Quick and Easy Costume Animal Ears
29,927
76
6
It's the last minute, and you need a costume, fast!
This method lets you make a pair of comfy animal ears with a realistic shape in about half an hour.  It's pretty flexible - whether short dainty cat ears or giant swaying bunny ears, they'll come together in a jiffy!  Mine are pretty bright, but switch out the fabrics with fun fur and vinyl for a more realistic look.
Supplies:
Step 1: Materials and Tools
Materials:
  • Wide, strong plastic hairband (to be nice and stable on your head)
  • 8 Cable or Zip ties (these provide the structure)
  • Fabric scraps
Tools:
  • Hot glue gun (and glue sticks)
  • Fabric scissors
  • Strong snips (I used metal snips, but you could also use wire-cutters or really strong scizzors)
Step 2: Design Your Ears & Build the Structure
Decide where on your hairband you want your ears to be - standing straight up, or wide spread to the side.
Mark the middle of the hairband, and add the cable ties symmetrically.  I've only shown making one ear here, but it's a good idea to make both at once, so they match.
The innermost cable tie should stand up at the front, and the others at the back to add depth to the shape of your ears.  Place the last one a little further apart from the others.
Step 3: Shaping
Where you gather your ears will determine their size - use a rubber band to gather them together.
Twist the innermost tie to lay flat on top of the other ones - this will help make a little pocket at the front.
Push and pull the individual ties to settle the shape of your ear.  When you're happy with it, add hot glue to the cable ties below the rubber band.
When it's set, trim the ends off, and add more glue to reinforce the join.
Step 4: Add Outer Fabric
Take an oversized bit of your outer fabric, and glue it to the back of the ear.  Start with the base, then the tip, then either edge, making sure it's securely anchored.  If you're using hot glue, try and make sure it stays neat and tidy, so it doesn't leave hard splodges to marr the shape of your ear.
Once it's fixed to the outside, trim the fabric down to leave a nice wide hem around the structure, then glue that down.  Trim the fabric around the base of the ears.
Step 5: Lining
Nearly there...  Cut your lining fabric slightly larger than your ear, then glue to the two innermost struts first.  Once it's firmly in place, trim it more precisely to fit, and glue it around the edges.
You're done!
Step 6: Enjoy Your Ears!
These ears are really comfortable and stable - I've had them on all day, and completely forgotten they were there.  I hope you like them!
    • Arduino Contest 2019
    • Party Challenge
      Party Challenge
    6 Discussions
    Duskinator.
    4 years ago on Introduction
    I plan to make Raposa Ears for a Drawn To Life Cosplay. Is there any way to make little fur flicks on the edges?
    hegeesh
    5 years ago
    you look beautiful ^_^ and cute
    incensedpanther
    5 years ago
    I'm going to have to share this with my friends who do Cosplay. I have a couple of bronies in mind right off. Thanks it's a great instructable. Your photo's are really helpful.
