Raspberry Pi Controlled Irrigation System
68,472
414
67
About: For my day job I write K-12 STEM projects for www.sciencebuddies.org. In my spare time I write Instructables.
Every spring my wife gets really ambitious and plants a big vegetable garden. As the summer drags on, ambition turns to laziness and unfortunately many of the plants die a slow, withering death from neglect due to lack of weeding and watering (except for the tomato plants, which grow like mutants in our climate even if you neglect them...so every August we wind up with 10,000 tomatoes and no other vegetables).
While I can't automate some maintenance tasks like weeding*, I can certainly automate the watering and I figure that will give our poor plants a better chance at survival. You can buy all sorts of fancy programmable hose, irrigation, and water timers (not sure about the difference between those three terms, but that's how Lowe's has them listed) if you want to automatically water your garden. But, in the true spirit of Instructables...where's the fun in buying one when you could build it yourself? Enter the Raspberry Pi-Controlled Irrigation System. A quick search on Instructables shows that I'm not the first one to do this, but I think my project will take a unique approach. I really didn't want to deal with calibrating or cleaning a soil moisture sensor. I also don't care about being super picky about maintaining an optimal soil moisture level. The bar is set pretty low here - I just want to keep the plants alive. If we're watering the plants by hand, we roughly follow a rule of "Did it rain yesterday? If not, water the plants." So, why not automate that with a Raspberry Pi? Use a weather API to answer "did it rain yesterday?" and then the GPIO pins to control a solenoid valve to water the garden. That's what this Instructable will show you how to do, including the electronics, programming, and plumbing. The advantage of this approach is that it's flexible and easy to expand - for example, if I want to decide how long to water based on how much it rained, water based on the future forecast, or water in multiple short intervals throughout the day, that just requires changing a few lines of code.
Please note that this is not a "how to use a Raspberry Pi" Instructable. If this is your very first time using a Raspberry Pi, there are a TON of getting started with Raspberry Pi projects out there - please check those out first if you need answers to things like "how do I install the OS?" or "what type of power supply do I need?"
Ready to get started? Move on to the next step for a full materials list!
*Consider that a challenge. Someone needs to do a computer vision/robotics project that uses a camera to identify weeds and a robotic arm to remove them.
Note on contest entries:
  • Sensors Contest: "If it’s got an input and an output, it’s fair game." - I hope that means the Weather Underground API counts as a sensor, even though I'm not using my own local rainfall sensor.
  • Urban Farming Contest: OK, so I'm not exactly doing this on the rooftop of an apartment building, but you should be able to do this project regardless of your location (and this project is sort of a DIY version of the grand prize of that contest anyway)
  • Home Hacks Contest: I certainly hope this is making a regular household task faster and easier, so this one seems like a good fit!
Step 1: Materials
I got most of the parts for this project at SparkFun, Jameco, and Lowe's. I'll do my best to link the exact parts I used, but you can make reasonable substitutions and it should still work (e.g. you could use a different model Raspberry Pi, or you could do the whole thing with 1" PVC pipe instead of 3/4", provided you get all the right adapters). Note that the exact quantity of piping and types of adapters you need will depend on things like the size of your garden and whether you also want to have a regular hose connected, so you will need to take some measurements and plan your layout before you make a trip to the hardware store (see next step).
Update: thanks to many people on Reddit, Hackaday, and in the comments here for feedback on the electronics and plumbing. The biggest point seems to be that my original circuit was missing a flyback diode across the relay coil, so I've updated the instructions to include that. I've received other comments about including a current-limiting resistor on the RPi's GPIO pin, a pull-down resistor on the MOSFET gate, an RC snubber in parallel with the solenoid valve, and to use poly tubing instead of PVC, but I'll leave those changes up to the individual. If you have questions or advice on any of those points, please leave a comment.
Electronics
  • Raspberry Pi 3. Used because it has built-in WiFi, but you could do this with an earlier model.
  • 5.25V, 2.4A micro-USB power supply. Recommended for the RPi3, older models do not require as much current.
  • Micro SD card with adapter. 8GB recommended, newer versions of Raspbian Jessie don't seem to fit on 4GB cards (unless you plan to install the lite version and only run headless).
  • Relay. I debated using a solid-state AC relay, but this mechanical relay is rated for 100,000 operations at max electrical load - we are well below that limit if you're only watering a couple times a day.
  • N-channel MOSFET. Required because the RPi's GPIO pins cannot drive the relay coil directly.
  • 2-pin screw terminals (2)
  • Protoboard or breadboard of your choice
  • Green LED (3), used as status indicators
  • Rectifier diode
  • Male/female jumper wires, for connecting to Raspberry Pi GPIO pins
  • 22 AWG solid hookup wire, for making connections on protoboard
  • Female header pins
  • 220 ohm resistor (3)
  • 20 AWG stranded hookup wire, for connecting solenoid valve (note that you may need thicker wire if you need to run the wires really far, consult a chart like this to determine what you need)
  • 24 VAC 1500mA AC to AC wall adapter. Important: make sure the rating of this adapter matches the requirements of the solenoid valve you purchase! (some valves are DC)
  • Optional: monitor for Raspberry Pi. I found a monitor useful for setup and debugging, but once it's working you should be able to run the RPi headless (without a monitor). See instructions for connecting to the RPi remotely via VNC or SSH if you do not have a monitor.
  • Project box (small cardboard box or plastic container)
Plumbing (note: NPT = National Pipe Thread, MHT/FHT = Male/Female Hose Thread)
Tools
  • Hacksaw or miter saw to cut PVC pipe
  • Shovel, hoe, or trenching spade etc. to dig trenches for pipe
  • Wire strippers
  • Soldering iron
    Step 2: System Diagram and Planning
    Confused about how all those parts fit together after reading the materials list? Here's an exploded diagram of the entire plumbing system (more details on the electronics in a later step). The exact dimensions and orientations will depend on the layout of your garden and relative location of the hose faucet. You should definitely plan your layout in advance and do a "dry run" (cut straight pieces to length, lay out all the pieces of piping in their approximate locations to make sure they'll fit). Mistakes in this project can be hard to undo - you don't want to start haphazardly digging holes in your yard and cementing pieces of pipe together only to find out halfway through that things don't fit together right.
    A couple important notes:
    • Pay attention to the difference between NPT (national pipe thread) and MHT (male hose thread) adapters. They look similar at first glance, but the threads aren't compatible. NPT adapters are used to connect to the solenoid valve and PVC union. MHT adapters are used to connect to the hose faucet and soaker hoses.
    • The entire section in the dotted red box (between the faucet and the PVC union) can be disconnected and brought inside during the winter. This prevents any damage to the solenoid valve if leftover water inside it freezes. I believe the standard approach is just to bury the valve below the frost line, but I wanted easy access to the valve in case something went wrong (this being my first attempt at a DIY irrigation system) or I wanted to make changes to the future. If you just want the valve permanently installed, you can get away without the union and quick connector.
    • Make sure you install a drain valve at the lowest point in the system! Again, this is so you can drain out all the water and prevent damage from water freezing in the pipes over the winter. I forgot to do this at first so had to dig up and cut a section of pipe to add a T-connector for the drain.
    • "Call before you dig" - you might have seen this phrase on little flags or utility boxes around your neighborhood. If there are any underground utility lines (gas, electric, water etc.) in your yard, make sure you know where they are and avoid them. If in doubt, call the utility company to be safe and they will mark the lines for you.
    • I recommend using an indoor outlet for the 24VAC adapter, as it is not rated for outdoor use. I ran the wires through a window. If you must use an outdoor outlet, make sure to use an appropriate weather-rated adapter.
    Step 3: Dig Trenches
    Dig trenches where you'll need sections of underground pipe. Note that there is probably some rule of thumb about how deep these trenches should be, and I didn't follow it. My trenches are only a few inches deep, just enough to bury the pipes and cover them with some soil. If that's a terrible idea, please let me know in the comments and I'll update this step.
    Update: someone already pointed out that you risk cracking the pipes when you step on them if they're not buried deep enough. So, bury your pipes deeper than pictured here.
    Step 4: Lay Pipe
    Follow the instructions on the PVC primer/cement to lay out the sections of pipe and various slip connectors. These sections should be terminated with slip-MHT adapters and quick connectors for the soaker hoses (refer back to diagram in step 2). Don't forget the drain valve!
    Step 5: Put Solenoid Valve in Plastic Box
    • Screw NPT-slip adapters into both ends of the solenoid valve.
    • Drill two 1" holes opposite each other in the sides of your plastic box (note that 3/4" PVC pipe refers to the inner diameter, the outer diameter is 1").
    • Push straight segments of PVC pipe through the holes and connect them to the slip adapters inside the box. Remember to use PVC primer/cement to seal the joints.
    • Use silicone adhesive to seal around the perimeter of the holes you drilled.
    • Important: drill a few small drain holes in the bottom of the box. I found out this was necessary when I realized I had a few small leaks because I didn't tighten the adapters enough.
    Step 6: Connect Solenoid Valve to Rest of System
    This is the most complicated plumbing step in terms of adapters and valves. Each part is labeled in the photo above (I disconnected the valve from the rest of the system so I could get a clear photo), but you can also refer back to the diagram in step 2. It might be easier to assemble this segment inside or on a workbench, then take it outside to connect it.
    Important: Make sure you get the flow direction of the check valve correct! The valve has an arrow on it that indicates flow direction. This arrow should point towards the solenoid valve (to the right in the photo above). A check-valve is a one-way valve that will prevent dirty water from flowing backwards into your house, if for some reason the pipes in your house lose pressure. I'm not 100% sure if this is necessary (I've never seen a check valve installed on a regular garden hose, which can have dirty water sitting in it), but after some Googling about sprinkler systems, I figured better safe than sorry.
    Step 7: Attach Solenoid Valve Wires
    • Cut two segments of stranded 20 AWG hookup wire (length depends on how far you need to run the wires into your house).
    • Drill small holes in the sides of the plastic box and thread the wires through.
    • Connect them to the solenoid valve wires with waterproof wire connectors.
    • Use silicone to seal around the holes.
    • Run the wires into your house to wherever you plan on having the Raspberry Pi set up. I poked a tiny hole in a screen and threaded them in through a window. You will connect these wires to your circuit in the next step.
    Step 8: Check for Leaks!
    Before you go any farther, you probably want to check your plumbing for leaks. Luckily you can do this before you even make the circuit or hook up the Raspberry Pi. Take the two solenoid valve wires you just ran inside, and twist them directly to the two wires from the 24VAC adapter (note: if your adapter ends in a barrel plug, cut it off then separate and strip the wires). This will open the valve and water should flow through your pipes. If you can't hear water flowing, check that you've opened any other necessary valves, like the hose faucet and internal shutoff for the pipe.
    Hopefully you don't have any leaks at your cemented joints, or you might have to cut the pipe and re-do the joints. I had a few leaks at threaded joints, particularly the union, that required tightening. Note that you can tolerate slow leaks downstream of the solenoid valve, because those areas will only be pressurized when the valve is open. However, you really do not want leaks upstream of the solenoid valve (between the hose faucet and solenoid valve), because those will be pressurized all the time and will leak continuously.
    Finally: I'm not sure if I'm violating some rule about mixing plastic and metal threads, and if that could contribute to leaks. I didn't have much of a choice because I had to get from a metal hose faucet to plastic PVC somehow. If you have any input on that point, please leave a comment.
    Step 9: Circuit
    The images above show a breadboard diagram and schematic of the circuit. This should be clear to assemble based on the diagrams, but leave a comment if you have questions. I recommend testing everything on a solderless breadboard (see next step) before you finalize the circuit on protoboard.
    Here's how it works:
    • A relay controls the 24VAC power to the solenoid valve.
    • The relay coil requires 5V and the Raspberry Pi's GPIO pins are only 3.3V. So, the Raspberry Pi drives a MOSFET which turns the relay coil on and off, which then turns the solenoid valve on and off. By default, when the GPIO pin is low, the relay is open so the valve is closed (water does not flow). When the GPIO pin goes high, the relay closes, and the valve will open (water will flow).
    • I added a couple status LEDs to use as indicators. One is connected directly to the RPi's 3.3V supply, so you know your circuit is getting power. Another will be turned on when the solenoid valve is open, and the third is in there just in case I think of something else to use it for.
    Note that Fritzing did not have a relay that matches the pinout of this SparkFun part. I was too lazy to make a new Fritzing part so I just edited the breadboard diagram in Inkscape, which is why the relay and wires connected to it look a little different. If you feel like making a new Fritzing part (which SparkFun has a tutorial on), let me know and I can update the Fritzing file.
    Also note that I forgot to include a flyback diode across the relay coil initially, so it isn't shown in the picture (but I did update the Fritzing diagrams).
    Finally, not a bad idea to put everything in a project box once you've finished the circuit board. A SparkFun box with some holes poked in the sides for the wires works nicely.
    Step 10: Testing Circuit
    Before you go for full-blown automation, it's a good idea to test the circuit manually. You can do this by using the command line in Python. Please remember that I am assuming you have basic knowledge of how to use a Raspberry Pi at this point. If you find yourself asking questions like "how do I install the operating system?" or "how do I launch Python?", you should check out the many Instructables on getting started with Raspberry Pi or the Raspberry Pi Foundation's official learning resources before you continue.
    To test your circuit, power up your Raspberry Pi (the top LED on your circuit board should light up since it is connected directly to the 3.3V supply), then open Python and enter the following commands:
    import RPi.GPIO as GPIO
    GPIO.setmode(GPOI.BCM)
    GPIO.setup(17,out)
    GPIO.setup(27,out)
    GPIO.setup(22,out)
    This initializes the GPIO pin controls and sets pins 17, 27, and 22 as outputs. Now type
    GPIO.output(27,GPIO.HIGH)
    GPIO.output(22,GPIO.HIGH)
    This should turn on the other two status LEDs. You know things are working so far. Now for the big test (drumroll). Type
    GPIO.output(17,GPIO.HIGH)
    You should hear a "click" as the relay switches position. Go outside and check your solenoid valve. It should be open and water should be flowing. Assuming you checked for and fixed any leaks previously, this means everything is working! Now, go back inside and type
    GPIO.output(17,GPIO.LOW)
    You should hear another "click" from the relay. This turns the valve off. Go back outside and check that the water has stopped.
    Great so far...but you don't want to have to type a bunch of commands every time you want to water your plants. Now it's time to automate the whole thing!
    Warning: do not use GPIO.cleanup(). Through a few hours of irritating troubleshooting, I found that this command (for reasons I still don't fully understand) causes the relay to turn on again, opening the valve. The best explanation I can find came from this Stackexchange thread where a comment states that "The cleanup method sets all the gpios you have used to be inputs and disables the internal pull-ups/downs for those gpios." You need the pin to stay as an output with a low voltage to keep the relay off, so that could cause the problem. I tried adding a 10K pull-down resistor to the MOSFET gate but that didn't work. So, even though it's generally recommended as good practice, I'd avoid using GPIO.cleanup() for this project. Please leave a comment if you have a solution here.
    Step 11: Code
    Now that you have a working circuit and plumbing system, you will install code on your Raspberry Pi that automatically checks the past 24 hours' rainfall and decides whether or not to open the solenoid valve. Then you'll have a hands-free watering experience!
    Credit for the code for this project goes to my friend Mark Veillette. The files and installation instructions are available on his github page: https://github.com/markveillette/rpi_sprinkler. The code is pretty well-commented but here's a general explanation of how it works:
    • run_sprinkler.py is the main file that checks a weather API for the past 24 hours' rainfall, decides whether or not to open the solenoid valve based on the rainfall amount, controls the GPIO pins, and writes the resulting actions to a log file.
    • config is a configuration file where you enter your Weather Underground API key, your city/state, the GPIO pins used by the circuit, and the rain threshold (in inches) for running the irrigation system.
    • run.crontab is a scheduling file where you set when run_sprinkler.py will run, using Cron, a Linux job scheduler. This has the advantage of only running the Python code briefly at certain times of day, rather than leaving a Python script running in an infinite loop 24 hours a day and constantly checking the time (like I did in my Christmast light timer project...whoops). By default it is set to run twice a day at 6am and 6pm, but this is highly customizable. For example, you could set it to only run every Tuesday and Thursday, or only on odd days of the month.
    To get it running, follow the download and installation instructions on Mark's Github page. Be sure to go through the recommended testing commands to make sure everything is working smoothly. Then, let it run for 24 hours, come back to check the log file, and make sure the results are consistent with weather you actually observed (in other words, if it didn't rain, it should have turned on the sprinkler and the log file will say that). If you have any trouble getting the code to run, please post a comment along with any error messages you received and I'll do my best to help out.
    (Note that Mark decided to call it a "sprinkler" - that's more compact than "irrigation system," so whatever. They refer to the same thing.)
    Step 12: Grow!
    Make sure you monitor the entire system for a few days to confirm that it's running smoothly. Check the plumbing for leaks and check the log file to make sure the program's actions are consistent with the weather you observe. Most importantly, check the health of your plants! You don't want to over or under-water, so adjust the timing and duration of the watering in the run.crontab and config files as needed (see the Github page for instructions on making changes to the files). This is where some actual gardening know-how would come in handy, because I'm doing the timing by trial and error - any suggestions for typical watering times using soaker hoses for a vegetable garden in the Northeast would be appreciated.
    Any other questions or suggestions? Don't hesitate to leave a comment - thanks for reading!
    Sensors Contest 2016
    Runner Up in the
    Home Hacks Challenge
    Runner Up in the
      • Organization Contest
      • Build a Tool Contest
      • Trash to Treasure
        Trash to Treasure
      67 Discussions
      ferrinhos123
      Question 4 weeks ago
      Hi Ben,
      Nice work and explanation about the system.
      I want to do something similar to implement in a small flowerbed.
      I see that you developed this in Python but I want to improve some knowledge on C#.
      Do you know if this system can be developed in C#?
      Keep up the good work :)
      Thank you
      1 answer
      Ben Finioferrinhos123
      Answer 4 weeks ago
      Hi - unfortunately I don't have any experience with C# and have no idea about its availability on the RPi. Your best bet to find out would probably be the official Raspberry Pi website and forums. Good luck!
      DaveR222
      Question 2 months ago
      Thank you for a great write up. It was the best one i have found which does not rely on a bucket of water to be refilled but can just use the existing household water supply.
      I have a question regarding the use of the MOSFET.
      You mention:
      "The relay coil requires 5V and the Raspberry Pi's GPIO pins are only 3.3V. So, the Raspberry Pi drives a MOSFET which turns the relay coil on and off, which then turns the solenoid valve on and off"
      The later version raspberry pi do have a 5v output on particular pins (not all GPIO's). In your drawing you have the 5v line connected to the relay too.
      If the relay is getting 5v, why do you need the MOSFET, cant just setting the pin high or low do enough or is this due to the type of relay you used, and the same result could be acheived from one of the "blue 5v relays" from a lot of other tutorials
      Thank you.
      Ben FinioDaveR222
      Answer 2 months ago
      Hi - so my understanding is that all models of the Raspberry Pi do have a 5V power pin available on the pin header, but that pin is *always on* (just like how the ground pins are always at 0V) - you can't turn it on and off like the 3.3V GPIO pins. Therefore, in this case I used the 3.3V GPIO pin to switch a MOSFET to control a higher voltage to the relay. I couldn't turn the 5V on or off directly.
      However, this project is done with an older version of the Pi, so if that has changed with newer models, it would be news to me. If you have seen this done differently in other more recent projects, then that could be OK.
      DaveR222Ben Finio
      Reply 2 months ago
      Ah that makes sense! thank you. Yes i believe that is correct even on the new models too. Appreciate the quick reply.
      Could you have not used a different relay which doesnt require 5v to switch? something like: http://www.circuitbasics.com/setting-up-a-5v-rela... ? reason why im linking that one, is that its what im familiar with (and im only new to basic circuits).
      Thanks Dave
      Ben FinioDaveR222
      Reply 2 months ago
      Dave - at a glance I believe that relay is conceptually similar, it just doesn't require an external MOSFET. There may be some additional stuff built-in to the relay circuit board. It still requires an external 5 volt connection (the "Vcc" pin in the "5V terminal relays and pins" diagram). The "signal" pin is then used to control it, in this case from the Arduino's I/O pins (which use 5V logic) instead of a Raspberry Pi.
      If you're new to basic circuits it might help to clarify something: while the GPIO pins for various boards (Arduino, Raspberry Pi, etc) all operate at certain voltages, there is a limit to how much CURRENT they can supply - usually roughly 20 milliamps, or about enough to light up a single LED. The power pins (which you may hear referred to as other names, like power rails, power buses, etc), which are fixed at a certain voltage and can't be toggled on/off (5V, 3.3V, etc), can generally supply much more current - usually in the hundreds of milliamps.
      Anyway ultimately the answer should be that yes, you should be able to use a relay similar to the blue one in that project, but you will need to make sure the "signal" pin will accept a 3.3V signal from the Raspberry Pi. This tutorial on logic levels might also be helpful - long story short, even for something with 5V logic, 3.3V might still be considered "high" so it could still work:
      https://learn.sparkfun.com/tutorials/logic-levels/...
      Hope that helps!
      jafa5
      3 months ago
      Great post and thanks for sharing. All my parts arrived this week and looking to get this underway over the coming holidays!
      We are currently building the gardens and green house so will be looking to run a series of stations that will need watering at differing times and rates.
      Would you be able to point me in the right direction on how to build this to manage a number of solenoid valves? One for each station (we don't know how many we'll need yet and it'd be great to add the animal troughs into it as well).
      Cheers,
      Liam
      Ben Finiojafa5
      Reply 3 months ago
      Hi - depends on what exactly you mean by "point me in the right direction." Is this your first Raspberry Pi project? The basic idea is that you would just need a bigger circuit board, and you use more GPIO pins to control more solenoid valves (using the relays/MOSFETs, since the GPIO pins can't drive the solenoid valves directly).
      jafa5Ben Finio
      Reply 3 months ago
      Thanks for the far response and yes my first RPI project but I have support from some of the guys at work who are more knowledgeable.
      Excellent, sounds pretty straight forward. I'll post back once I've constricted it :)
      Ben Finiojafa5
      Reply 3 months ago
      Ok - this is a little advanced for a beginner project, so it might be worth going through some more basic tutorials first. There are TONS of "getting started with Raspberry Pi" intros out there - on Instructables, YouTube, the official Raspberry Pi site (raspberrypi.org), etc. Or you can just dive right into it and ask your coworkers for help - depends on how much of it you want to be able to do yourself.
      One caveat - this project is a few years old, and the software for the Raspberry Pi usualy gets updated multiple times per year, so some parts of this might be out of date. I actually wound up moving and had to disassemble the whole thing :-(, so no longer have it up and running.
      jafa5Ben Finio
      Reply 3 months ago
      Thanks Ben, in at the deep end is fine, I'll sink or swim :) The principles all look sound and I've looked at a number of other projects as well so think I'm good. I can call on my mates if needed.
      If I find anything that needed updates I'll post back. I have to build the gardens yet too so plenty of time to learn the ropes.
      Thanks again for the tips and quick responses, much appreciated. Have a great Christmas and I look forward to posting back in the new year!
      anilr50
      8 months ago
      Hi, I am working openweather API instead of wunderground since it is not offering free API keys anymore. I wanted to look for the day forecast and see if it no rain in the day run the sprinkler. I tried replacing wunderground api with openweather but it seem not working. Could you please help me modifying the code?
      Open weather API format: https://api.openweathermap.org/data/2.5/forecast?q=Malvern,us&appid=key
      Ben Finioanilr50
      Reply 8 months ago
      Hi - unfortunately I don't have the time or expertise to help with code troubleshooting. I mostly did the hardware for this project and a friend helped me with the code. You might be able to get more help in the forums here or on the Raspberry Pi website.
      anilr50Ben Finio
      Reply 8 months ago
      Hi Ben, sure I will take care of the coding part. I may reach out to you while assembling the circuit board. Hope that is OK.
      Allen DaveC
      8 months ago
      Hi i'm a student that working like this project . do you have a project like this that uses the soil moisture sensor that will trigger the Solenoid valve to open when plants are needed to be watered and close as if the plant is wet.
      Ben FinioAllen DaveC
      Reply 8 months ago
      I personally don't have one with a soil moisture sensor but if you search on Instructables you should find plenty of other examples.
      Allen DaveCBen Finio
      Reply 8 months ago
      Ah ok thanks for the reply :).
      Sir, How can i retrieve data from the Pi to store in the cloud or any online storage, because i wanted to view data of automated irrigation through website or an app. The answer is much appreciated. I'm working of my final project..
      Reply 8 months ago
      Again, this project does not have cloud storage but if you search Google or Instructables you should be able to find examples.
      beswickat
      9 months ago
      Great effort!
      My Pi is on the internet, so I added a web server to the Pi that hosts a cgi script so I can change the schedule via a web page. Using https://www.w3schools.com/w3css/ examples, I made the web page controller run on a mobile as easily as on my Mac.
      Using run_sprinkler.py to interrogate a weather server is brilliant!
      Allen DaveCbeswickat
      Reply 8 months ago
      Hi sir, can you share it to us how did you do the web page controller run on a mobile.:)
