Quick Start to Nodemcu (ESP8266) on Arduino IDE
609,616
527
87
About: I make hobbyist stuffs and play with electronics follow me to know more https://www.facebook.com/arduinolabviewsolidworks https://twitter.com/learnrobotix
Thanks to the guys those who ported the Esp8266 into Arduino IDE and helping all the arduino users happy to the core. Yes it's been long time since they did and this post is bit later to thanks the good hearted work by the guys out there.
Lets begin with Installing the Esp8266 support for the Arduino and see how to blink an LED ( the hello world in the electronics )
check out the video to know step by step tutorial on how to get started with our favourite chip Esp8266
Firstly open the Arduino IDE
Go to files and click on the preference in the Arduino IDE
copy the below code in the Additional boards Manager
http://arduino.esp8266.com/stable/package_esp8266com_index.json
click OK to close the preference Tab.
After completing the above steps , go to Tools and board, and then select board Manager
Navigate to esp8266 by esp8266 community and install the software for Arduino.
Once all the above process been completed we are read to program our esp8266 with Arduino IDE.
For this example I have used NodeMCU esp8266 and if you are using any other vendor wifi chips or generic wifi module please check with the esp8266 Pin mapping which is very essential to make things works.
The reason why I used D7 pin for this example is , I uploaded the basic blink program that comes with the examples program in the arduino IDE which is connected with 13 pin of arduino. The 13th pin is mapped into D7 pin of NodeMCU.
go to board and select the type of esp8266 you are using. and select the correct COM port to run the program on your esp8266 device.
<p>void setup() {<br>  // initialize digital pin 13 as an output.
  pinMode(13, OUTPUT);
}</p><p>// the loop function runs over and over again forever
void loop() {
  digitalWrite(13, HIGH);   // turn the LED on (HIGH is the voltage level)
  delay(1000);              // wait for a second
  digitalWrite(13, LOW);    // turn the LED off by making the voltage LOW
}</p>
upload the program and see the results.
if you like the above tutorial and if you want try out with cool projects you can also check this link here , that's the amazon book link where you can use that book to make IoT with Esp8266 or Nodemcu, that books gives you basic coverage on how to do simple things and get yourself started with arduino and goes on developing projects like sending data to webserver and creating a webserver, uploading and controlling data from a webpage, how to interface TFT LCD and I2C devices and many more things can find on the link.
Step 1: Control an LED From Web Browser
In this blog, we will see How to "Turn On and Turn Off" an LED that has connected to the Esp8266, the esp8266 has programmed from Arduino IDE to control the LED.
We will connect the Esp8266 to the Wi-Fi router using SSID and password of our Home network Wifi , where the esp8266 connect to our wifi and create a webserver, which can be accessed by looking through the serial Monitor of the Arduino window or you can also log into your Wifi router and check for the list of clients connected to your Wi-Fi router.
Here's a window which explains the step by step procedure to connect the Esp8266 to the Wi-fi server and How to access the Webpage and control the LED connected to the Esp8266
For the above video I have used NodeMcu, you can use any type of Esp8266 to make this thing work in your web browser.
look for the mapping of pins in with your Esp8266 vendor, if the program not working properly for you , the fault will be with the pin mapping functionalities, Here I used the D7 pin which mapped to 13th pin when program from the Arduino IDE.
Connect your Esp8266 to Arduino IDE and Select the correct COM Port and board type and
upload the program.
Note change the SSID to your WiFi Name and password to your Wifi password. if you forget to change it , esp8266 will not connect connect your wifi.
<br>
If everything completed you can turn to your serial monitor and check for the ip address that your devices has connected to . you will presented with an serial monitor that look exactly to the picture below.
Step 2: Control Electrical Devices From User Web Browser Using Esp8266 Nodemcu
Hi, in this tutorial we will see how to control electrical devices like fan, light, etc., to turn on and off using esp8266 from a web browser. if you are bored with a dedicated device controller like an app or an remote which will be available for only one particular device but using this method all the device which support web browsing will be act as a controller for us.
Make sure all the devices are connected to the same router, this example doesn't include a port forwarding function which will not allow us to control the device from outside the home network.
Components that you need for completing this project are very simple, you need to have an esp8266 wifi module and a relay, make sure you buying a 5v relay which very easy to use with esp chips doesn't require external supply too. we can make use of the Vin pin of the nodemcu or if you are using a generic chip, you need to supply an external 5v to the relay.
For this example project I have used only 2 relay circuit, but the actual program wrote for connecting four relay module.
You can check the above video on how this thing works and how to connect your browser to the ip address returned from esp and all the details are included in this video.
Copy the below arduino code and paste into your Arduino IDE and upload the program to your nodemcu or any other esp devices that you are using, make sure to choose the correct port and device name from the board. also don't forget to change the SSID and password to your Wi-fi settings.
This program for the esp8266 wrote to return the status of the device , which will in turn notify us with the device state in the browser which will also make the user to know which device has currently turned on or off.
Copy the above code and complete the process. Share and let others know about this tiny chip which can do dozens of magic.
Step 3: Upload DS18b20 Temperature Sensor Data to Thingspeak From Esp8266 (nodemcu)
Hello all in this tutorial you will know how to use Ds18b20 Temperature data to thingspeak.com, you can follow above fritzing circuit diagram to control the Ds18b20 temperature sensor, This sensor follows one wire protocol which means you can connect many sensors as you want to the single pin and access temperature data calling the sensor by address.
check the video below on how to work with this sensor and also proof of code working .
There is no much work to get work with this sensor, as there are plenty of example library that already available in the internet which anyone can make use and get started to work with this sensor.
Test the below code to know check whether you can get reading from the temperature sensor with ESP8266 or Nodemcu
if you get any error , make sure you have downloaded library for Ds18b20 Temperature sensor.
<iframe style="height: 510px; width: 100%; margin: 10px 0 10px;" allowtransparency="true" src="https://codebender.cc/embed/sketch:243987" frameborder="0"></iframe><br>
copy paste above code to your Arduino IDE and upload to your ESP8266 or Nodemcu if you are not sure about how to do this please check the video about to know how things work, if you don't know yet to search search on this blog for getting started with Esp8266 in Arduino IDE.
below you can see the code for sending temperature data to thingspeak.com from Esp8266 or Nodemcu to do this you need have thingspeak api key which can get easily by registering to the website.
change SSID and password to your router password and also update the Nodemcu api key.
<iframe style="height: 510px; width: 100%; margin: 10px 0 10px;" allowtransparency="true" src="https://codebender.cc/embed/sketch:243988" frameborder="0"></iframe>
11 People Made This Project!
  • Tape Contest
    Tape Contest
  • Trash to Treasure
    Trash to Treasure
  • Arduino Contest 2019
87 Discussions
GianniP6
Question 10 months ago
How do you prevent the ESP8266 from going into sleep/standby mode..? mine controls the garage door via its own web server, but the board goes to sleep after a while forcing me to press the reset button in order to regain connectiity.. thanks in advance..
base1379GianniP6
Answer 4 days ago
Did you figure this out?
Mine disconnects from wifi anywhere between 5 minutes - 15 hours. The only way i can get it to reconnect is to reset.
If i were to guess, maybe there is too much power or time used by the sensors, and then the esp8266 crashes?
GianniP6base1379
Reply 2 days ago
Haven't figured it out yet. I had to postpone this project, but I was leaning towards the strength of the wifi signal falling under a certain threshold, which would cause the board to lose connectivity and go to sleep as a result.
base1379GianniP6
Reply 1 day ago
Thanks for the reply Gianni,
In my case I think it was a coding issue:
In my loop function, i started with a loop to prevent proceeding without a connection:
while (WiFi.status() != WL_CONNECTED)
And my mistake apparently was to do a WiFi.begin inside this loop.
If i remove this WiFi.being line then it reconnects automatically.
So i'm only calling WiFi.begin once in setup now.
En ElH
Question 1 year ago
Hi everyone
Thanks for this instructable. The sketch worked ok but after an hour or less the esp goes off. I tried increasing the leasing time of my router but the ESP keeps going into sleeping mode. Anybody here had the same problem? Is it possible to avoid the EPS to enter into sleeping mode?
Best regards
1 answer
base1379En ElH
Answer 4 days ago
How do you know it is in "sleep" mode?
Mine disconnects and I can't get it to reconnect unless i push the reset button.
I need a way to reconnect it to wifi without manually resetting.
King of Hertz
Question 4 weeks ago
Does anyone know where I can find a data sheet for this if I want to talk directly to the registers?
nyanphyo
Question 1 year ago on Step 1
Connecting to Magesh
not WiFi connected , why pls give me solve
1 answer
DivyeshNnyanphyo
Answer 3 months ago
Change to your own user id and password.
Marvin14
8 months ago
Great work m8. This was really helpful to get me started with the NodeMCU.
nidhisad1
Question 11 months ago
I purchased a NodeMCU Lolin V3. when i try to compile the code from arduino ide i get this error message.
#include <ESP8266WiFi.h>
//#include <data.h>
#include <BlynkSimpleEsp8266.h>
char auth[] = "5c64f9c98d2a4fc583b5c7ccd027dc39";
char ssid[] = "******";
char pass[] = "*******";
void setup()
// Debug console
Serial.begin(9600);
Blynk.begin(auth, ssid, pass);
void loop()
Blynk.run();
please reply as soon as possible
1 answer
MuzammilS12nidhisad1
Answer 10 months ago
whenever ur uploading a program at that tym u have to make sure the com port and node mcu model name
for better clarification open serial monitor which is there on top right hand side
aaloia61
Hello, I just bought a NodeMCU Lolin V3 and I'm trying to use it with Arduino IDE.
I'm trying the very basic Blink example, just to see if everything works but I'm having a compile error:
This is the configuration I set in the IDE:
Arduino:1.8.5 (Windows 10), Board:"NodeMCU 1.0 (ESP-12E Module), 80 MHz, 4M (3M SPIFFS), v2 Lower Memory, Disabled, None, Only Sketch, 115200",COM4
This is the error it gives:
open C:\Users\angel\AppData\Local\Temp\arduino_build_777104\sketch\Blink-MCU-ESP.ino.cpp: Impossible accessing the file. File already in use by another process. Compile error for NodeMCU 1.0 (ESP-12E Module).
I checked the mentioned file exists and I can read it.
Any suggestion please?
thanks
Angelo
DavidH1021
When I upload the program to my esp8266, and open port mapping, all that appears are this:
][⸮⸮⸮2W⸮⸮⸮2
~ld
⸮⸮ ⸮⸮ ⸮⸮ ⸮⸮ ⸮⸮ ⸮⸮ ⸮⸮ ⸮⸮ ⸮⸮ ⸮⸮ ⸮⸮ ⸮⸮ ⸮⸮ ⸮⸮ ⸮⸮ ⸮load 0x4010f000, len 1264, room 16
What happened, and how can I fix it?
Carlosd169DavidH1021
Answer 1 year ago
You have to set the right baud rate, in this case 115200 baud. You have an option to set the baud rate in the serial monitor window. it's a drop down list.
bikram0514
Question 1 year ago
hello,thank you for all details.....can you please share how to connect it with phpmyadmin database?i am trying to make wireless attendence system with rfid...please help me.
email id:bikrammukherjee600@gmail.com
MadukaP
Question 1 year ago
Great tutorial!!!!!! +++
MadukaP
Question 1 year ago on Step 2
Can we control that from the android app??
