Portable Container for Earbuds
60,131
548
33
I actually made this about five years ago but thought I'd share. I liked carrying my MP3 around, but sometimes the earphones' cord was a bit excessive, catching on things as I walked by, or I'd accidentally step on it when crouching to pick up something. At the time they were my only earphones as well, so I used them constantly and didn't like continually winding and unwinding it from a rubber band when I needed it, so it would just end up a tangled mess.
I had a bubblegum container that had been laying around prior to my dilemma, which I had kept hold of, thinking it may come in use one day. Well yes, that day was upon me.
I had only seen one other person on the internet use the exact same container for the exact same purpose (for the life of me I can't remember the site). The only exception being that it was strictly for carrying said earphones. If you wanted to use them, you had to take them out entirely, which still left the issue of duking it out with the long cord, and the container is left as wasted space in your pocket or bag.
I wanted mine to stay together, so that my earphones could be used and somewhat contained at the same time.
Step 1: Materials
*Gum container
*Two beads (one shown)
*Two rubber bands (one shown)
*Earphones
*Paperclip
*Drill (not shown)
Step 2: How It's Done
-Drill a whole in the lid and bottom of the container. Make sure the whole is big enough for the cord to go through.
-Instert a rubber band through each bead (the beads are to hold the auxiliary bit in place at the bottom of the container).
-Thread the aux. through the top whole.
-Loop the first bead onto the cord just a bit above the aux., and then feed the input through the whole in the top of the container (this part will be a little tricky).
-Once through, loop the final bead around the aux.
Step 3: Almost Done.
Now to contain the mess on top.
The paperclip helps adjust  how much cord I need.
-Adjust for desired cord length, clip, and tuck the remainder of the cord into the container (be sure the paperclip is inside the container to keep the cord from slipping through the whole).
Step 4: Done
(Hopefully) pretty straightforward.
I'm sure there could've been many other ways to go about this, but it was fun doing this project with what I had available at the time.
    • Warm and Fuzzy Contest
    • Organization Contest
    • Paper Contest
      Paper Contest
    33 Discussions
    Kris T.
    5 years ago on Introduction
    I managed to find that site again: http://organized31.blogspot.com/2012/08/repurposed-mentos-bottles.html
    prmlegal
    5 years ago on Step 4
    THANK YOU, THANK YOU, THANK YOU!
    I can't tell you how long I have struggled with the issue of long, dangling cords from my ear buds. Since I am ADHD, I use my ear buds constantly as music therapy to help me stay focused on my work and when I work out, practically every day.
    Oh the frustration and angst I have had every day dealing with what to do with all that tangled mess of a cord....
    You may laugh, but I've wrapped it around my arm, my bra strap, my neck, a headband, stuffed the cords in my exercise bra and even tried to make my own "neck wrap" like those expensive ones designed to sit on the neck and wrap so snugly around your ears (can't afford those). Finally just gave up and literally hold onto my phone while working out or stuff my phone into the top of my pants to hold the cord from flopping around. Drives me nuts.
    THANK YOU FOR SUCH A SIMPLE SOLUTION TO A FRIGGIN ANNOYING PROBLEM.
    RhenN
    3 years ago on Introduction
    Wow! very creative! Now I got an idea about this great post! I'm thinking to make a portable container too. Then I luckily see this. Thanks for your post
    Thanks for inspiring me to think about this tangled subject Kris.
    My first protoype is made from a 35 mm film cannister. The main aim is to protect the earbuds and mic/switch. The woven covering on the Urbanears Medis cord seems to behave itself in my pocket when wound around as shown on the photo. I'll add some extra tidyings as I discover how this first attempt of mine settles into daily use when I travel on buses.
    I will post this pic on Facebook and link to your helpful 'ible here.
    Cheers
    Peter
    thank you its is pretty amazing plus I find out that you can also made it with a tick tac box or any
    ehauss
    5 years ago
    So smart
    Atom 6
    5 years ago
    Cool
    jtimothy
    This is really great, and I was wondering if you could use another paperclip for the aux pin instead of the beads, cos they are really confusing x_x
    Kris T.jtimothy
    Reply 5 years ago on Introduction
    I don't see why you couldn't. Basically you just want something to keep the aux from slipping out of the container. Use what you've got! :)
    sparrland
    First of all I love the Mentos containers. I have always wondered what I could use those empty containers for. Pill holders, needle holders etc. but I LOVE this idea. Can't wait to try it out maybe using something flat like a button instead of the bead, if I can work it out.
    Kris T.paint321
    As Trelligan said, a knife might leave sharp edges which could damage the cord. If you can find a way to smooth the edges after cutting, it might be pausible.
    Also, if you choose the knife route: MIND YOUR DIGITS AND OTHER APPENDAGES. Wouldn't want you to get hurt.
    Trelliganpaint321
    Depending on how hard your plastic container is. If it's very hard, you don't want a sharp edge to cut into the insulation on the earphones.
    A fast enough drill tends to melt the plastic a bit, leaving easy to clean-up globs.
    A knife cut might need some smoothing.
    Patscrafts
    I think I am being dense, I don't get how the paperclip hold the cord in the top. Do you 'clip' it onto the wire?
    Kris T.
    Featured? 300+ Favs?! 21,000+ VIEWS?! I gave a laugh and slapped my knee (actually, the desk was in the way, so I slapped it instead). My day is MADE!
    pbm67
    Cracking idea. Just one editorial comment. The thing at the top and bottom is a hole. A whole means everything added together. :-)
    Kris T.pbm67
    Ah, this is the result of attempting to post an Instructable WELL past bedtime. If that's the only "oops" you've found, I'd say I did pretty well. :)
