Raspberry Pi: Completely Wireless IP Camera. Solar Battery Pack, WiFi, Logitech Camera, Raspbian
212,888
271
29
This is one of the first projects I did with my Raspberry Pi. I wanted to see if I could make a completely wireless web cam and set it to stream over the internet. Below are the steps and items I used.
All items except for the Raspberry Pi were purchased from ebay.com
Raspberry Pi Model B 512MB RAM
5000mAh Solar Powered External Battery Dual USB For iPad/Mobile Phone/Tablet PC
802.11n/g/b 150Mbps Mini USB WiFi Wireless Adapter Network LAN Card w/Antenna
Raspberry Pi Case Raspi Enclosure Box with GPIO Access and Logo (optional)
Logitech QuickCam for Notebooks Deluxe Laptop Webcam (Other web cams may work)
The first thing you want to do is get the Raspian Wheezy Image from here. Once you install it and boot up, you’ll come to a configuration screen.
Go to Expand_Rootfs to allow the operating system to use the entire SD card.
Go to SSH and Enable it. This will allow you to remotely shell into the OS to make configuration changes and get updates.
Save changes and reboot the Raspberry Pi.
Once booted up, you will want to download updates.
sudo apt-get update
This can take sometime to complete.
sudo apt-get upgrade
Type Y for yes and wait for the updates to download and install.
Next we want to setup the WiFi adapter. Shutdown the RPi with “sudo shutdown now” and plug in your WiFi adapter.
When booted up login and then type: sudo nano /etc/network/interfaces
We want to give the Raspberry Pi a static IP address so that we can access it remotely. Below is an example of my configuration. Yours may vary. I set the Ethernet port and the WiFi to the same IP address so that I can access it from the same IP even if it is connected via Ethernet or WiFi.
auto lo
iface lo inet loopback
iface eth0 inet static
address 192.168.0.85
netmask 255.255.255.0
broadcast 192.168.0.255
gateway 192.168.0.1
auto wlan0
allow-hotplug wlan0
iface wlan0 inet static
gateway 192.168.0.1
wpa-ssid “yourSSID”
wpa-psk “yourPASSPHRASE”
Save your changes using Ctrl-O and shutdown the device.
Unplug the Ethernet cable.
You should see your static IP on the verbose screen “My IP address is xxx.xxx.xxx.xxx”
Verify that you are connected to the internet by typing: sudo ping -c 3 google.com
From this point on, I do the rest of the setup through SSH and PuTTy on a Windows machine.
Log into your RPi via PuTTy using the Pi’s static IP address.
Plug in your webcam.
Next we need to install the “motion” service. This is a package that contains everything you need to stream your cam over the internet and view it from any browser.
sudo apt-get install motion
Once the installation has completed we need to start the service.
sudo services motion start
If your web cam has a light on it, you should see it light up.
Now lets configure the motion software.
sudo nano /etc/motion/motion.conf
In here there are a few basic changes that you need to perform:
Daemon = OFF to ON
webcam_localhost = ON to OFF
webcam_port = desired port number or 8088
control_port = desired port number or 8089
To ensure that the motion service will actually start as a daemon we need to change another configuration setting, so enter the following:
sudo nano /etc/default/motion
Then change the value “start_motion_daemon=no” to “yes”
sudo service motion restart
You can now open up a browser from another computer on the same network and go to: http://192.168.0.85:8088 to view your web cam.
You can remotely control the web cam settings by going to http://192.168.0.85:8089.
Power off the RPi, hook up the battery pack and turn it on. You should now only have the WiFi adapter and web cam plugged into the usb ports. Try viewing the cam from a web browser and walk around your house or even outside.
You will need to enable port forwarding on your home broadband router to the Raspberry PI on port 8088, that will mean you can access the web cam from anywhere in the world. You can also sign up with a service like www.dyndns.org.
    • Classroom Science Contest
    • Woodworking Contest
      Woodworking Contest
    • Fandom Contest
      Fandom Contest
    29 Discussions
    richardnml
    2 years ago
    have you updated this design?
    AdrieSentosa
    3 years ago
    sudo modprobe bcm2835-v4l2
    hope this code help someone to access the camera
    LudgerB
    3 years ago
    Habe meinen PI3 nach dieser Anleitung installiert. Wenn ich motion im Terminal starte werden auch Bilder der Kamera als jpg abgelegt.
    Wenn ich allerdings über die IP zugreifen will erhalte ich keinen Zugriff. Selbst lokal funktioniert es nicht. http://localhost:8080 führt zu der Fehlemeldung :
    Die Webseite auf http://localhost:8080/ ist möglicherweise unereichbar, die genaue Fehlermeldung war
    Verbindung ist gescheitert. Verbindungsaufbau abgelehnt.
    Sie könnte vorübergehend nicht erreichbar sein oder zu einer anderen Adresse umgezogen sei.
    Von einem PC im gleichen Netz kommt auch keine Verbindung zustande. Der PI ist jedoch errrecibar. sftp - Verbindung funktioniert.
    Hat jemand eine Idee ?
    MathewB14
    3 years ago
    Hi there.
    I'm looking at setting up a cheap video streamer so when people are like sick/away from school that can still do the school. I would like it to be as cheap as possible.
    Could you do it for under $30 - I don't mind outdated devices as log as I can view on the Internet and has sound too.
    MasonP6
    3 years ago
    Anyone know if I can make this with a raspberry pi 0? (When they come back for sale)
    CédricV2
    3 years ago on Introduction
    Instead of motion you can also use Kerberos.io, it's also open-source and a lot more user friendly to install and configure. You can find more information on the website.
    jpayton
    4 years ago on Introduction
    I would use an old smart phone. The android IP Camera app works great. I have three of them set up. I want to do something like this so I can mount one on a tree for a better view of the front of our house. I have a home server running xeoma that allowes motion sensing, managment, and access to all the cameras.
    lspicerjpayton
    Reply 4 years ago on Introduction
    I do the same as you, only I use Ispy software to access my phones camera's. You could add as many camera's as your computer or server can handle. The link is www.ispyconnect.com it works only on Windows machines 32 and 64 bit. The best thing about this software is you can use any type of camera. IP, Network, Local, etc.
    jpaytonlspicer
    ISpy is windows only. Otherwise I like it. Xeoma allowed me to trigger a plugin on my media center to have my security camera pop up when motion is detected.
    JamesW18
    I like what you've suggested. I would like to build your project just for the sake of doing and learning. I would like to build your project with various differences. Such as, (1) I don't want it motion activated, basically always on so to speak like a security camera. (2) I will use the RPI "B" with the Pi Camera.
    This is my idea, I want to place the pi w/camera inside a waterproof container near my pond about 100 yds from my deck. While on my deck, I would like to wake the Pi similar to wake on lan, login to the Pi, turn on the camera, view for however long the battery will support and then shutdown. Please if you can, point me in the correct direction. I'm not a noob and not a skilled tech person.
    rjwarpathJamesW18
    Id suggest something like http://www.amazon.com/HooToo%C2%AE-HT-IP212P-Outdoor-Wireless-Surveillance/dp/B00PQBTAAE/ref=pd_sim_sbs_p_2?ie=UTF8&refRID=1014XFTXQXBT1D8V8YD0 It has all of the features that you mentioned. Configurable via web browser.
    catslover32
    5 years ago on Introduction
    Worked, but then dropped after a few seconds when looked at in firefox.
    aoiivier
    5 years ago
    Hey Ryan,
    I sent you a private message. Old friend hoping to catch up!
    -Amanda
    rjwarpath
    This project is not a substitute for network security cameras. This is just a simple project that you can do with your Raspberry Pi.
    If you are looking for a cheap security camera solution, I would suggest investing in a few wireless network cameras. Each camera has its own IP address and web interface. You can even view multiple cameras through one web interface. There are also several apps available for Android and iOS for viewing the cameras.
    You can connect the Raspberry Pi to a HDTV to view the cameras. Simply enable the desktop manager or (startx), then open a web browser and go to your network cameras web interface. You can also do the same thing with an old computer, instead of using a RaspPi connected to an always on monitor.
    NFAZ10
    5 years ago
    I set up all the software got the IP and port working remotely. The realized that the RPi camera module is not supported. How can I enable this to work with motion
    shrutin111
    Hey
    I am planning to do something similar to this for my project.But I have to use the WAT-902H3 Supreme camera for video capture. I will have to use an adapter for video input. Can you explain me the hardware setup for your project...that might help me in my project.
    Thanks
    synaps3
    Awesome build. Planning on using this for people i know on a farm that need it badly. thanks!
    just wanted to know if there is a way of viewing more that one system at a time, say if you have 4 raspberry pi's around?
    rjwarpathsynaps3
    Reply 5 years ago on Introduction
    Yes. Kinda of messy, but.... You can view more then one cam at a time with a custom html page. Lets say you have 4 Raspberrypi's....
    Create a html web page with 4 iframes. Each iframe source will point to one of the raspberrypi webcam url's (http://192.168.0.85:8088). You will need to set each RaspPi to different IP addresses and port numbers. Port forward the IP's and Port numbers in order to acess the cams over the internet.
    Web page example code.
    Create a single html page (mycams.htm) and add the following to get started.
    iframe src="http://192.168.0.85:8088" style="width:400px; height:400px; border:none; float:left;
    iframe src="http://192.168.0.86:8089" style="width:400px; height:400px; border:none;float:right;
    iframe src="http://192.168.0.87:8090" style="width:400px; height:400px; border:none; float:left;
    iframe src="http://192.168.0.88:8091" style="width:400px; height:400px; border:none; float:right;
    I can not figure out to add html code in the comment with out it disappearing. You can google search iframes or visit w3schools.org
    You can also purchase Wireless WiFi IP Network Cameras from Amazon/Ebay. They can do a lot more then the RaspPi such as remote control, pan, tilt, record, audio. A good model is Foscam Indoor Wireless WIFI IP Network Camera Pan/Tilt Security Webcam
