Power Switch for USB Devices
14,189
376
17
This guide will show you my version of a switch for a USB hard disk. I did this as i wanted to connect an external hard disk to my router, but did not want to leave it on all the time as I just need it 2, maybe 3 times a week.
Of course you can just unplug it, but in my case and since it is in a narrow space, i prefer to have a switch to do it.
(You will need some basic soldering skills to build this)
- 1 picture: These are the parts you will need
You can use this, or any other switch you like, its easily found on ebay, as well as the USB male and female connectors.
I wanted to keep it simple so i'm only going to use the switch to cut the 5V supply and not the data pins or ground since they don't work without the 5V.
- 2 Picture: First thing I did was to cut down the pins a bit, so that they don't stand out that much, this is just for aesthetics.
- 3 picture: I used some cooper wire in order to hold the USB connector in place.
- 4 picture: And soldered some wire to the other 3 pins.
- 5 picture: Measuring how long the wires should be
- 7 picture: At this point everything is soldered in place and i wanted to superglue the connectors to the case to give it stability, but then i had a better idea
Step 1:
I soldered the case of the male to the case of the female USB connector to give it the stability i needed. With 2 copper wires, one on each side. That way you can pull on it, without it falling apart.
At this point my thought was to make it look a bit nicer with some FIMO or something similar which you can mold and then make it become hard. I wanted to use it all around so you cant see the wires, but then i just figured out that where I would use it, it would not be visible, so i just let it be like it is.
The final picture is the place its actually serving its duty.
    • Trash to Treasure
      Trash to Treasure
    • Arduino Contest 2019
    • Tape Contest
      Tape Contest
    17 Discussions
    KelV4
    2 years ago
    awesome invention
    Tachyon
    4 years ago
    I wanted to try something similar but I'm concerned about what the USB spec expects for power control this way.
    i.e. What pin or pins are expected to be switched?
    if more than one, is there an expected order or can they all be cut at once?
    data lines too?
    Ric Malandrino
    4 years ago
    great idea for an Asus mid to high level motherboard. I have one and try have a feature that let's u charge ur phone when the computer is off. so in order for a usb wifi dongle to work I will need a switch. also anything with led's stay on.
    ludovix
    4 years ago on Step 1
    FIMO need 200 ° temperature to be hard ...
    script_coded
    4 years ago
    Great i'ble!
    Though if you want to use it with a hard drive, it could harm it. In a normal USB socket some connections are longer than the other, making some disconnect first. When you use this switch only the power pins will disconnect and it could harm the harddrie. You can get special disconnecting PCBs for that. Just google it. Just making sure nothing get destroyed :)
    Great I'ble, as said ;)
    portumanscript_coded
    Reply 4 years ago on Introduction
    You're right on that, although i could not find any more info about it, it makes sense. If anyone has some technical explanation on this, i would appreciate it ;)
    techboy411
    Why not use Sugru, the wonderful paste that Instructables is (a wee bit) famous for?
    portumantechboy411
    Reply 4 years ago on Step 1
    Didn't know about that. That stuff is awesome!! A bit expensive, but still...
    3366carlos
    awesome.
    For safety reasons, I would have cut the ground instead of positive, but no big deal since it's low voltage. Good job.
    JmsDwh
    Very cool! I made a few USB adapters a while back and I used plumber's epoxy putty to cover the innards.
    https://www.instructables.com/id/Make-Your-Own-USB-Adapters/
    seamster
    This is really interesting! I can see how this would be really handy in the right situation. Nice first instructable!
