Printing Onto Fabric at Home - Mount Spray
11,767
247
12
There are different ways of printing onto fabric using your home computer - but using mount spray is the way which I've had most success with.
Step 1: Spray Card With Mount Spray
Cut a piece of card slightly bigger than the size you would like your fabric to be - 1cm larger width and height. So if you want your fabric to be 30cm x 20cm, for example, cut the card 31cm x 21cm. This will allow you to trim it by 0.5cm on either side.
Spray card with mount spray all over, right up to the edges. It's important to use mount spray as its repositionable qualities mean you can peel your fabric off again easily.
Step 2: Smooth Fabric Over Card
Cut your piece of fabric is slightly bigger than the card. Make sure it's nice and flat - you may wish to iron it. Smooth it carefully over the sticky card. Make sure you get out as many wrinkles as possible.
Use fabric which is not too thick and which is not too textured.
Step 3: Trim Fabric and Card
Using a very sharp craft knife and a metal rule, trim both the fabric and the card by 0.5cm on each side. Make sure you press firmly and that you cut through both the card and fabric with one clean cut.
Step 4: Inspect Fabric
Your fabric should look nice and smooth with a well defined edge to it. Make sure there are no stray threads that could tangle it in your printer.
Step 5: Feed Into Printer
You are now ready to feed the fabric covered piece of card into your printer. Depending on what you're printing, you may need to increase the contrast and the brightness of a design, to compensate for the light fabric. You may want to experiment with which print setting produces the best results - such as 'plain paper' or 'photo paper'.
Carefully feed the fabric cover card in, and watch it as it feeds through the printer, to make sure it doesn't jam.
Step 6:
The finished fabric! As you can see, you can print on highly detailed images.
Depending on the ink you use in your printer, the images may or may not come off when you wash it. I use Lyson inks in my printer, so they are fairly robust. It helps if you iron them on the back with a high heat to fix the images.
Happy printing!
If you like would like to print these images, you can find these, and other printable illustrations in my Etsy shop:
https://www.etsy.com/uk/shop/ThreeBearsPrints
A note: I've had a few questions about whether this results in washable fabric. For me, the best solution has been to spray protector (such as you would use on canvas shoes/bags to waterproof them) on them, to repel stains and water. The items I'm making are mainly decorative, so for me, this works well.
  • Fandom Contest
    Fandom Contest
  • Party Challenge
    Party Challenge
  • Classroom Science Contest
12 Discussions
DeeOES
4 years ago on Introduction
Pardon my lack of knowledge but can you use any image or is it a special image produced by a company? I would like to try this with my own drawings. Your results are lovely.
Thank you! I just used a 'normal' illustration I produced in pencil and ink which I scanned in. It's printed at 300 dpi - and I upped the contrast and decreased the brightness of the image slightly using Photoshop - simply to compensate for the whiteness of the fabric.
Maybe I'll give it a whirl and let you know. Keeping in mind zeppomarks' comment, of course, and having a fire extinguisher handy. :o)
Probably better to avoid flimsy or artificial fibres with a laser to allow for the heat.
zeppomarksmugwumpr
Reply 4 years ago on Introduction
I have not personally tried it, but I do have experience with Laser printers which get extremely hot. Respectfully, I believe feeding any kind of fabric through a laser printer could result in fire.
estrelita
4 years ago on Step 6
why is this method better than using wax paper and using soda ash as a fixer. Spray adhesive can't be too good for your printer and cardstock is harder to print in many printers because they don't all have a straight through path.
I originally tried the wax paper method but the fabric kept coming off and getting tangled when I tried it. I just found this to be a more effective method for me and the printer I use (a Canon Pixma) but I can see that it may not be suitable for all printers.
tomatoskins
This turned out looking really well. What do you have planned for you pieces of fabric?
