Quilted Pillow Case
2,613
68
4
I had a lot of scraps leftover from my herringbone t-shirt quilt and thought it would be fun to use them for a cozy quilt-as-you-go pillow case to go with my warm quilt.
Supplies:
Step 1: Materials
scraps - You could use any kind of scraps, and they can be any size, but you need them to be in strips. Varying widths and lengths are perfect for this project.
rotary cutter with mat and ruler
sewing machine
quilt batting
backing fabric - I used muslin. It isn't going to show, so any piece of fabric will do, but it needs to be the size of the pillow case.
cotton fabric - This fabric will make up the back of your pillow case.
Step 2: Pillow Size and Shape
Cut a piece of batting and backing fabric the size and shape you want your pillow to be.
Pin the batting to the fabric at the corners only.
Step 3: Sewing Pieces
Put your first piece onto the batting in a central (or semi-central) location. You'll be working your way out from this spot. The further from the center you go, the longer your outside strips will need to be. If you mainly have short strips, I would stick as close to center as possible.
Stitch it down with repeating rows. If you rotate the piece, you can do all the stitches at once. For example, stitch left, down, right, down, left, down, etc.
Step 4: Additional Pieces
Each additional piece you add will be stitched once on the reverse side before adding the striped stitching.
Step 5: Progress
Continue to add pieces while covering the raw edges of all the pieces applied before them.
Step 6: Edges and Corners
When you add pieces that overlap the edges, cut off the excess before doing your striped stitches.
When doing the striped stitches, instead of going off the edge, run the stitches along the edge.
Step 7: Progress
As you go along, you'll need longer strips to cover the raw edges of the previous pieces. You can see here how the strips are much longer than the ones I started with.
Step 8: Trim
When you've covered the entire pillow, the edges will be messy.
Trim the edges with a rotary cutter.
Step 9: Stitch Edges
Run a stitch around the edge of the entire pillow.
Step 10: Backing
Cut a piece of fabric for the back of the pillow that is around 6"-8" longer than your pillow's front.
Cut the piece in half.
Press and hem one edge of each piece that will cross the center of the pillow case. The outside edge of the backing pieces can be left raw.
Step 11: Stitch Backing
Pin the backing to the front of the pillow case as shown in the first two images.
Stitch around the edges.
Stitch diagonally across and trim off the corners.
Turn right side out.
Step 12: Add a Pillow
Put your case onto a pillow.
Step 13: Enjoy
Sew Warm Challenge
Runner Up in the
Sew Warm Challenge
Patterns Contest
Third Prize in the
Patterns Contest
    • Woodworking Contest
      Woodworking Contest
    • Classroom Science Contest
    • IoT Challenge
      IoT Challenge
    4 Discussions
    oscardelben
    3 years ago
    These are gorgeous and unique! I love the line details of this pillow. Though the instructions are pretty hard to understand.
    Penolopy Bulnick
    3 years ago
    That is really cute! I love all the sewn lines :)
    Tsanabe
    3 years ago
    Very beautiful! It looks complicated but your instructions make it easy. Great job!
    nanaverm
    3 years ago
    Cool that it matches your quilt! This is almost like a (camera) iris design, something you may want to consider designing if you make one again.
