Pwm Driver With 555
2,716
32
5
About: radom diy projects
making a powerfull 12v pwm controler for leds or dc motor
Supplies:
Step 1: Print Pcb
open .pcb file with pcb express
and print it
i use toner transfer method
Step 2: Circuit Diagram
take a look at the circuit diagram
be careful with the polarity every time
better add a fuse at the (+)
this circuit is with N-Channel mosfet and output control the (-)
Step 3: Drill the Holes and Solder the Parts
the parts
  • 1x 555 timer
  • 1x N-channel mosfet (i find it from a broken loptop's motherboard,take a look at mosfet's, you find, datasheet)
  • 2x diodes 1N4148
  • 1x diode 1N4007 (this is not on the pcb i forgot it..you can add it on the motor be careful with the polarity )
  • 1x capasitor 100nf
  • 1x capasitor 1000uF16v
  • 1x resistor 1 k
  • 1x resistor 40 Ohm
  • 1x 50k potentiometer
Step 4: Add the Wires
add all wires, clean the pcb
and test it
Step 5: Paint the Pcb
if you dont have solder mask to protect your circuit paint it with a high temp spray
Step 6: Finish With the Wires
when you finish with the wires add some hot glue at the cables
Step 7: Find or Print a Box for the Circuit
if you have a 3d printer download the .stl files and print it
Step 8: Finish the Project
put all ''thinks'' in the box carefully!!
glue the box cover with instant glue..
Step 9: End
end
now you can drive leds or motors
thanks!!
    • Party Challenge
      Party Challenge
    • Woodworking Contest
      Woodworking Contest
    • Gardening Contest
      Gardening Contest
    5 Discussions
    sanjay117
    Question 6 months ago on Step 2
    Where is circuit diagram??
    buffatron94
    1 year ago
    It doesn't need a resistor on Mosfet's Source Pin for pull down effect?
    andreash79buffatron94
    Reply 1 year ago
    I think
    1. at 555 the output is 0 or 1,when is 1 is like the gain connected to source
    2. if it was an H-Bridge circuit, this resistor it will nessesery!
    and you are right.A resistor must be between Source and Gain
    gm280
    1 year ago
    Very nice layout and design. You can get a can of clear lacquer to spray the circuit board to protest the copper and the components. I do that on my circuits to also keep moisture at bay. And using MOSFETs you can parallel them for more current capability for larger motor control as well. The typical 555 timer sink or sources 200 ma. And using MOSFETs is the best component(s) for that application. But then you need some serious heat sink. Thumbs Up!
    andreash79gm280
    Reply 1 year ago
    thanks!
    yes the clear lacquer it would better
