Programming Arduino Nano Using UNO
10,495
34
14
About: A man of mystery and power, whose power is exceeded only by his mystery.
Hey Guys,
Recently I had just bought a new arduino nano clone (CH340) from ebay for my mini arduino project. After that I I I connected arduino to my pc and installed the drivers but not still working, After few days I just found out how to programme arduino nano using arduino UNO and it was pretty simple too! Follow my steps correctly to gain final results :)
Supplies:
Step 1: Materials Required !
* Arduino NANO
* Arduino UNO
* Bread board
* Jumper cables
Step 2: Connection !
Connect
Uno to Nano
D13 > SCK
D12 > MISO
D11 > MOSI
D10 > RST (reset)
5V > VIN GND >
GND Note :
If your board's operating voltage is 3.3V then use 3.3V.
Step 3: Prepare Arduino IDE !
When wiring is done.
Now we have to do some settings in IDE.
Go to Tools >
Board & select Arduino UNO.
Select the right PORT
And Upload any code :)
The settings is done. Now, open up the sketch you want to upload on your Nano,In Menu, go to Sketch & click on "Upload using Programmer"IDE will compile the sketch & upload it to your Nano. The RX TX leds will blink rapidly on both board, & you will see done uploading. If not, then recheck all the wiring & settings. If you get any problem or you want to give me suggestion, you can write in comment section below. If any error occurs please press reset on nano and even on arduino uno
Happy Programming :)
Step 4: Conclusion !
I wish this Instructables helped you a lot, If it helped you please follow me. If any issue rise please comment below. :)
    • Fandom Contest
      Fandom Contest
    • Arduino Contest 2019
    • Gardening Contest
      Gardening Contest
    14 Discussions
    Ravi ravnang
    4 months ago
    I set the icsp conetion and upload sketch but Arduino showing device signichar
    MidhunL
    1 year ago
    well! could i use a serial monitor?
    of nano?
    grayl
    1 year ago
    I guess I have to ask, if you have a USB cable and can connect to a NANO directly, why use a UNO?
    VictorMNAgrayl
    Reply 1 year ago
    There are two reasons to do this:
    - You cannot connect to the NANO because it has lost the boot loader. So with this technique you can restore it and then work programming with the USB as usual. But this case goes against what you said of "and can connect".
    - You need extra space for your application. The NANO has 32KB of flash, about 2KB of them are for the boot loader. Then your application can be up to 30KB. So if you erase the boot loader you can make applications up to 32KB. But, having sacrificed the boot loader, you need an external programmer, in this case the UNO.
    Baasil Biniyamingrayl
    Reply 1 year ago
    Really you are right, but my ch340 driver is not working or my Arduino nano's port is not working. For those who have similar problems can fix it :)
    Your NANO is damaged, then. Or the problem (most probably) is in your USB Mini cable/connector.
    no my friend i have another nano which is working, the cabel or connecter is working fine :)
