did everything according to the plan but it does not seem to do anything. The bluetooth comes on automatically as soon as I turn on the speaker. Re did twice with the same result....
      Any thoughts on the subject?
      Thanks
      Robear51
      Question 2 months ago
      While building this project which is great BTW, I have a little issue with the battery pack and the charger. After following the wiring diagram closely and assembling it, I have good voltage on the B+,B- (+12v) terminals but nothing on the P+ and P- post...
      Any thoughts
      Thanks
      Robert
      Edit : Hi again. Problem solved. The charger requires an initial charge in order to trigger the output. All good.
      c44otg
      Question 3 months ago on Step 7
      In your parts list, you didn't indicate what the capacitor value was. I am going to build this speaker, have had the body completely laser cut out and in process of ordering parts. The capacitor is the only part I don't have a part number for.
      KolfMAKER
      Question 7 months ago on Step 6
      Hi Donny, what a great build, thanks for sharing it!
      Is is possible to share the Sketchup files?
      (I can unfortunately not import or convert the DXF file)
      AspireS3
      8 months ago
      I have followed modules... But have dubbed in circuit connection so can you help me to build a 2*15w bluetooth speaker...
      5v DC power supply, 5v-12v DC step up circuit, bluetooth module v2.1, 12v amplifier circuit (PAM8403), 15W Speakers...
      adriánl123
      8 months ago
      Hello i have a problem when i mount all the pieces
      When the speaker is connected to my pc and to the electricity the right speaker (after 2h runing) it's geting hot but the left speaker not and i don´t know.
      The second insue is that when the speaker is conected to the electricity and i not conect the jack it procuce annoying noise.
      And thanks for the documentation of the speaker
      lollyboy9
      10 months ago
      I have a question so how did u managed to lower the ampere of ur batterypack?
      because i just need like 1 ampere and not 20.
      CarlosF194
      Question 1 year ago
      Hi, I have a couple of electronics questions (I am beginner in electronics):
      1) Could I charge the batteries from a 5V micro-USB standard connector instead of a 9V? The only problem I see is when speaker is connected to socket, thus PAM would only receive 5V, right? Maybe I could add a step -up (5V to 12V) converter to feed PAM while on charging?
      2) Why there is the need to add a 555 timer (and its resistors and capacitor)? What is its function exactly?
      Awesome project, thanks for sharing!
      1 answer
      GoMartin300CarlosF194
      Answer 11 months ago
      the 555 timer is used to detect the momentary pushing of the button, if the button is pressed, the IC detects this and will then cut off power to the bluetooth board. This way when using the headphone jack, the bluetooth board will not be using any power or sending audio signals over the same wire as the audio input jack.
      However, the bluetooth board provides pins so that you can connect the audio jack to the bluetooth board. it will then automatcally switch between bluetooth and headphone jack if the bluetooth is connected or disconnected.
      BUT! i have not tried this myself so there may be a reason why Donny did not do this that i am not aware of.
      GoMartin300
      Question 11 months ago
      first of all, amazing build, i love how the small size increases the usability! I'm going to be using your build plans because i couldn't find a single descent small speaker build where they took the time to do the math for the drivers and passive radiator matching up until this one.
      I was wondering if you could provide the 3d model files(you mention creating the speaker in sketchup), i am looking into building your speaker 3 times (one for me, my brother and one as a gift to a close friend). Since i don't own a jigsaw (what a noob right :p) and don't own a stable grinding platform as you do (the table with the turning tingy). I was hoping i could use your 3d file's and if needed modify them so the main body 'tube' could be 3d-printed. By 'tube' i mean the part you create by gluing together the 12mm thick MDF cutouts.
      The front and back panel i will stil laser-cut since screwing into 3d printed parts is not going to work and i don't think i could make it air-tight.
      As a second question, could you provide some more information on the wraping material you used please? Are all vynil fabrics alike or is one more durable than the other.
      and my last question:
      if i were to 3d-print, would it be useful to make the wall's thinner, which would increase the internal volume of the speaker, or was the volume a perfect match for your calculations?
      The only thing i plan to change to the electronics is adding a usb-c and micro-usb connecter with a boost converter to 12V for charging with a phone charger. I will also replace the BMC in your project with a BMC that has balance charging, but that's the only stuff i'm going to change. I'm currently studying electronics engineering at a university level and i could do the other electronics stuff as good as you did it!
      Kevlar-evo
      1 year ago
      Hi, thanks for all the instructions, it's one of the most complete I have read on DIY bluetooth speakers. I will definitely take some information from it !!
      Just a short remark : the link to the passive radiator goes to the amplifier, it the same link than the previous line.
      BertalanK
      Tip 1 year ago
      Use some sound absorbing material inside (eg. cotton wool) to avoid acoustic standing waves.
      And,
      if you settle for lower volume for more bass, measure the frequency
      response of the completed speaker+cabinet system and use equalisation.
      It's just some passive RC-components and an OP-AMP...
      My speaker
      is an 8cm driver in a 2liter closed box. It needed +8dB @50Hz and -4dB
      above 2kHz. I measured with white noise from youtube and Spectroid
      android app. Checked the sound with foobar's EQ before build the
      phisical EQ circuit.
      BertalanK
      1 year ago on Introduction
      And,
      My speaker
      Robear51
      Question 1 year ago on Step 4
      Hi. This looks like a really fun project. Thanks for the plans and the wiring, it is very helpful. I noticed that the front and back panels are laser cut. As I don't have a laser cutter, is there any chance in getting a DXF file for the front and back. I have a friend who works in a laser cutting business and could do the work for me. Thanks
      Robert
      Donny TerekRobear51
      Answer 1 year ago
      Hi! Thanks! I have just uploaded a set of DXF plans for the build, feel free to give those a try!
      Robear51Donny Terek
      Answer 1 year ago
      Thanks again. Wasn't sure where to ask hence the message here and on Youtube.
      SalilG2
      Question 1 year ago
      Couldnt we power the Bluetooth module directly from one part of the 18650 cell, i.e. 3.7v off the single cell and let the remaining amp work on 12v? Is that even possible seeing that you have not used a balancer?
      1 answer
      Donny TerekSalilG2
      Answer 1 year ago
      Hi! You could power the Bluetooth module directly from one 18650 cell but that would result in a bigger amp draw from one cell which would later cause problems while charging since the cells need to be very close in voltage in order to charge properly through a BMS.
      JonasM37
      Question 1 year ago
      Hey. Sorry for asking.
      But, what is the size of the panels? I mean on the 4 sides?
      Example: Back Panel, On the 4 sides of this one?
      Best Regards
