ROYALTEK REB-4216 GPS MODEM WITH ARDUINO
4,752
41
4
About: Electronics & Telecommunication Engineer
RoyalTek REB-4216 is the GPS module . The module is powered by latest SiR Star IV GSD4e ROM chip & Royaltek proprietary navigation technology that provides you with stable and accurate navigation data. this module can be used in portable navigation system, personal locator, speed camera detector and vehicle locator.
In this instructables I'm going to show how to print the values of longitude & latitude to the Serial monitor using arduino.
Let's Get Started!
Step 1: Components You Need:
1. GPS Module (any gps module is compatible)
2. Arduino UNO (u can use clone or any other like uno)
3. 12v 1Aamp power supply for GPS
4. Arduino data Cable
5. Jumper wires
Step 2: Connections:
Connect TX of GPS to Pin 2 of Arduino.
Connect GND of GPS to GND of Arduino.
Connect power supply to GPS according to power requirement of GPS module.
(In my case I required 12v)
Connect Arduino to your PC.
Step 3: Uploading Code:
Include the TinyGPS library to ArduinoIDE.
Open ArduinoIDE>Go to Sketche> Include library > Select TinyGPS zip File.
Upload GPS_Royaltech.ino to Arduino.
Step 4: Final Output:
Connect power supply to GPS .
Wait for blue led to start blinking,
Open Serial monitor set baud rate 4800.
    • Tape Contest
      Tape Contest
    • Arduino Contest 2019
    • Trash to Treasure
      Trash to Treasure
    4 Discussions
    ajinkya_dalvi
    Question 9 months ago
    Hello!! I bought this same GSP module. Connected 3.3v power supply from arduino. The BLUE led on board is not at all blinking. Does it have to be powered by 12v 1A or 3.3v from arduino is fare enough? Also tell me the reason for blue led not blinking.
    Thank you.
    1 answer
    RishabhLajinkya_dalvi
    Answer 9 months ago
    It needs 12v 2amps supply. It may be work with 12v 1amp but it will malfunction. So recommended is 12v 1amp. 3.3v from arduino not needed only connect gnd.
    SameerS16
    Question 1 year ago
    Thanks for the lovely project. I tried following the steps and I was able to see the output on serial monitor. However, it is not showing expected Lat Long info. Is there anything wrong?
    PrasenanP
    Question 1 year ago on Introduction
    this gps module how is connect in arduino mega (2560) and sent it's code
