Quick and Easy Margherita Pizza
60,130
124
40
About: I was born at a very early age...
One of my favorite summertime meals is this easy to make Margherita pizza. It can be made in just over 20 minutes once you've done it a few times and, with a backyard garden, can be made cheaply and organically.
Step 1: Is It Getting Hot in Here or Is It Just Your Oven?
Preheat your oven to 450 degrees F (or 232 C if you live just about anywhere in the world besides America).
Gather your tools and ingredients. You will need the following:
INGREDIENTS
1Medium sized tomato
6-8 Fresh basil leaves
1 hunk of mozzarella cheese (or you could buy the preshredded, you'll need at least 3/4cup but I suggest a full cup)
1 12" pizza crust (I wimp out and buy the premade kind)
2 to 21/2 tablespoons of Extra Virgin Olive Oil (for a little more flavor try infusing your oil with something like garlic or basil)
White pepper (no set amount, I never use the same amount twice)
TOOLS
1 cutting board
1 vegetable knife
1 pizza cutter
1 cheese grater (only if you have a hunk of cheese, not store bought preshredded)
1 Oven (duh)
Step 2: Lube Job
Next we need to make sure that our dough cooks correctly by adding some olive oil to the surface of the crust. This will also add a bit of flavor to the medley (more or less flavor depending on whether or not you've infused your olive oil with any herbs or spices). Pour anywhere from 2 to 2 1/2 tablespoons of your oil onto the crust. Spread evenly with the back of a spoon, a basting brush, or use my favorite method: your hand.
Step 3: Secret Ingredient (Hint: It's Not Really Secret)
One thing that remains a tradition in the Chandler family is using White Pepper over the standard black pepper or peppercorn melange you see most often. It just tastes better people! I'd recommend using whole peppercorns and grinding them out yourself for full flavor, but the canned stuff will work as well. I will typically put 3 to 4 full twists of the grinder onto the crust for a nice zip that is oddly subtle (for pepper).
Step 4: It Slices! It Dices! Part I
Take your rinsed tomato (I shouldn't have to tell you to rinse your produce) and slice it into your preferred thickness. I usually don't go super thick and I've found that if you make them too thin they will scorch VERY easily. Place your slices on the crust. On a 12"crust I usually will get about six slices on board.
Step 5: It Slices! It Dices! Part II
Now it's time to chop up the basil. Other, more culinarily astute people, will say things like, "Cut your basil into Julienne strips." I say stack three or four of your (rinsed, c'mon use common sense!) basil leaves and cut them three or four times horizontally. Pile up the resultant pieces and run your knife through them a few times in a few different directions. That will get you an easily spreadable pile of basil.
Step 6: CHEESE IT, THE COPS ARE HERE!
Now the best part: CHEESE! I cannot stress enough to you how much better your final product will turn out if you part with a few extra pennies and buy a ball of (sort of) fresh mozzarella. In the end the shredded stuff will turn out fine, save you a step, and cost a little less but your tastebuds will love you for going the extra mile. If you went the fresh(er) route and got a hunk of cheese, now is the time to grate it. Grate to taste, but I'd suggest at least 1/2 a cup just to pull things together. You'll get better results from about 3/4 of a cup and if you want to add lots of flavor and don't care about a small amount of extra calories, throw on a whole cup.
Step 7: Now We Play the Waiting Game...
Place the prepared pizza into your preheated oven for 7 to 8 minutes (or whenever the cheese looks good to you). If you want a slightly softer crust, use a pizza stone in the oven, but if you're a real person and like your crust more towards the crispy side just throw that bad boy right on the middle rack. While you're waiting check out this instructable. I've attached a picture of it just because I think it's cool.
Step 8: Eat, Drink, and Be Merry!
Your Quick, Easy, Cheap, Delicious, Healthy, Awesome Margherita pizza is done! Enjoy it with some friends on the patio or plop down in front of the couch with your significant other for the latest DVD from your Netflix queue, this is the perfect meal for sharing. I like it with some ice cold sweet tea and a little bit of pasta salad.
    • Pie Contest
      Pie Contest
    • Jewelry Challenge
      Jewelry Challenge
    • Fat Challenge
      Fat Challenge
    40 Discussions
    Sunkickeddepotdevoid
    Sweet! I'm a big fan myself. ;-) We just had one the other day with some fresh, homegrown tomatoes. YUM!
    depotdevoidSunkicked
    Here's a picture I took of the results, I used red and yellow tomatoes and fresh basil, all from my garden. The crust came from Little Caesar's where my girlfriend works (the dough is made fresh every day, so it's a pretty good place to get a pizza crust).
    Thanks for sharing the recipe, even my picky daughter liked it!
    ricklow
    8 years ago on Introduction
    That actually doesn't look that hard to make.I'll try it even though I'm more of a "meat" person.:)))
    I could be wrong, but I've worked in pizza places off and on for the last 14 years, most of them in NY, and I've always known a margherita pizza to be sauce based. Dough, plain tomato sauce, basil leaves, cheese. I'm sure what you made is a white pizza, but I'm not sure it qualifies as a margherita. Regardless, good post. Spot on about the white pepper, as well. I like to use both white and black. Personally, I use a stone and have the oven set to "surface of the sun". I dunno about with the pre-made crusts, but with my own dough I find the higher heat brings out the flavor better.
    It's not a white pizza, it's similar at cooked caprese pizza ( fresh tomatoes, mozzarella, and basil over a focaccia(pizza cook only with olive oil and salt))
    The white pizza it's like focaccia but with some rosemary.
    Important: we don't use "cheese", All kind of italian pizza is made with mozzarella.
    Believe it or not, the Italian government has an official recipe for making Margherita Pizza (Naples takes its pizza making fairly seriously). I've included a link to the translated site here.
    TrueItalianSunkicked
    I can give you the very margherita recipe, this is absolutly not right, i don't know what our government said about that but it's false or a wrong traslation XD. This is the right recipe, i find a perfect explaination in english.
    rix_101
    I love the titles for each step. Makes you want to make pizza ^0^
    t.rohner
    10 years ago on Introduction
    Good instructable, but i'd make the dough myself. It's really easy. I make it in my bread maker and let it ferment for at least 4 hours. If you want to speed it up, you could prebake the pizzas. My other idea, freeze the dough and then thaw it in the microwave. Otherwise thawing takes too long. But i don't have a microwave to test it ;-) A buddy will lend me one, if it works well, maybe i buy one. For baking, i'd use the highest setting in the oven and a pizza stone for a crunchy crust. In my electric oven, i set it to 300C or 570F for pizza. (The maximum setting) A neighbor has bought a professional electric pizza oven, he sets it to 350C or 662F. I just made "Flammkuchen" last weekend in my wood fired pizza oven. I measured over 380C or 720F on the oven floor. A simple and delicious recipe for a pizza dough: 500g or 1.1 lb gluten-rich bread flour 300ml or 10 floz water 2 tblsp olive oil 14 g or 0,5 oz or 2 tsp salt 3g or 1/2 tsp active dried yeast (less yeast, longer fermenting time, better taste...) mix, knead and let ferment for 4 hours, if it's too moist after mixing add some more flour until workable. (Flours have different water absorbing properties.) This amount makes 4 medium sized pizzas or flammkuchens.
    Sunkickedt.rohner
    Nearly a year later, I've finally gotten confident about making my own pizza dough. I've been playing around with a whole wheat dough that has turned out fairly well the 3 or 4 times I've made it. Instructable to follow, but I wanted to say thanks for pushing me towards making my own! -Sunkicked
    t.rohnergodsdog
    Why should i do this? Using carbonated sugar water may speed up the leavening a little bit, but only for the price of less taste. The CO2 in the water will be mostly driven out while kneading, if you knead it sufficiently. The added sugar may speed up the leavening, but there is enough free sugar in the flour. In a long fermentation, some starch is reduced to yeast digestible sugar by alpha-amylase present in the flour as well. (We do this conversion in the mash, when brewing beer at around 63C or 145F) At room temperature, this conversion happens rather slow, but it does. You don't want a pizza dough too fluffy. (At least i don't) In this light, there is enough sugar in the flour for a pizza dough. (for most other yeast leavened doughs as well. Less yeast, longer fermentation ---> better taste
    godsdogt.rohner
    I suggested "trying" it. I'm not going to track you down if you don't. And by not "trying" it, you will not waste 30 cents on ingredients and you can remain Mr. Wizard of pizza dough.
    t.rohnergodsdog
    You are right, i shouldn't have written it this way. It's too lecturing. I wanted to be constructive, but i shouldn't have wiped away a method i didn't try. I made many doughs in the last 15 years or so. I found that a long fermentation time enhances taste the most. If a recipe calls for sugar, i don't add it, except it's a sweet dough. Your comments are appreciated, that's what instructables is all about. Sorry again.
    godsdogt.rohner
    No apology required. I'm going to use your recipe this weekend (with the addition of garlic...mmm)
    Sunkickedt.rohner
    Awesome comment! have you made an Instructable for your pizza dough? Also, do you prefer the wood fired pizza or the electric version?
