Rain Gutters Out of 3″ PVC Pipe, DIY How To!
15,796
23
10
About: There is nothing I love more then making something new and usable again that someone else would have thrown out or torn down! And there's no reason to buy new when you can build it yourself!
This is a post on how I created gutters for my house using PVC pipe! So, quite awhile ago, I stumbled on to the coolest thing online: Rain gutters made out of 3″ PVC pipe. Since then I cannot find it online ANYWHERE! The only thing I can find online about it is forums of people like me who want to try it and other people telling them to just hire a crew to put up seamless gutters because apparently: we’re all rich. Not that I wouldn’t love to be able to afford seamless gutters!
Initially I was going to just cut the pipe completely in half so one pipe would make two gutters but the more I thought about it the more I realized I wanted a “deeper” gutter then that. I had a buddy come over and give me a hand feeding the pipe through my table saw. It was kind of a pain in the butt and I was glad to have an extra set of hands. I ended up cutting off about 1/3rd of the pipe in one pass.
Supplies:
Step 1: Screwing Your New Gutter Into Place
I used steel screws and went directly into the back INSIDE of the pipe and into the end rafters of my house. I could tell where they were by finding the nail heads on the outside fascia board.
Step 2: Finished Gutters
I am so impressed with them! I’m also pleasantly surprised by how nice they look because with no hangers, no parts, no joints etc. they are totally seamless and no one in my family has even noticed that they’re there lol They work great and I think this is a great alternative to other gutters.
    • Party Challenge
      Party Challenge
    • Classroom Science Contest
    10 Discussions
    a1d2
    11 months ago
    Couldn't ends and fittings just be made from standard 3" PVC fittings? Also a air ,right angled socket wrench would drive the support screws with ease if used with care.
    GrandmasHouseDIYa1d2
    Reply 11 months ago
    Absolutely, what's great about all the fittings with PVC it would be easy to make the corner and create full down spouts too!
    nocaresmap
    Tip 1 year ago on Step 2
    In my wife's village near Madang, Papua New Guinea, they always use PVC pipe for guttering on corrugated iron roofs. They cut a narrow slit along the length of the pipe just wide enough for the corrugations to fit inside the pipe. The narrow strip is then cut into lengths and used to strap the gutter in position. Among other advantages of this type of guttering is that leaves and other debris tent to flow over the top of the guttering rather than fill and clog it, as usually happens with most other types of gutter. No gutter guard needed!
    gm280
    1 year ago
    You could have used either Lacquer Thinner or Acetone to simple wipe those marking off instantly. Could have saved you some sanding time. Now you need to work on end caps and down spouts. Otherwise the water pouring out the ends will dig into the ground making some pits.
    onlyHischildgm280
    Reply 1 year ago
    Downspout those babies into a rain barrel!!!
    mkrobert
    1 year ago
    Just a question. How do you keep the water from backing up into the valley where the two roof lines meet? We removed our gutters because the water backed up into the valley and entered the walls causing much damage, even though they were installed on a grade away from the house and toward the downspouts. There was a diverter at the intersection where the two roof lines and the valley connected so that the water would go equally towards both gutters and not back up into the valley, but it was an epic fail. We have the same problem that you have with the flower beds. As I write this the rain is 'drilling' a hole to China where the valley ends. Southeast Louisiana....need I say more? We have web feet for a reason down here.
    GrandmasHouseDIYmkrobert
    Reply 1 year ago
    Hi there! So far we've had a couple of serious rain storms and haven't noticed any problems because when the garters get full they just run over. I'm wondering in trouble areas like this where you live (I know up here in northern MN we don't see anything like the storms that you guys do!) if you made the gutters a lot more shallow. So instead of cutting off 1/4 of the pipe like we did instead cut it completely in half making a much more shallow gutter that would overflow a lot quicker?
    mkrobertGrandmasHouseDIY
    Reply 1 year ago
    I'm not sure. I will definitely have to test it out, though. Thanks for the response.
