ROLLING CAN MOTOR
Rolling motor system describes the motion of a rolling wheel, car tire or can. A wheel rolling over a surface have both linear and rotational motions (also called trans- rotational motion).
These systems have vast applications in automobile engine.
MATERIALS NEEDED
  • Iron rod
  • Two cans
  • 15mm PVC pipe
  • Two elbow connectors
  • PVC glue
TOOLS NEEDED
  • Plier
  • Nail
Supplies:
Step 1: Making the Handle and Steering
MATERIALS NEEDED
  • PVC pipe
  • PVC glue
STEPS
  • Arrange the Pipe and connectors as shown in the 2nd picture
  • Glue them together
Step 2: Attaching the Roller Cans
MATERIALS NEEDED
  • Two cans
  • Iron rod
STEPS
  • Make a hole at the other end of the pipe
  • Insert the rod into the first can, then into the pipe and finally through the second can
  • Bend the rods by 1cm at the two ends, leaving a little gap between the can and the point of bending
Step 3: HOW IT WORKS
When the motor is been pushed over a surface through the handle, the rolling cans have both linear and rotational motions (also called trans- rotational motion). This is a great toy for the kids.
Aspirescience....inspiring possibilities
    • Woodworking Contest
      Woodworking Contest
    • Arduino Contest 2019
    • Gardening Contest
      Gardening Contest
    8 Discussions
    longp2000
    4 years ago on Introduction
    If you put a few decent magnets on the inside of the cans you could use this to pick up metal items off of your carpet too.
    Hmmmm thanks!!! Thats very cool. But it could only works for picking up small metal items. Larger metal items overtime would impedes the movement of the cans.
    fred3655
    4 years ago
    My guess is that this is a toy for poor kids?
    aspiresciencefred3655
    Reply 4 years ago on Introduction
    Fred, your guess is incorrect!!! What is important here is the learning content which empowers kids to experience the joy of creating new things irrespective of their background.
    Thanks
    What? Is this simply a pvc pipe with cans nailed onto it or am I missing something? I don't see a motor in any of this.
    Yeah, it's as simple as that!! I didn't use any motor (as in rotor), you simply need to push it. The mechanism/art of the movement is what i described as "motor"!!!
    Thanks
    it must be a conceptual thing, i understand it completely! would have been much more quiet that the "popper" and "lawn mower" my daughter had, she wouldn't push them because of the noise they made. thanks for sharing!
