Press Aluminum Cans Into Ceiling and Wall Tiles
165,820
737
119
About: Dad and hubby, good food enthusiast, solar energy, boating, making stuff, melting stuff, and raising chickens.
This is an experimental project that uses aluminum cans to make decorative metal tiles for ceilings or walls by cutting open the cans into flat rectangles and using a die stamp to form them. This is similar to my beer can roof project except the die making is more complex here.
  • First make a tile die design in expanded foam
  • Then use evaporative (lost-foam) pattern casting to cast the tile die in aluminum.
  • Clean up and shape the die with a grinder and other tools.
  • Start cutting cans and stamping tiles
  • Staple them into place on a ceiling, wall, or whatever you can think of.
This is a very involved and semi-dangerous project where tools have to be built, very high temperature molten metal is used, fumes are created, etc. Use caution and be safe. I'm not liable for any injuries you may occur using the techniques shown here.''
Supplies:
Step 1: Make + and - Polystyrene Foam Molds of Die Plates
Make some foam cutting tools if you feel like it, a good sharp utility knife will do OK on this step. This link has a great variety of foam cutting ideas:
http://wolfstone.halloweenhost.com/HalloweenTech/fotmak_MakingFoamTools.html
Polystyrene or styrofoam of some kind is carved into the shape you want to cast aluminum into. I used egg cartons, take-out containers, and dumpster scavenged foam. These foam pieces are exactly how the aluminum cast will turn out, so put some effort into this step.
First make two rectangular blocks out of the foam, about a half inch think and 8.25" by 3.75".
Print out a stencil or create your own for guiding and cutting a design on the 8.25" x 3.75" foam blocks. Here is this stencil link for use in Google Sketchup. If you make your own design, you'll want ribs of some kind as part of it to strengthen the tile. The templates I made have two squares which are the ribs. Cut the features into the foam very carefully with a sharp utility knife or exact o knife. The depth of the imprint should be shallow, about 1/16". A polystyrene egg carton is about the right thickness, a meat tray is too thick.
One foam piece should have an negative impression in it and the other should have the positive impression using egg carton foam (see picture). The two pieces of foam should have some wiggle room when assembled to make room for the thinkness of the aluminum can that will be pressed when the die is finished. You'll still need to clean up the final cast with a dremel tool.
Now finally hot glue on a foam sprue on the center back of the block; this forms a channel for pouring the molten aluminum into the cast. I used a 3" long piece about .5" x .5". In the pictures you'll notice two sprues/vents but these do not work, use a single center sprue.
Step 2: Put Foam Piece Into Dry Sand.
Before burying the actual foam pieces that were just carved, I recommend casting a couple of test pieces until you get the hang of casting.
In a metal canister or metal tub, fluff up some plain mostly dry sandbox sand that has been sieved with window screen. Press the foam mold into it the sand; then pack sand around the whole thing and bury it. Pat for a minute to reduce air pockets in the sand around the object. I added bricks on top of the sand to keep it packed tight.
Set a large metal soup can with both ends cut open onto the sprue; this is to funnel the liquid metal into the mold.
Step 3: Melt Aluminum
I'm not going to detail everything about casting here but I'll list some good links on metal casting and safety. Most importantly do this outdoors.
Casting Aluminum at submarineboat.com
Home Foundry
BackyardMetalcasting.com ...Melting and casting metal yourself
Gather aluminum from everywhere; lawn chairs, stereo amps, computer hard drives, beer cans, lawn mower and weed trimmer engines. It'll take about a pound of aluminum per die half, melt down more than what you think you'll need.
Make a charcoal fueled aluminum melting furnace, link to my quick and cheap aluminum melting furnace setup instructable for details on the information below.
Using the 5 gallon bucket furnace, and depending on the amount of aluminum to be melted it can take from 10 minutes to 25 minutes to have a pool of molten metal.
The pictures below show a metal 5-gallon bucket, a piece of stove pipe, hair dryer, and some duct tape for cheap a foundry furnace. A hole is cut in the bottom side of a metal bucket to fit the stove pipe. The bottom of another metal bucket is cut off about 2 inches from the bottom; a lot of holes are punched in that piece and its inserted into the main bucket as a burning grate. Keep bucket lids, one lid should have a vent hole in it for burning and the other lid should be left unchanged for snuffing out the fire. The hair dryer needs to have the "cold" button taped to use it just as a blower; tape the dryer into the stove pipe.
For a crucible, a 14 oz propane bottle was used; the top was cut off and some bolts were added for grabbing the crucible with the tongs. I made some basic tools with some scrap steel from an old bed box spring. You'll need tongs for the crucible, some kind of shepard's hook to tip the crucible, and a plain rod with a little bend at the tip for poking things and skimming out the dross (impurities in the aluminum).
To operate this, fill the furnace 1/3 full with charcoal and light it like you're going to cook some hot dogs. Wait until the coals start to turn grey on the edges, now fire up the blower and set the crucible in there with chucks of the aluminum. Cover the furnace with the vented lid, then grab a chair, a drink, and wait. When the aluminum is liquid, skim the floaties off the top with a hooked metal rod until the molten aluminum looks like a shiny pool of mercury. Now it's ready to pour.
Have all the safety gear on, turn off the blower, remove the lid and use the tools to grab the crucible and pour.
Step 4: Pour the Liquid Metal
Like the last step, do this outdoors with good breeze, the stink of the plastic burning out of the mold is not too good for you.
Have everything ready with the foam mold and sand; also have a steel muffin tin or something similar for pouring excess aluminum into.
Pour slightly quick and aim well. This may take some practice with little chunks of foam before pouring the big project. Actually, I've recast the "big project" five times until I finally got the hang of casting.
Once poured, wait about five to ten minutes for cooling before poking at it. It will still be 500 degrees F or more; watch out it will be hot for about an hour after sitting. Use pliers to handle it. The sand also will hold this immense heat so don't start playing in it like I did, with a gloved hand (luckily).
Step 5: Clean Up the Cast
Use a wire brush, grinder, file, and dremel to clean up the cast. Remove little bumps and funny spots and cut the sprues off the casts. If you used styrofoam egg carton for the mold details, the depth of the positive die needs to be taken down by about half; also round the all the edges slightly. This might take a while until both casts fit together nicely with wiggle room. If there is too little wiggle room between the negative and positive die, it can act like scissors and cut or break the thin aluminum tile.
Step 6: Cut and Stamp Cans
First cut the raw material, the soda can.
This gets sharp, so wearing gloves is important. Use scissors or tin snips to cut the top off the can at the seam where the can bends. Cut down the center to the bottom and then cut off the bottom of the can. You should now have a rectangular piece of aluminum sheet metal.
Cutting lots of these little aluminum sheets in advance is nice
Lay a sheet in between the dies to make a little sandwich. Give it a few light raps with a ball peen hammer until you feel the deformation of the can. Open it up and see the tile; if you dies aren't perfect, this may take some practice and some dremel adjustments until everything works. Actually my stamp still tears and breaks the cans often, I think it has something to do with the sharp angles of the design.
Step 7: Install Metal Tiles
To cover an area, it takes about 4.5 can tiles per square foot. Install with a staple gun or something similar. Start from the end farthest from the entrance on a ceiling or start from the bottom when installing on a wall, this helps hide the overlapping seams.
Each little can isn't perfect, but when they're all installed the effect is nice.
Second Prize in the
Epilog Challenge
Runner Up in the
Earthjustice United States of Efficiency Contest
    • Fandom Contest
      Fandom Contest
    • Gardening Contest
      Gardening Contest
    • Woodworking Contest
      Woodworking Contest
    119 Discussions
    Bricology
    3 months ago
    Another option to explore is instead of using cast aluminum dies is to build dies up from MDF or HDF ("Masonite") sheet over a heavy backing (such as scrap Corian or 3/4" birch plywood). It's easy to cut and form with a rasp and sandpaper, since it comes in a variety of thicknesses, one can produce designs as shallow as 1/8" deep, and it's very strong under compression. It probably won't survive as long as the cast aluminum dies but it doesn't require the infrastructure either.
    StarrsWife
    1 year ago
    Paint the Styrofoam with a coat or 2 of spackle or drywall mud to leave a smoother surface on your finished product. I haven't tried it myself but i did read that when i was planning my forge...
    rusheggie
    1 year ago
    nice. great idea.
    smallcarterwang
    2 years ago
    Interesting. My choice is applying self-adhesive crystal-look wall tiles.
    applying-sticktiles.jpgpeel-and-stick-tiles.jpgtransform-a-space-with-blue-long-stone-sticktiles.jpgblue-mosaic-stick-tiles.pngpeel-and-stick-sticktiles.jpg
    For people that rent, you could always attach the aluminum cans directly to the ceiling using strong double-stick tape. I think this would look really cool in my bathroom...once I cover them in Rustoleum. No rust stains for me!
    The cool thing about Aluminum is that when it rusts, it rusts clear. That is unless there are specific impurities that are present during the rusting process. In fact there is an art/science to it, it's called anodizing and it can produce some beautiful results. The best part is that the rust, although only microns thick, is as hard as Sapphire. Because Sapphire is aluminum rust.
    If you decide to go that way I would love to see your results (please share with the community)!
    If you see rust, its not the aluminum that is rusting. Real quick experiment for you. Clean up a piece of steel and get a piece of aluminum, spray them with a saturated solution of granular fertilizer like 13-13-13 (dont work with fertilizers and mixing them with liquid unless you know the warnings very well, some aluminum roofing materials have an oily residue to prevent oxidation and doesnt need to mix with some fertilizer) or just spray some salt water on the two and come back in a day or so and check them. Youll see the steel rusted and the aluminum didn't. If the aluminum did rust......then itis an alloy of more than aluminum.
    This is a great instructable. For the people concerned about casting aluminum, you can create the molds and cast the stamp and dies out of zinc instead. Zinc melts at around 800 deg (f) and is stronger than iron in compression tests.
    halfmumi
    7 years ago on Introduction
    Question : Can you make aluminum molds and cast aluminum inside?? Might sound silly but made me wonder...Anyone?
    I wonder, might it not be easier (though maybe more time-consuming) to skip the wet sand and make the dies out of concrete? Maybe something like papercrete for more tensile strength and durability under impact, but I'd think that would be a little easier and safer than casting aluminum dies, and you can do fine shaping before the concrete fully cures.
    In regard to crucibles, I have no actual experience in this area myself. With that disclaimer out of the way, from what I've read about DIY metal forging and smelting one can make a pretty heat-resistant crucible from a metal container lined with a thick layer of refractory mixture that is 50% wood ash and 50% cheap kitty litter (bentonite clay), moistened with water to a paste and allowed to dry after application before being fired. Apparently, wood ash is well-known for its refractory and heat-resistant properties, and the clay acts as an inert binder. I've been told it can be used at least hot enough to forge steel (lining the inside of a BBQ forge), so you should have no problem with melting aluminum. You've got a really cool instructable here!
    PKTraceur
    10 years ago on Introduction
    This is amazing! Although im not a heavy (Soda!) drinker, I think I could make some interesting lamps... So, a thought/question on the "foundry." Can a hardwood be used for fuel? What addition does the hairdryer add? Does it enable it to be hotter? How can I contain the aluminium? So, you create a foam positive, to make a wetted sand negative, thus making a aluminium positive? Is that confusing? Any tips on pressing the can with the "die cast?" Any other tips? -PKT
    robbtoberfestPKTraceur
    Wood doesn't seem to get as hot as charcoal, but maybe I'm doing it wrong. This is a first in casting for me. The hairdryer air is very important as a blower, not for heat. You make the foam exactly how you want the aluminum to turn out, that's what you bury in dry sand and pour the molten metal into. I did try heating the cans on a heater and pressing them hot; that seemed to reduce the tearing.
    PKTraceurrobbtoberfest
    How shall I come about getting a crucible? I don't like eBay, so it really isnt an option. Perhaps a steel pot? But wont that get orange-y hot? -PKT
    joeflagstaffPKTraceur
    I have purchased a few stainless kitchen utensil holders at a Ross "Dress for Less" store in my town and they hold up very well to the heat, with thinner walls than cast iron pipe
    JaycubPKTraceur
    A steel soup can makes an OK crucible, but they can burn through sometimes.
