Precise Glass Bottle Cutting Jig
5,586
213
11
Yep! Another bottle cutting jig. What's the difference between this one and all the other? Don't know. Maybe precision. Or the easy ajustment.
The fonctionning is easy. Ajuste the guide, push the blade and turn the bottle.
The width is 23". You can easily move the guide to cut a small bottle or a large wine bottle.
P.S. My knowledge of english is not as good as it should be. Please feel free to send me any suggestion about it.
Thanks
Step 1: Cut 2 Pipe at 21"
Step 2: Cut the Wood Piece.
  1. You need two piece of wood, One for the base and the other for the back.
    Cut two piece of wood at 5.5" X 23".
  2. Cut two piece wood to hold your pipe at 3" X 5.5" .You will need to drill 2 hole at half the deep of the wood to hold your pipe.
  3. To make the guide, cut another piece smaller then the 2 side, 2.5" X 5.25". Drill 2 hole for the pipe and a small one in the middle for the lock.
  4. Fix all the part together.
Step 3: Add the Hardware
Add a long screw to fix the guide in place and add 2 angle iron to hold the arm.
Step 4: Ajust the Blade
Ajust the blade to be able to cut large wine bottle or small beer bottle.
Step 5: Voila
You can now cut bottle at any size.
    • PCB Contest
      PCB Contest
    • Toys Contest
      Toys Contest
    • Comfort Food Challenge
    11 Discussions
    jerryattrick
    1 year ago
    Yes I like this model glass cutter. Only thing I am wondering is, how is the slide locked to the rails? Or does the screw go all the way through the guide and fix into the bottom timber?
    Thanks for sharing
    Luc Moreaujerryattrick
    Reply 1 year ago
    The screw go all the way. Not the prettiest way to lock it. If you have another idea, please post it.
    Have a nice day
    mxx
    1 year ago
    Nice! I like the simplicity of the design!
    Erinirish9
    1 year ago
    I love your design! is the blade screwed into the arm? two pictures look like you are holding it. (or does it pivot on a screw??
    kbbaktha
    1 year ago
    This one is awesome, yet so simple, You are brilliant to think of two parallel pipes and scoring blade mount with a fixed pivot point. Thanks for sharing.
    HarryC40
    2 years ago
    looks fantastic. The last step with the blade, where would someone get one of them? Great job
    Luc MoreauHarryC40
    Reply 2 years ago
    I buy this one maybe 25 years ago. Any model can do it.
    BirgitJansen
    2 years ago
    I've been looking to build one for the longest time now. Your's looks so simple to build, yet very functional, this might be the one for me to attempt! Just one question: do the pipes rotate or are they fixed? Does it even matter?
    Nice job on this instructable!
    Luc MoreauBirgitJansen
    Reply 2 years ago
    They do not rotate but I don't think it's matter.
    Thank for the comment.
    OldGuy52
    2 years ago
    This design is elegant in its simplicity! Clear instructions, good photos. Well done!
