Quadcopter With Nodemcu and Blynk(Without Flight Controller)
7,653
24
11
Hello guys.!
The search to make drone without a flight controller ends here.
I was kinda making drone for my project which involves survillence.I was surfing net overnight to make it work without the flight controller and it’s was very disappointing that i didn’t one.So i decided to make this instructable so it’s easy for those who will be making drone without flight controller.
Blynk is an open-source IOT platform where one can control the things remotely.(Can be even stated as an universal remote).Check out their webpage to know more.
Thanks to Blynk.!
Nodemcu has been on buzz these days.I have used nodemcu because of it’s ease in programming.One can program it in arduino IDE itself.
Prerequisites:
One needs to know the basic soldering techniques and of Arduino IDE.
Things needed:
1.BLDC motors.(In my case, i have used 2212 1800KV motors of quantity 4)
2.30A ESC-4
3.A drone frame(One can order it online or can make it like this).
4.LIPO Battery(Typically with a charger)(I have used 2200 mAh 11.1V 30C spec battery).
5.Power Distribution Board.
6.Nodemcu
References:
Here are the references i have used:
1.Blynk Docs
2.Nodemcu docs
3.Esp9266WiFi Header functions.
4.BLDC and ESC working, calibration.(Refer youtube).
Time to get started.!
Step 1: Wiring Up the Escs' and BLDCs'
ESCs’ are generally used to control the speed of the motor.The three pins coming out of the ESC are given to the BLDC motors as follows. PWM signal is generated by the nodemcu which will control the speed of the motor.
Aerodynamics to be considered:
The synergistic step for making the drone fly is it’s aerodynamics.
The motors which are opposite to each other has to in the same direction
Two motors which are opposite has to be in same direction(i.e.,ACW),then the other two opposite motors has to be in CW.
Solder properly by taking care of the dynamics.
Step 2: Setting Up the Blynk App
Download the blynk app.One can find it in the Android/ios store. Create Blank account and get your account verified.
Install blynk library to the Arduino IDE.
Add two slider widgets.
One is for motor calibration and the other is for motor control.
Choose one slider and assign the pin as V0 and change the highest value to 255.(For calibration)
Choose another slider and assign the pin as V1 and change the highest value to 255.(To control drone)
One can use the same widget to calibrate and to control the drone.(but not recommended)
Some pictures has been uploaded to show demonstrate.
Step 3: Arduino IDE Code
Check this link out to get the code.
Esp8266 board package has to be installed to Arduino IDE.Follow the uploaded video to add ESP8266 library to the Arduino IDE.
Open the file in Arduino and upload the code by selecting the board in Boards manager as “Nodemcu”.
Step 4: Calibrating the Motors
Caution.!
Please make sure that the propellers are removed while calibrating.An important precaution ‘coz i had very bad experience with ‘em.!?
The motors have to be “callibrated”.It’s more defined like matching up the highest and lowest throttle speed to highest and lowest voltage provided by the mcu.
Once blynk app is properly setup and wiring the esc and BLDC is done,the next step is to calibrate.
After you connect the four escs’ to a power source(typically a lipo battery),the motors will give a beep to calibrate the esc.
Follow the simple steps to calibrate BLDCs’
1.After motor gives a beep,change the slider to the maximum value(In my case it’s 255).
2.The motor detects it and gives second beep for the low throttle.This time move the slider to the lowest value i.e., 0
3.The motor will give beep twice stating that the calibration is done and change the value of the slider to change the speed of the motors.
You are done.!
Step 5: All Done.!✌?
Please make sure that all the motors should have the same speed (i.e.,same RPM) to hover.
Good day all.!
Any queries:
Reach at abinayg@gmail.com
    • Party Challenge
      Party Challenge
    • Gardening Contest
      Gardening Contest
    • Arduino Contest 2019
    11 Discussions
    DanieleT15
    5 months ago
    This instructable is a complete lie and should be removed. It tricks people into thinking it's possible to build a drone/quadcopter without a flight controller. It is simply impossible. The flight controller is responsible for changing the speed of the 4 motors in order to keep it balanced. It does this by rapidly reading a gyro and adjust the motor speeds. Even IF you would add a gyro to this instructable (which it hasn't), it would STILL be a lie, because then the NodeMCU board becomes the flight controller! Stating that the drone would keep hovering just because you have the same RPM of all 4 motors is also false. That would only be true if the drone is 100% symmetric, absolutely no wind etc. It simply does not happen. You can even see that he is using a CC3D flight controller on one of his pictures!
    PacquitoSDanieleT15
    Reply 4 weeks ago
    Yep, it's a scam if you don't have a gyro board. The code is also a full fake of programming :-) But you can use a NodeMCU with multiwii :-)
    Farrukh_
    1 year ago
    i doubt this design, all motors will have different RPM,
    AbinayGFarrukh_
    Reply 9 months ago
    I have coded the NodeMCU with using PID feedback control to balance the drone with the help of Gyroscope(MPU6050)
    DanieleT15AbinayG
    Reply 5 months ago
    If that is true, then the NoceMCU becomes a flight controller!!!
    LanL17
    Question 8 months ago
    can i have the schematic please?
    AbinayGMaker Saga
    Answer 9 months ago
    I apologise for not mentioning about the Gyroscope(MPU6050) i used.!
    PID feedback control with IMU will stabilise the drone.
    AbinayGMaker Saga
    Answer 1 year ago
    The thing is that i haven't fixed any IMU in it.Balance is achieved if the RPM produced by the four motors are same.
    AbinayG
    Tip 1 year ago on Step 1
    Fix the cw and ccw propellers to the respective motors properly
    Swansong
    1 year ago
    That's a neat setup :)
