Raspberry Pi - Data Logging
144,919
615
29
About: A candle loses nothing of its light when lighting another
In this project, we will learn how to logging data from Raspberry Pi using Python and Excel which collect data and save the output of the collection or analysis.
It’s a quite quick project and can be used either on its own or part of something bigger. Check it out >> Integrated Weather Station(IWS).
Step 1: List of Material
For this project, we will be using:
- Raspberry Pi (mine Raspberry Pi 2)
- Flashdrive cost: ~5.00 USD
Step 2: Hardware Connections
In general, the connections are fairly easy. Just connect Flash Drive to Raspberry PI with USB slot and check the name of Flash Drive in Raspberry pi by type "ls /media" in Raspberry Pi terminal, the result should be content Flash Drive's name and you are good to go.
Step 3: Raspberry Pi Programming
Below is the Python code. Edit the code in any way you prefer, run the module , and you should have no problems.
import os
import time
from time import sleep
from datetime import datetime
file = open("/home/pi/data_log.csv", "a")
i=0
if os.stat("/home/pi/data_log.csv").st_size == 0:
file.write("Time,Sensor1,Sensor2,Sensor3,Sensor4,Sensor5\n")
while True:
i=i+1
now = datetime.now()
file.write(str(now)+","+str(i)+","+str(-i)+","+str(i-10)+","+str(i+5)+","+str(i*i)+"\n")
file.flush()
time.sleep(5)<br>file.close()
Step 4: Read Your Data Log
Your file that located in your /home/pi/ or any location you prefer is a comma-separated value(CVS) file. Comma-separated values (CVS) file is a formatted file that stores tabular data (numbers and text) which separated by comma. To open and modify this file, simply double click on it, or open it with Microsoft Excel. You can plot your data with Chart tools that available in Microsoft Excel.
Step 5: Enjoy!
After making sure that everything works correctly, you can take this project into bigger project or integrated it with Real Time Clock (RTC) for accurate logging. Check it out >> Raspberry Pi - Real Time Clock (RTC) !
Power through power bank or a plug and you’re good to go!
    • Trash to Treasure
      Trash to Treasure
    • Arduino Contest 2019
    • Tape Contest
      Tape Contest
    29 Discussions
    bunglesmate
    Question 18 days ago on Step 3
    Are there any comments for each line of this code for us newbies?
    TimK171
    Question 1 year ago
    Hi Adrie, this is a great piece of code, thank you, just wanted to know, how do I connect 7 x distance sensors to this code so I can get the data sent to the csv file? The code for the sensors work perfectly and I can see the data when running the code, but don't know how to connect it to your cool piece of code, can you help please?
    GoobyPlestomlubinsk
    Reply 3 years ago
    Data logging for example =D
    It logs data from sensors, and that's the real life application. Weather monitoring, movement tracker, use your imagination ^^
    TimK171GoobyPles
    Reply 1 year ago
    Hi GoodyPles, I'm new to RPi, I have 7 x directional sensors connected to RPi 3 all working perfectly, I just need to download the data to csv file, above code is very useful and works very well. How to I connect the sensor data to this code? Please help really struggling. Cheers
    TimK171TimK171
    Reply 1 year ago
    Sorry should be distance sensors
    Danjo77
    1 year ago
    Hi ArdieSentosa,
    I like this project!
    @Hejhooo:
    1) try ls /media/*
    2) got it running by re- opening file before closing again in the while true loop ; dunno why it closes after header line - I'm also a newbie
    3) if running well you will not see it opening; in folder you will see file size raising
    mabtan
    1 year ago
    like
    Hejhooo
    1 year ago
    Help!!!
    there is 3 things that is totally black for me
    1) ls /media ? the responses i got is - pi?? do i tell my RB it have USB ports?
    2) in the code i got a fault on i=i+1
    Code:
    #!/usr/bin/env python
    # -*- coding: utf-8 -*-
    import os
    import time
    i=0
    if os.stat("/home/pi/data_log.csv").st_size == 0: file.write("Time,Sensor1,Sensor2,Sensor3,Sensor4,Sensor5\n")
    while True:
    i=i+1
    file.flush()
    time.sleep(5)
    file.close()
    3) It don't open the file data_log.csv
    best regards Henrik
    ginojenssen13
    1 year ago
    sir can you help me how to put input pin on this data logger?. example how can i code input in sensor 1. im new in raspberry pi and i really want to explore more. please help me for my project thanks and best regards.
    ginojenssen13
    Reply 1 year ago
    example in sensor 1 how can i code input?. can i have example?. much better in push button for easy use.
    tangoWorld12
    1 year ago
    hi, hope you can help.. i get a error message for .. "time.sleep(5)
    file.close()"
    it says that the file name is not defined , why is this ??
    also, ls /media brings up "pi" and doesn't bring up the name of my usb, any ideas of how to resolve this ?
    yoyojackytangoWorld12
    Reply 1 year ago
    you need to import time module in your code.
    import os
    import time
    i=0
    while True:
    i=i+1
    file.flush()
    time.sleep(5)
    file.close()
    it seems like that.....
    fbooth
    2 years ago
    The data logging gave me ideas on saving data collecting from RasPi.
    44389
    2 years ago
    Can you use this to log data off of a blood glucose monitor?
    FilipaP2
    2 years ago
    Hello,
    I'm having a really hard time understanding your guide and how to use it in my project... maybe its me, since im a total newbie with python... will read the other two guides you shared tho, and try to understand how this data logger works.
    But.... is it possible to explain what does the "file.write(str(now+","+....." actually do?
    Thank you for your time!
    ojohn12
    2 years ago
    Hi Adrie,
    How do I get more information on how to use the Raspberry Pi data logger
    AdrieSentosaRocking Arduinos
    Reply 2 years ago
    nope, sqlite for the database that could be access easily from server but .sdv datalog require further code that affect in its simplicity.
