Portrait Gourds Grown in Molds
129,721
404
62
About: Tim Anderson is the author of the "Heirloom Technology" column in Make Magazine. He is co-founder of www.zcorp.com, manufacturers of "3D Printer" output devices. His detailed drawings of traditional Pacific...
Here's how to grow gourds in a mold to create any shape you want.
Even portrait sculptures. It's an ancient technique from China.
This method also works for other vegetables. Portrait pickles anyone?
Jim Widess, proprietor of "The Caning Shop" in Berkeley CA and author of many books on gourd craft walks me through the steps.
These molds and gourds were made by the Chinese master Zhang Cairi.
Supplies:
Step 1: Get or Carve the Original Pattern
Here's Jim Widess holding mold-grown portrait gourd sculptures of himself.
The light-colored one is the gourd's natural color. The darker one was stained with dark tea.
Almost any object can be used as a pattern for gourd mold.
Most likely you'll want to cast your head full-sized and make a mold from that.
Watch this space for an instructable detailing that process.
The mold must be slightly smaller than the gourd's natural size.
Match the gourd to the rough size and shape of the object you're molding.
There are gourds that grow very large and in a variety of shapes.
Step 2: Head Patterns, Mold, Gourd
The original clay sculpture is on the left. Then Zhang made a latex rubber mold over the original, pulled it off, and cast hard rubbery plastic resin in that. That's the white version standing to the right of the original.
That white pattern was used to cast the mold you see here.
This particular mold has a rubber interior and plaster around that to support it.
From left to right are the original carved pattern, plastic resin duplicate, and an actual gourd grown in the mold.
Step 3: Gourd in Mold
Depending on your climate, the gourd seeds are planted in the spring in a sunny place that gets plenty of water. If it's cold you can sprout and start them indoors. It's best if you have a trellis for the gourd vine to climb up. When the baby gourd is just big enough, put it in the mold.
Step 4: Clamp the Mold Shut
While I am taking this picture Jim is explaining that next you
clamp the mold shut by tying it with string or wire.
Step 5: How to Hang the Mold
While I am taking this picture Jim is explaining that you next suspend the mold with string or wire so the vine doesn't have to bear the weight of the mold.
Step 6: Nature Takes Its Course
If you harvest a gourd when it has reached the size you want, it will be soft and won't keep well.
You must wait until the season has finished and the vine starts to die. When there are six inches of brown dry stem above the gourd, you can harvest it.
This picture shows approximately how the gourd sculpture looked in the mold. It was a much lighter color at actual time of harvest.
Step 7: Remove, Dry, and Finish the Gourd
This mold has a flexible rubber lining which makes it easy to remove from the gourd.
A plaster mold adheres to the gourd more tenaciously and usually the mold is destroyed in the course of removing it from around the gourd.
The gourd is then allowed to dry slowly, and the outer coating called the "cuticle" is removed.
Then the finishing steps, if any, are done.
On this gourd, the details of the face and hair were then traced with the point of a jade knife to enhance the detail, It was dyed with dark tea, and a coat of varnish was applied to make it shiny.
Step 8: The Finished Gourd Sculpture
Here's Jim again with the finished sculptures.
One is tea-colored and one is the natural color of the gourd.
He's standing in front of a gourd vine [www.caningshop.com at his shop].
For more details on Zhang Cairi's methods, get a copy of the book.
This method will work for many other vegetables also. Portrait pickles anyone?
    • Arduino Contest 2019
    • Fandom Contest
      Fandom Contest
    62 Discussions
    artmakersworlds
    2 years ago
    So how do you make the mold? What materials, where do you get the materials, where do I find instructions on actual mold making for this?
    I have growing a gourd between two panels of hand carved wood but it just gets rotten.
    AntalyaS
    4 years ago
    Just by chance I met this group while surfing on the Internet...
    I have lived in US and returned to Turkey a few years ago. After my return , I have been in search of what to do and finally decided making gourd lamps.
    First, it was just a hobby but making gourd lamps turned to a pofessionality in time and today I am a gourd lamp producer and exporter.
    If you would like to have an idea about my works please visit following links. Starting from gourd lamp beads to table lamp bases, you can find some materials used for making gourd lamps.
    marmarisgeceleri.blogspot.com
    antalyakabakevi.blogspot.com
    pinterest.com/makbulerdogan
    instagram.com/gourd_lamp
    antalyakabakevi@gmail.com
    Thank you,
    BitisG
    4 years ago on Introduction
    Nice! This is exactly what I was after. My question is, how do you make the actual mold? And if one did the latex method of making a mold, how do you create a mold of the object you want in the shape of a gourd? Great instructables.
    Wow Jim! This is so, so cool! I've always loved coming to your shop on 8th Street and miss my times there for gourds, beads, leather, classes, etc. I think I may want to try this new thing!
    Ellen Willingham
    wow, there is a site called www.fruitmould.com has more type of this kind of molds , there are square watermelon molds ,buddha pear molds ,baby shaped molds and many other type of molds , you can check ,there will be a lot of fun ...
    paneer65
    5 years ago
    fascinating!
    gnawrag
    7 years ago on Introduction
    I once grew a pear inside a bottle for pear infused vodka. It tasted great and really impressed everyone who saw it.
    I had heard of the molded square melons before and always assumed that the mold needed to be transparent to allow light to fall on the surface of the fruit. I guess gourds don't need sunlight on their skin to grow. Great project really has me inspired for spring.
    angela-la-la
    "the outer coating called the 'cuticle' is removed"
    Anyone care to speculate on the process for this? Gentle abrasion, chemical process, very tricksy work with a peeler...?
    shortone
    https://www.instructables.com/id/Gifts-For-Guys/
    Put you in my gift guide for guys! Just thought I'd let you know :)
    Drake79
    9 years ago on Step 8
    Can you grow more than one gourd inside a mould? If so it would/could make for some really interesting effect....
    90mp11Drake79
    Reply 7 years ago on Step 8
    So long as you leave enough space so that the vine's aren't having any weight put on them I can't see a problem with it.
    Wouldn't water get into the mould and rot the gourd in the process of the casting?
    BtheBike
    8 years ago on Introduction
    this reminds me of 'Invasion of the body snatchers' pods
    DIY-Guyewilhelm
    I looked at the video and was wondering, well, exactly why did you encourage us to watch that video? Was there something relevant to this instructable? Maybe I missed something. Please clarify.
