Power Button Necklace
59,200
481
50
About: I like sewing and crafts,and trying new things. I'm vegetarian and always looking for new recipes. My cat's name is Mirko and likes to be in the centre of things, so you will see him in several of my instr...
I first saw a power button necklace posted on Pinterest,  it was called an iNecklace which can be found at Adafruit, it is made from CNC machined aluminum and the light gently pulses.  But with a price tag of $75 I opted to try to make one myself.  Mine is what you'd call the poor women's power button necklace,  it was put together from stuff I had lying around the house. Although my necklace is plastic and the light doesn't pulse, it cost me hardly anything to make and I put it together in one afternoon.
Step 1: What You Will Need
  • Power button from an electronic device (mine came from an old computer case)
  • 10mm LED -I used a blue one
  • 3V button battery (I used a CR2016 from a dollar store)
  • Jewelry wire -to make the loop for the chain, I bought mine at a dollar store
  • A badge
  • Sugru
  • A necklace chain
  • Needle nose pliers
  • Drill or awl
  • (Optional) Electrical tape, black paint
Step 2: Prepare the LED
The power button that I pried out of my old computer is fairly large in size, I could fit a 3V battery inside of it. I used a 10mm blue LED and sanded it so that the light would be more diffuse.  I bent the poles of the LED to fit around the button battery and then taped them so that it would stay put.
Obviously, not all power buttons are the same size, so if you make your own you may need to explore smaller size options for the LED and battery such as sequin LEDs and CR927 3V batteries.
Step 3: Prepare the Backing
Next I needed a backing to hold the LED and battery in,  I also wanted to be able to remove it to change the battery when it died.  I found a small badge, that was the right size and used the badge shell for the backing.  I used some Sugru to form a seal around the back of the button to hold the shell on.  I took off the shell while the Sugru was curing so that it didn't become permanently attached. Once cured it created a snug fit holding the backing in place and it can be removed with a screwdriver or your fingernail when you need to change the battery.
Step 4: Finishing Up
I poked a hole in the top of the button with an awl to fit the loop for the chain which I formed with jewelry wire and needle nose pliers.  I also painted the rim of the button with black paint because I thought the button might otherwise look too large (since black is very slimming). I also painted the backing to make it look uniform.  Once the paint had dried I popped in the battery, but the backing on and it was ready to wear.
Make It Glow
Finalist in the
Make It Glow
    • Tape Contest
      Tape Contest
    • Arduino Contest 2019
    • Trash to Treasure
      Trash to Treasure
    50 Discussions
    booksmart
    2 years ago
    Thank you for sharing your knowledge with us. I hope to try it one day soon and share it here. Thanks and God bless.
    Sock Puppet
    2 years ago
    You can use a colour changing RGB LED in there. They have a tiny chip inside to change colour automatically and only cost pennies.
    https://youtu.be/gK6__cX7QgY
    Pete1013
    6 years ago on Introduction
    What kind of power button is the one you used? Is it from an Xbox or something, cause all that i keep noticing is the rim, and i really like the size that you have...
    that and im to lazy to look through my old electronics for a good one.:P
    nice work, and have you ever thought about making plastic custom buttons that you can trim out a design with an X-acto knife?
    ex: Doctor Who Logo
