Rainbow Mountain Fossil Puzzle
2,714
30
7
About: We celebrate creativity on the southern Oregon coast at our store, the Electric Hospital, and outdoors where we enjoy the wonders. We might be sewing with a long arm robotic quilting machine in the morning a...
Half sheet of 1/2" marine grade birch plywood. Or other thin wood.
1" Dowel 10"
3/16 Dowel 1 1/2" Or chop stick
Wood Glue
Dozen 3/4" self tapping wood screws
Tools
Sabre saw
Screw driver
Bench Sander
Scroll saw
Supplies:
Step 1: Step 1: Craft a Plan for My Grandson's Puzzle.
My two year old grand son had a love of puzzles. I wanted an accurate geology puzzle where the lower sediments in the mountain would be the older fossils you would find. To make it easy for a toddler I wanted it color coded. The color code would be the colors of refracted light with the longer wave lengths being the longer pieces of wood.
That was the premise and the hardest part. I went to his Great Grandpa Cal and we went through his geology books looking for fossil images that I could change into puzzles. I chose to use a trilobite, ammonite, plesiosaurus, tyrannosaurus, shark, insect, fish and rabbit to represent the time periods. The rabbit was to represent mammals and the top of the mountain was capped with white snow. White was also the color of all the lights before being refracted.
Step 2: Step 2: Cut Out 18 Plywood Circles.
I started with a series of 9 sizes of circles I found around the house; a pizza dish, dinner plate, salad plate, bowl, saucer, etc. Each of the 9 circles was marked on a sheet of plywood and two sheets were screwed together with short screws. The screws were to hold the plywood together so I could cut 9 circles two layers thick. I cut them out with a sabre saw then smoothed the edges on a belt sander. After the twin circles were the same size they were separated. One side was to be the base for the puzzle and one the perimeter.
Step 3: Step 3: Design Puzzle Pieces on Paper.
Using a copy machine I changed the size of the fossils to fit on the boards. The outline of the fossil was cut out. On the back side of the paper I drew three segments for each puzzle that would be easy to lock together. None of the parts were to be similar in shape so a toddler would not be easily confused. This paper cut out was attached in the center of the board with clear packing tape.
Step 4: Step 4: Cut Out Puzzle Pieces.
Using a scroll saw with a spiral blade cut the pieces out. The plastic packing tape melts and lubricates the blade. I can't take credit for that clever idea I read it in a book on puzzle making.Animal Puzzles for the Scroll Saw by Judy and Dave Peterson. I used a vacuum cleaner on blow to keep the dust away from the line I was cutting.
Step 5: Step 5: Glue Perimeter of the Fossils to the Backing Board.
After the pieces were cut and sanded the perimeter of the fossils were glued to the backing boards. I was careful to not get glue in the center where the puzzle pieces would fit. The boards were all stacked from largest to smallest with the tops butted together.
Step 6: Step 6: Drill Hole for Storage Dowel.
An 1/8 inch pilot hole was drilled through each puzzle an inch and a half from the top edge. The bit only needed to be long enough to drill into the board below it to mark where the one inch holes would be drilled with a butterfly bit. To reduce splintering the butterfly bit was used on both sides of the boards such that the holes met in the middle.
Step 7: Step 7: Storage Dowel and Cover.
A 1" dowel was rounded and a 3/16" hole drilled near the end. A 3/16" dowel was glued in the end like a T. This was to make it possible to transport and not have all the pieces separate. The final small disc was not a puzzle it was only to cover up the rabbit so no loose pieces would be exposed.
Step 8: Step 8: Painting and Staining.
The painting was done with diluted acrylics as a wash to let the wood
grain show. The two white boards had to use non diluted paint as the white wash was not pretty. Both the edges and the back were stained at least three times. When dry the back sides of the puzzle pieces were sanded to make it obvious they were upside down if they did not have any stain. Every surface was then sprayed with clear spray to seal the wood.
The puzzle was a huge success and the fossils are fun to make frighting shadows with.
First Time Author Challenge
First Prize in the
    • Gardening Contest
      Gardening Contest
    • Fandom Contest
      Fandom Contest
    • Classroom Science Contest
    7 Discussions
    Dr. JoeNYCitySlicker
    Reply 4 years ago
    Thank you for the nice comment. I am new to this and have just figured out how to reply. Perhaps that could be an instructable.
    seamster
    4 years ago on Introduction
    Very nicely done! I love handmade wooden toys like this. I've got a few I'm working on right now in fact for Christmas presents. Thanks for sharing this!
