RC Car
44,610
169
13
I put this RC car together with stuff i found around my school's wood shop. I improvised a lot of the stuff on the car because of the lack of RC car parts.
Step 1: Materials
The parts I used to make this:
  • 3 feet metal rod
  • 2 channel Remote
  • 1 servo (I used 2 but that was because I didn't have a speed controller for the motor)
  • 1 motor (I used 2 motors because the ones I have are weak)
  • Plastic Gears
  • 4 wheels
  • Batteries
  • Receiver for the remote
  • Wood (for the car's body)
  • Nails
  • Hot glue gun
  • Switches
Step 2: Body
for the Body of the car i used 11 in. x 6 in. with a thickness of 1/2 in. of poplar wood then i made this shape on the front of the car, to attach the steering system to it.
Step 3: Steering
I cut 2 T shaped pieces out of poplar wood without touching the thickness of the wood, and drilled a hole in the middle to attach a rod for the wheel.
Then i nailed the T shape to the body and nailed a bigger nail on the opposite side for the steering input.
then i found a flat gear piece and attached it to the up right nail with paperclip tape and hotglue.
then i mounted the servo to on top of a piece of wood, so the servo gear would fit right with the flat gear.
Step 4: Motors
For the motor i used 2 because a single motor didn't have enough power to make the car go forward.
for the wheel axle i used the welding rod and attach it to the body with 2 rectangular small pieces of wood snailed on and drilled in the center, then I lubricated the holes so the welding rod can move with less friction.
I friction fit the motor with a piece on sheet metal screwed on to the back of the body of the car right on top of the axle.
I attached the wheels and the a gear to the axle, and hot glued the gear to the axle to prevent the gear from slipping.
Step 5: Forward Power Control
For the forward power control i made a circuit with the motors and used a servo to act as a switch that i can move with the remote. how this improvised switch works is by opening and closing a circuit with a servo. i made this improvised switch by soldering a the circuit wire to the piece of metal i hot glued to the body of the car, and i took an Allen key and pressed it through the plastic part that moves on the servo and then I took the other circuit wire and soldered it to the Allen key and when the servo moves forward and makes contact with the piece of metal it closes the circuit making the car go forward.
Step 6: Improvements or Things That Would Make This Project Easier.
  • lighter wood and materials, for the body of the car (easy)
  • decent RC motor (easy)
  • actual RC Car parts (easy)
  • thinner wheels, for better turn radius (easy)
  • better wiring, from the batteries to the motors. (hard)
  • brakes, by using reverse braking (easy), or actual separate brake (hard)
  • reverse control (easy)
  • better turn radius (hard)
  • better organization of the RC car components on the car (easy)
    • Remix Contest
      Remix Contest
    • Organization Contest
    • Trash to Treasure
      Trash to Treasure
    13 Discussions
    GuillaumeD123
    Question 4 months ago
    Hey, very cool! How did you make the front wheels turn on the axle while turning? The T shaped pieces are hiding it. Thank you in advance.
    vipindas707
    9 months ago on Step 1
    • 3 feet metal rod
    • 2 channel Remote
    • Plastic Gears
    • 4 wheels
    • Where we can buy these things can you help me?
    pabloF25vipindas707
    Reply 9 months ago
    The receiver, remote, servo, plastic gears and wheels can be bought online or at your local hobby shop. They don't need to be the exact ones I used; just make sure the remote is 2 channel and the servo is of the type that continuously rotates clockwise and anti-clockwise (that servo type was used on the steering mechanism, regular servo was used on the dead man's switch at the back of the car); also make sure the receiver and remote can communicate with each other. The 3 feet metal rod is actually a welding rod (which can be found in most hardware stores), you can use any type of rod as long as it doesn't create a lot of friction with the wood. If your going to attempt to build this car I encourage you to think of ways to make it better; there are a lot improvements that can be made to the original car design.
    pabloF25Rajat Naskar
    Reply 1 year ago
    Using only one motor made the car very slow, so I just added another one.
    HarshitK34
    1 year ago
    Hey , can you explain me, how you made your tires straight while steering as the servo motors straight away turns 180 degrees and that would just make the car go left or right , so how to can make the car move straight after turning.
    pabloF25HarshitK34
    Reply 1 year ago
    I used a different type of servo for the steering. That servo constantly turns in one direction when activated.
    eva1234
    2 years ago
    how much did you spend im on a budget. me and my friend are gunna build it for a science project
    sirfixalot7797
    2 years ago
    wow the steering is ready for Dakar great work..keep it up
    selias33
    2 years ago
    Very cool. Nice work.
    keberts
    2 years ago
    Nice work! Very creative!
    currentcityccwold630
    Reply 2 years ago
    Nice one there. building something similar.. but with lighter wood..
