Potato Powered LED!
2,069
13
8
About: My name is Babak Eshghi and I am currently operating ScienceKitShop.com, a retail and wholesale distributor of science education products, based in Clifton, NJ.
LEDs require more than 2 volts to light up.
Each Zinc-Copper Potato produces 1 volt. In this particular setup, we've created 3 - 1 Volt batteries connected in a series so that they can light up an LED.
Please see photos for directions.
Also see "Metal Reactivity Series" table to learn more.
Supplies:
Step 1: What You Will Need
1 LED 2-3V
3 Idaho Potatoes
3 Copper Electrodes (5" x 3/4")
3 Zinc Electrodes (5" x 3/4")
4 Double Sided Alligator Clip Wires
Rubber Bands
Step 2: Connections
See photo for connection setup.
Note: The LED has a positive and negative so if your connection doesn't initially work, just switch the wire connection to the legs.
Step 3: Make Electricity!
Light & Dark Photos of the lit LED!
Step 4: Kit With Instructions
You can find the make electricity kit on ScienceKitStore.com
    • Classroom Science Contest
    • Party Challenge
      Party Challenge
    • Fandom Contest
      Fandom Contest
    8 Discussions
    KayleeV1
    4 years ago on Introduction
    It should Persee Idaho potatoes are like andwoord back later for 20:00 but the best is for 20:00 Can you use regular potatoes?
    KayleeV1
    moeten het persee Idaho aardappelen zijn graag andwoord terug voor 20:00 of later maar het beste is voor 20:00 kan je ook gewone aardappelen gebruiken?
    KayleeV1
    KayleeV1
