Raspberry Pi Scrolling Sign
9,124
25
24
This project is for a Raspberry Pi controlled scrolling sign using a 32x64 matrix of RGB LEDs. The sign scrolls information on two rows. The upper row shows current time and date. The lower row shows; jokes, quote of the day, weather information, environment information, headlines, birthday greetings and holiday greetings. A BME280 environmental sensor array is used to obtain temperature, humidity and barometric pressure information. The birthday and holiday greetings are read from two .xml files that you can edit to add the birthdays, holidays and greetings of your choice. Everything else is obtained from various web sites.
RGB LED matrices come in a variety of pixel sizes, pixel densities and interface configurations. Pixel size refers to the number of rows and columns of RGB LEDs. Pixel density refers to how close the RGB LEDs are to each other. The pixel density of a display is stated by a 'Pn' designation. P4 refers to a display with 4mm spacing between the RGB LEDs. Lower 'P' numbers are higher density. The lower the 'P' number, the closer you can view the display. If you are too close then your eye will not blend the pixels properly. For this project you will need an RGB LED matrix with a Hub75 (the most common) interface. The Hub75 interface defines the connector used, the signals used and the wiring. I used a 32x64 pixel matrix with 4mm density (P4-64x32-16S). The matrix has 32 rows with 64 columns of RGB LEDs. This type of matrix can be purchased from Adafruit or on Ebay. The driver library used can handle longer displays (more columns or fewer columns) and can drive up to three displays. I chose to limit it to one display with a maximum of 32 rows.
Adafruit sells a HAT for the Raspberry Pi for controlling a Hub75 RGB LED matrix. I chose to design my own board to mate with a Raspberry Pi Zero W (RPiW). My board has all of the GPIO pins not used to drive the matrix broken out to headers. The I2C and Console (Serial) ports are also broken out. An optional 3.3V regulator can be added if you need more power for peripherals. Except for the matrix driver library, all the coding was done using Python. My Hub75 interface board will work with any Raspberry Pi with a 40 pin GPIO header. However, if used with a Raspberry Pi other than an RPiW there may be interference issues. You may have to leave out the unused GPIO headers or swap them for right angle headers. Why use a $35.00 Pi when a $10.00 Pi will do the job? If you do not use an RPiW then you will need to add a USB WiFi dongle and possibly an adapter to convert it to micro USB. WiFi dongles and adapters are cheap, but when you add it to the cost of the Raspberry Pi you might as well buy the RPiW.
The driver for the RGB LED Matrix drives two rows of RGB LEDs at a time. All of the rows are time multiplexed to yield the display. This means that at any given point in time, only two rows of LEDs are drawing current. Each pixel consists of three LEDs. One red, one green and one blue. Each individual LED in a pixel draws approximately 20mA when lit up. So each pixel will draw around 60mA if all three LEDs are turned on. Multiply that by the number of pixels in a single row (64 in my case) and you get a maximum current per row of 3840 mA or 3.84 Amps. Multiply that by two because two rows are driven at the same time and the maximum current jumps to 7.68 Amps. Bottom line, if every LED on the display is being told to be on then it will draw in the neighborhood of eight Amps. This calculation does not take into consideration the power requirements of the Raspberry Pi used. An RPiW needs about 180mA when using WiFi, So an 8 Amp @ 5V power supply will suffice. A full sized Raspberry Pi 2 or 3 requires around 2.5Amps. You would need a 10Amp power supply for a full sized Raspberry Pi. Keep in mind that this represents a worst case scenario. For a scrolling sign most of the LEDs are turned off so you should be able to use a lower rated supply. But, do you really want your display to mysteriously reset because too many LEDs are turned on?
The amount of work to build one of these scrolling signs depends a great deal on what parts you buy. For the Adafruit Hub75 HAT, all you need to do is solder a few connectors in place. If you decide to build one of my boards then you will need to be skilled at hand soldering surface mount components. Or you can decide to use the schematic of my board to hand wire a Hub75 interface board. I highly recommend using someone's Hub75 interface board because the RGB matrices are 5V and the RPi is 3.3V. Adafruit's board and my board use level shifters to convert the RPi's 3.3V signals to 5V for the matrix.
Configuring the RPi for WiFi, auto boot into the Python script, installing the matrix driver library and installing the Python libraries used can be a daunting task. I have laid out step by step instructions for doing this that should make it fairly easy to do. This project assumes that you are familiar with using Putty and WinSCP or equivalent programs and working with the Linux command line.
Supplies:
Step 1: What You Will Need to Build One
  • A Raspberry Pi Zero W.
    • If you are using another Raspberry Pi then you will also need;
      • A USB WiFi dongle compatible with the Raspberry Pi.
      • if using a Raspberry Pi Zero, a micro USB to full size USB adapter.
  • A micro SD card with a capacity of at least 4GB.
  • A micro SD to full size SD card adapter or an SD card reader/writer that can accept a micro SD card.
  • A USB cable with a micro USB connector on one end. This is used only during setup and development.
  • A 32x64 RGB LED matrix display with a Hub75 interface.
    • any RGB LED matrix that has 16 or 32 rows and a Hub75 interface.
  • The power harness that came with the RGB LED matrix. The flat cable is not used.
  • A 5V, 8 Amp minimum power brick.
    • 5V, 10Amp power supply if using a full sized Raspberry Pi.
  • Power jack that mates with your power supply.
  • A Hub75 interface board that accepts a Raspberry Pi 40 pin connector.
    • Adafruit sells one
    • I designed my own for this project. Mine has the unused GPIO broken out to headers as well as headers for SPI, Serial and I2C. See BOM for my board or if you hand wire your own
  • Four optional 2.5x11mm standoffs.
  • Eight optional 2.5x6mm screws for the standoffs.
  • Optional, for obtaining environmental information.
    • BME280 sensor array board.
      • Two, four pin DuPont shells.
      • Eight DuPont female crimps.
      • Four lengths of 22-28 awg stranded wire.
      • Or you could use four female to female jumper wires
RGB LED Matrix displays are available on Ebay or from Adafruit. Just make sure it uses a Hub75 interface. You can buy a ready to run Hub75 interface board from Adafruit. They sell one for the Raspberry Pi and one for the Teensy. As this is a Raspberry Pi project, buy the one for the Raspberry Pi. I have included the Eagle files needed to have one of my custom Hub75 interface boards manufactured. I use AllPCB.com to have my boards fabricated. As of this writing, AllPCB.com is charging $5.00 with free shipping to the USA for ten boards. The last order that I placed took about ten days from time of order to delivery to my door. Of course, if you are truly adventurous, you can hand wire your own board from the PDF of the schematic. I also have some rev 1.1 boards left over from my order and some rev 1.0 boards. Contact me if you are interested in a blank board.
A 32x64 RGB LED matrix requires at least an 8 Amp power supply. If you decide to daisy chain in a second or third matrix to extend the length of the display, you will need an additional 8 Amps for each 32x64 panel that you add.
Matrix display panels are specified by the pixel (tri-color LED) density, number of columns and rows. A P4-64x32-16S display has a pixel spacing of 4mm. A P5-32x16-8S display has a pixel spacing of 5mm. Displays with a lower pixel density (higher P number) require a greater viewing distance for the human eye to blend the pixels. They are also usually a little less expensive. The display shown above is a P4-64x32-16S. The pixel density will also determine the actual physical dimensions of the display. The -16S indicates the number of rows that can be selected, 16S indicates 16 rows (four signals), 8S indicates 8 rows (three signals). It also indicates that the refresh is done 16 or 8 times for per panel. A panel has an upper and a lower half with one row from each half being refreshed simultaneously. So -16S is a 32 row panel and -8S is a 16 row panel.
Step 2: Hub75 Interface Board BOM
You can ignore this if you purchased the Adafruit Hub75 Interface board. If you are hand wiring your own board then you may want to use through hole parts instead of the surface mount parts called for. In that case consider this more of a guideline. The BOM is detailed as two assemblies, a bare minimum and the ad-hoc optional assemblies. The first picture above shows the minimum parts required.
Minimum Build:
Reference - Description ------------------------- Mouser P/N ------------- Digikey P/N
TB1       - 2 position Terminal block, 5mm pitch, 651-1792863,      $0.30, 277-2518-ND,   $0.30
IC1, IC2  - 74HC245DWR,                           595-SN74HC245DWR, $0.50, 296-1197-1-ND, $0.52
J9        - 2 - 1x20 Socket strips,               855-M20-7822046,  $1.90, 952-1905-ND,   $1.89
J8        - 2x10 Socket                           855-M20-7830546,  $1.38, 609-3573-ND,   $1.43
The BOM calls out for 74HC245DWR. Any part 74*245DWR will work. So 74LS245, 75ALS245 or 74AHC245 will all work. The important thing is that it is 74xxx series, 245 (indicates an octal bus transciever) and that the wide surface mount package is used (DW indicates SOIC-20W package). CMOS (HC or AHC) is preferred over TTL (LS or ALS).
If you do the minimum build and leave out the AS1117-3.3 regulator then you need to solder a jumper wire to the two holes of J18. Doing this allows the 3.3V from the Raspberry Pi to connect with the 3.3V pins of the I2C headers and the 3.3V header associated with the unused GPIO. Leave the jumper out if you add the AS1117-3.3 regulator. When the jumper is left out the AS1117-3.3 handles the load for the added peripherals. It prevents overloading the Raspberry Pi's 3.3V regulator.
For the minimum build you should also place a jumper from the center pin to either of the outer pins of J11. This jumper selects 32 row or 16 row operation. Place the jumper to correspond with the RGB LED matrix that you are using. If you leave out the jumper then your display will look very weird. In place of a wire jumper, you could add a three pin post strip and then use a two pin shorting plug to select 32 or 16 rows.
Tip: You may find that you can save about a dollar by using two 2x10 sockets for J9 instead of two 1x20 socket strips.
Tip: Buying all your parts from one vendor will save you shipping costs.
Tip: I prefer to buy forty pin female socket strips and cut them down to the size that I need. You sacrifice one position each time you make a cut, so a forty pin strip will not yield two twenty pin strips. However, two forty pin strips, each cut twice (cut at 21 then cut the 19 pin piece at 11), will yield two twenty pin strips, two ten pin strips and leave you with two eight pin strips to use someplace else. After cutting I like to use a small file to cleanup the cut end. The second picture above shows a 40 pin strip that has been cut into a 20 pin strip and a 19 pin strip (red box). The green box shows a 19 pin strip and the 10 pin and 8 pin strips that result from cutting it down.
Adafruit sells several 2x20 female headers. They vary in height (8.5mm or 13mm) and in the length of the solder pins. Stacking connectors have extra long pins so that you can stack another HAT on top. For this project, the standard 2x20 female header (Adafruit P/N 2222, $1.50) is the best choice. If you buy the 13mm version then you will need to get longer standoffs (13mm instead of 11mm).
A 2x10 socket is used to mate with the display because it fits into the shroud that surrounds the 2x8 post strip on the display. The extra pins on each side prevent you from mis-aligning the connectors.
The rest of the parts are optional and add to the minimum build. You can add what you need for your project. I like to buy forty pin snap-apart post strips in black, red and yellow. I then break them apart into the sizes that I need. Of course you can use all black, but I find it very convenient to use black for ground, red for power and yellow or some other color for the signal.
J1, J2, J3  - four pin post strips         - I2C headers
J4          - three pin post strip         - Console or Serial port header
J5,         - nine pin post strip, yellow  - Unused GPIO header
J6          - nine pin post strip, black   - GPIO Ground header
J7          - nine pin post strip, red     - GPIO Power (3.3V) header
VR1         - AS1117-3.3                   - 3.3V, 1A regulator
C1, C2      - 10uF tantalum capacitors     - Used to stabilize the AS1117-3.3 regulator
Optionally, you can use three row, right angle post strips for the I2C and GPIO headers. The advantage of using the right angle headers is that they will not interfere with the USB adapter and WiFi dongle if you are using a Raspberry Pi Zero. The right angle headers can be mounted on what ever side of the board is convenient for you.
Step 3: Tools Needed:
  • Hardware tools
    • Screwdrivers, Philips and flat blade
    • Wire cutters
    • Wire strippers
    • Soldering Iron & solder, preferably with 'No Clean' flux
    • HDMI monitor
    • mini HDMI adapter
    • keyboard
    • micro USB adapter
    • 5V power supply
    • Internet connection for downloading files
The SD card formatter is used to erase & format an SD card to give you a 'clean slate' to work with. The SD card imager is used to put a bootable image of the operating system (a .img file) onto your newly formatted SD card. Putty allows you to use SSH to talk to your Raspberry Pi through its WiFi or Ethernet connection. With Putty and SSH you can operate and monitor your Raspberry Pi from a window on your PC. WinSCP allows you to copy files from your PC to your Raspberry Pi. WinSCP provides a drag and drop GUI for you to transfer files and view the directory structure of your Raspberry Pi and your PC.
Step 4: Setup the Raspberry Pi
The good folks over at www.raspberrypi.org have spent a lot of time and effort making simple to understand, detailed instructions on how to setup your Raspberry Pi and what you will need to do it. They have done a much better job of this then I can. Use the following links to setup your Raspberry Pi;
Here is where we run into a little trouble. The guide on connecting your Raspberry Pi to a monitor, keyboard and mouse assumes that you have a full sized Raspberry Pi 2 or Raspberry Pi 3. The Raspberry Pi Zero and Raspberry Pi Zero W have only one USB port and it has a micro USB connector. The HDMI connector is a mini HDMI and not a full sized HDMI connector. So there are some differences in what is needed and how things are attached. In addition to what was listed on the Raspberry Pi web site, you will also need the following;
  • A full sized female HDMI to male mini HDMI adapter
  • A full sized female USB to male micro USB adapter
  • As we will be running headless, a mouse is not required
  • If you are using a Raspberry Pi Zero, a USB WiFi dongle will be required
  • To power your Raspberry Pi you will need either;
    • To take power from your computer; a USB cable with a micro USB plug at one end
    • To power from a wall socket; a 5V power pack with a micro USB on the end of the cable or an old 5V phone charger with a USB cable with a micro USB plug at one end.
The first picture above is of two styles of mini HDMI adapter. One is a simple plug and the other is a short cable. The second picture is of two styles of micro USB adapter. The third photo is a picture of a Raspberry Pi Zero. I have drawn red circles around where to plug in your power, keyboard, monitor and micro SD card. The micro USB plug adapter in the photo above works quite well, but is a little too big to plug in a micro USB cable into the adjacent micro USB power jack (see fourth photo above). As a result, I filed down the side of the adapter until everything fit nicely (see fifth photo above). The cable style micro USB adapter does not have this problem.
Step 5: Configure the Raspberry Pi
Once you have your Raspberry Pi up and running the Raspbian Stretch Lite operating system it is time to configure your system. You need to enable the I2C interface, SSH, select your language and keyboard layout, select your timezone and configure WiFi to access your home network and set the WiFi for your country. Most of this is done using raspi-config. Setting up to work with your home network involves editing of a configuration file.
The easiest way to run raspi-config on your Raspberry Pi zero or Raspberry Pi Zero W is to use a keyboard and monitor. If you have a full sized Raspberry Pi you can put the SD card into that Raspberry Pi and then use a keyboard and monitor or plug in an Ethernet cable and SSH into the Raspberry Pi using Putty or connect a USB-to-Serial dongle to the console RX & TX pins and use a terminal program on your computer to run raspi-config.
Use this link for how to use raspi-config
Tip: You can use a full sized Raspberry Pi to configure an SD card to be used in a Raspberry Pi Zero or W. Once the configuration is complete, power down the Raspberry Pi , remove the SD card and plug it into the Raspberry Pi of your choice.
Tip: When using raspi-config, Internationalization Options to change your Locale you must first deselect the default locale (en_GB.UTF-8 UTF-8) before you change to your locale. The selected locale is identified by an asterisk between square brackets ([*]). You deselect the locale by using the arrow keys to move the cursor to the currently selected locale and then press the space bar. The asterisk should disappear. You select a locale by using the arrow keys to move the cursor to your selection and then press the space bar. The asterisk should appear. You can select multiple locales. However, if you do then when you exit, you will find that the default locale is still selected. Until you deselect the default locale your selection of another locale will not 'stick'. If you live in the USA then select en_US.UTF-8 UTF-8.
Step 6: Configure WiFi for Your Home Network
To do this step you will need to know the SSID (name of your home network) of your home WiFi network and the WiFi passkey. If your WiFi network is not using some form of encryption (a very bad idea) you will not need a WiFi passkey. The WiFi passkey is not the same as your WiFi router's password. One allows you to use your WiFi network and the other allows access to your router to configure it.
To enable WiFi on a Raspberry Pi you have to edit the file /etc/wpa_supplicant/wpa_supplicant.conf and add some lines at the bottom of the file.
At the prompt, type; sudo nano /etc/wpa_supplicant/wpa_supplicant.conf
Use the Arrow keys to go to the bottom of the file.
Add the text below, replacing "yourssid" with the SSID of your home WiFi network and replacing "yourpasskey" with the WiFi passkey for your home network
network={
	ssid=”yourssid”
	psk =”yourpasskey”
Press Ctrl-O, Enter, to save the file, Ctrl-X to exit.
If you are using a full sized Raspberry Pi or a Raspberry Pi Zero to configure the SD card then type; sudo poweroff
Wait for the Raspberry Pi to finish powering off, then plug in the USB WiFi dongle and power your Raspberry Pi back up.
If you are using a Raspberry Pi Zero W then the WiFi is built-in, type; sudo reboot instead.
Once the Raspberry Pi has finished booting, type; ifconfig
You should see something like the following;
<p>pi@StretchLite:~ @ ifconfig<br>io: flags=73 mtu 65536
        inet 127,0,0,1  netmask 256.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10
        loop  txqueuelen 1  (Local Loopback)
        Rx packets 0  bytes 0 (0.0 B)
        RX errors 0  dropped 0  overruns 0 frame 0
        TX packets 0  bytes 0 (0.0 B)
        TX errors 0  dropped 0 overrun 0  carrier 0  collisions 0
wlan0: flags=4163 mtu 1500
        inet 192.168.0.157  netmask 256.255.255.0  broadcast 192.168.0.255
        inet6 fe80::5c97:56f0:9dac:e5ac  prefixlen 64  scopeid 0x20
        ether 74:da:38:62:93:66 txqueuelen 1000 (Ethernet)
        Rx packets 127 bytes 28722 (28.0 KiB)
        RX errors 0  dropped 19  overruns 0 frame 0
        TX packets 90  bytes 16874 (16.4 KiB)
        TX errors 0  dropped 0 overrun 0  carrier 0  collisions 0</p><p>pi@StretchLite:~ @ ifconfig</p>
wlan0: is the Linux name of your WiFi dongle.
inet 192.168.0.157 is the IP address of your WiFi dongle (Raspberry Pi).
ether 74:da:38:62:93:66 is the MAC address of your WiFi dongle.
These values for IP and MAC address are for my WiFi dongle on my network. Yours will be similar, but different. If you do not have a wlan0: or no IP address then something is wrong. Make sure that your WiFi dongle is plugged in to the correct micro USB connector. Check the file /etc/wpa_supplicant/wpa_supplicant.conf and make sure that you entered your WiFi network SSID and passkey properly. If everything looks correct, but still does not work, try a different WiFi dongle. The one you have may not be compatible with the Raspberry Pi.
If all is good then your Raspberry Pi configuration is complete. What I like to do at this point is to put the SD card back into the reader and make a backup image of the configured system. Then the next time a need a fresh SD card I can just use the backup image and the system will be all configured once the SD card is written. I name the image files with the capacity of the SD card, the version of Raspbian, the country and WiFi if added. For example an image on an 8GB SD card would be named; Stretch lite WiFi USA 8GB.img. Of course you are free to use any naming convention you desire.
Step 7: How to Get an OpenWeatherMap Key
You will need an API key to access the OpenWeatherMap.org website to obtain current weather information. The next few steps detail how to signup with OpenWeatherMap.org and get an API key.
Follow this link to OpenWeatherMap.org/api.
On the left side, under Current weather data, click the Subscribe button.
Step 8: How to Get an OpenWeatherMap Key, Get API Key
Click on Get API key and Start in the Free column.
Step 9: How to Get an OpenWeatherMap Key, Signup
Click on the Signup button under How to get API key (APPID).
Step 10: How to Get an OpenWeatherMap Key, Create Account
Fill in all the fields. When finished, check the I agree to the Terms of Service and Privacy Policy checkbox. Then click on the Create Account button.
Check your email for a message from OpenWeatherMap.org. The email will have your API key. You will need to copy the API key into the options.ini file in order to obtain the current weather. The OpenWeatherMap.org free service has some limitations. Foremost is that you cannot access it more often than once every ten minutes. This should not be a problem because the weather does not change that rapidly. The other limitations have to do with what information is available. Any of the paid subscriptions will provide more detailed weather information.
Step 11: Copy the Project Files to Your Raspberry Pi
First you need to be able to talk to your Raspberry Pi. You can do that in one of two ways;
  1. Connect the Raspberry Pi to an HDMI monitor and USB keyboard using the appropriate cables and adapters.
  2. Connect to the Raspberry Pi over Ethernet or WiFi using SSH from a computer running Putty or an equivalent program. To use Putty you must have configured your Pi to enable SSH and you must know the IP address of your Pi.
You need to create a directory on your Raspberry Pi for all of this project's files. You can name the directory whatever you want and put it wherever you want. I recommend that you put the directory in /home/pi. The name I choose for the directory is; rgb-32x64. Be aware that when using the Linux command line, capital letters are not the same as lower case letters. So /home/pi is not the same as /Home/Pi.
  • To create a directory for this project type; mkdir /home/pi/rgb-32x64
All of the project files are available on GitHub. Click here to download the zip archive or clone the directory. If you have Git installed on your Raspberry Pi, you can clone the project files directory or download the zip archive directly to your Raspberry Pi.
Do the same for the Henner Zeller RPI RGB Matrix driver library. Click here to get the Henner Zeller RGB Matrix Driver Library from GitHub.
If you downloaded or cloned to your PC then use WinSCP or a similar program to copy the project files and RGB matrix driver directory to the directory you just created on your Raspberry Pi. You can unzip the archive on your PC prior to transferring the files or unzip the archive on your Raspberry Pi.
To unzip the archives on your Raspberry Pi
  • To unzip the project files archive, type: unzip
    RPi-RGB-Matrix-Scrolling-Sign
    .zip /home/pi/rgb-32x64
  • To unzip the Henner Zeller RGB Matrix library, type: unzip rpi-rgb-led-matrix-master.zip /home/pi/rgb-32x64
The folder on your Raspberry Pi should now contain all of the following;
  • RGB-32x64.py - Python script that runs the RGB LED matrix
  • options.ini - configuration file for enabling/disabling features of the Python script
  • birthdays.xml - XML file for birthday greetings
  • holidays.xml - XML file for holiday greetings
  • fonts - directory containing all of the fonts used by the RGB matrix display, part of the Henner Zeller RGB LED matrix driver package
  • samplebase.py - part of the Henner Zeller RGB LED matrix driver package
  • rpi-rgb-led-matrix-master - Henner Zeller RGB LED matrix driver directory
The zip archive/clone downloaded from GitHub contains some files that are not needed to run the project on your Raspberry Pi. There is a zip archive within the zip archive/clone that contains all of the eagle files need to have my PC board manufactured and a PDF for the schematic of my board. There are also some files used by GitHub that you can ignore.
Step 12: Edit Options.ini
The options.ini file is used by the system to enable/disable features and to provide URLs for some features to use. The file is organized as key=value pairs. When the Python script starts up, it reads and parses the contents of options.ini into system variables and lists. The keys are used to determine where/how the values are stored. You need to edit options.ini to add your OpenWeatherMap.org API key and to add your zip code and country. OpenWeatherMap.org is used to obtain current, local weather information. In a previous step you signed up for the free weather service from OpenWeatherMap.org.
If you wish to not have a URL be used, but want to keep it in the file then just alter the key by adding a letter or symbol to the key. For example, if you are not a fan of Blonde jokes then just add a pound symbol ('#') before jokesurl in the line; jokesurl=http://www.randomjoke.com/topic/blonde.php. The result should look like this; #jokesurl=http://www.randomjoke.com/topic/blonde.php. Or you could just delete the line.
Here is the default version of options.ini. Do not change any of the keys. Change only the values to the right of the equals sign ('='). For example; military=f can be changed to military=t to have the time displayed in 24 hour format (military time). To keep the time displayed in 12 hour format, leave the value as f.
military=f
temperature=t
humidity=t
pressure=t
weather=t
weatherkey=
weatherzip=
quote=t
quoteurl=https://www.brainyquote.com/link/quotebr.js
jokes=t
jokesurl=http://www.randomjoke.com/topic/oneliners.php
jokesurl=http://www.randomjoke.com/topic/riddles.php
jokesurl=http://www.randomjoke.com/topic/signs.php
jokesurl=http://www.randomjoke.com/topic/doit.php
jokesurl=http://www.randomjoke.com/topic/professional.php
jokedelay=300
news=t
newsurl=http://hosted2.ap.org/atom/APDEFAULT/3d281c11a76b4ad082fe88aa0db04909
newsurl=http://news.google.com/?output=rss
newsurl=http://news.yahoo.com/rss/</p>
The following expains what each key is used for and what values can be used.
  • military
    • t -> 24 hour (military time) format is enabled
    • f -> 12 hour format is enabled
  • temperature
    • t -> temperature read from the optional BME280 is displayed, BME280 must be present
    • f -> temperature read from the optional BME280 is not displayed or the BME280 is not present
  • humidity
    • t -> humidity read from the optional BME280 is displayed, BME280 must be present
    • f -> humidity read from the optional BME280 is not displayed or the BME280 is not present
  • pressure
    • t -> barometric pressure read from the optional BME280 is displayed, BME280 must be present
    • f -> barometric pressure read from the optional BME280 is not displayed or the BME280 is not present
  • weather
    • t -> weather data from OpenWeatherMap.org is collected and displayed
    • f -> weather data is not displayed
  • weatherkey
    • the API key obtained from OpenWeatherMap.org is copied here. The key is used when the site is accessed. Enter the text of the key without any quotes around it
  • weatherzip
    • this is the postal zip code of the city that you want to obtain weather data for. The entry here should be your zip code followed by a comma and then your country. Example; weatherzip=14502,us
  • quote
    • t -> enable the quote of the day to be displayed
    • f -> quote of the day is not displayed
  • quoteurl=https://www.brainyquote.com/link/quotebr.js
    • do not change this line. quoteurl= specifies the URL used to obtain the quote of the day. The Python script knows how to parse quotes from this web site. If you change the URL then the quote may not be parsed properly
  • jokes
    • t -> enable jokes to be displayed
    • f -> no jokes are displayed
  • jokesurl
    • Each URL is read into a list. When it is time to get a new joke the next URL in the list is used to obtain a joke. The Python script knows how to parse jokes from www.randomjoke.com, so always use that URL. Randomjoke.com has several topics or types of jokes to choose from. Some are not suitable for all people. It is up to you to determine which topics you wish to use. I recommend that you use your browser to visit the site and edit the list of URLs to suit your tastes in jokes. Only one URL per line and you can have as many lines as you like.
  • jokedelay
    • This is the number of seconds before a new joke is obtained. If the value is too small then some jokes may never get a chance to be displayed. You should increase this value if there are a lot of headlines to display. A sufficiently large enough delay will ensure that a joke is displayed more than once before a new joke is obtained.
  • news
    • t -> news headlines are displayed
    • f -> no news headlines are displayed
  • newsurl
    • This works like jokes, one line for each URL where news headlines are obtained. Do not change these URLs. The Python script knows how to parse headlines from these sites. If you add more sites they may or may not be parsed properly. The URLs are read into a list. All of the headlines from one URL are parsed and added to the list of messages to display. When the list is rebuilt the next URL is used. If you want fewer headlines then remove one or more URLs.
Step 13: Edit Birthdays.xml
The file birthdays.xml is read every time the date changes. The file is formatted using XML. The file is used to show a message whenever the current date (month and day number) matches the values stored in the file. Upon a match the message associated with the date is added to the list of messages to be displayed. If you have multiple entries with the same date then multiple messages will be displayed. Add or edit the entries in this file for any occasion that you want to have a message displayed for. Birthdays, anniversaries, memorable dates it is up to you. The only stipulation is that it must be a fixed date, like July 4th. It must fall on the same date every year. If you add an entry for February 29th it will only match once every four years. To add a new entry, copy and paste everything from <item> to </item> inclusive and then change the month value, day value and text values.
One entry looks like this;
<item>
  <month>11</month>
  <day>29</day>
  <flags>Birthday</flags>
  <line>2</line>
  <backgnd>0000</backgnd>
  <foregnd>FFFF<foregnd>
  <text>Happy Birthday to all</text>
</item>
The fields are;
  • item
    • indicates the start of a new entry
  • month
    • a number between 1 and 12 inclusive. Where 1 represents January. If you enter an number greater than 12 then the entry will never match a date.
  • day
    • a number between 1 and 31 inclusive. Where 1 is the first day of the month. If you enter an invalid date, like February 30th, then the date will never match. If you would like the associated text to be displayed every day of a particular month the entern 0 or 00 for the day.
  • flags
    • not used for birthdays. Can be set to any value, however, it must be present.
  • line
    • should always be 2. This value determines which line on the display the text is displayed on. There are two lines on the display line 1 and line 2.
  • backgnd
    • this field is not used. However, it must be present. The value is the background color to use when the associated text is displayed. The color is specified in 5-6-5 format, 5 bits for red intensity, 6 bits for green intensity and 5 bits for blue intensity. The value is a 16 bit number expressed in hexadecimal. The field is here for future use.
  • foregnd
    • this field is not used. However, it must be present. The value is the foreground color to use when the associated text is displayed. The color is specified using the same hexadecimal 5-6-5 format as backgnd. The field is here for future use.
  • text
    • this is the message to be displayed when the date matches.
Step 14: Edit Holidays.xml
The file holidays.xml works in a similar fashion to birthdays.xml. The difference is that the entries in holidays.xml use the day and flags fields to target dates that occur on specific days of the week. For example, Thanksgiving is always on the fourth Thursday in November.
The entry for Thanksgiving looks like this;
<item>
  <month>11</month>
  <day>Fourth</day>
  <flags>Thursday</flags>
  <line>2</line>
  <foregnd>FFFF</foregnd>
  <text>Happy Thanksgiving</text>
</item>
Holidays that fall on the same date every year, like Christmas, December 25th, are entered just like an entry in the birthdays.xml file. The day field has the day of the month and the flags field has Holiday instead of Birthday.
For holidays that do not fall on a set date, the day field gets one of the following values; First, Second, Third, Fourth, PalmSunday, GoodFriday or Easter. Use the value exactly as shown, capital letters are important. The values indicate which week of the month the holiday falls on or that it is a special case. The flags field gets one of the following values; Monday, Tuesday, Wednesday, Thursday, Friday, Saturday or Sunday to indicate the day of the week to match against. Use the value exactly as show, capital letters are important. The holidays.xml file contains most of the holidays observed in the USA. Unfortunately the system used is not perfect. Some holidays, like Hanukkah, can not be determined by the code as it is. Feel free to take a stab at adding Hanukkah. The issue with Hanukkah is that the date is determined by a calendar that does not coincide with the Gregorian calendar. I never figured out how to reconcile the different calendars.
Step 15: Install the Henner Zeller RGB LED Matrix Library
The Python script for this project was adapted from one of the example programs that are included with the Henner Zeller RGB LED matrix library. You can download the library here; Henner Zeller RGB Matrix Library. If you are interested, the README.md file details how the library works. The library also includes schematics and board files for making Hub75 interface boards. There are board packages for driving one, two or three matrices with one Raspberry Pi. One caveat is that the snd_bcm2835 driver that comes with the Raspbian operating system can cause interference with the matrix driver. Instructions are included on how to disable the snd_bcm2835 driver.
Once you have downloaded the matrix library, unzipped it and copy it to your project directory on your Raspberry Pi then follow these steps to compile and install the Henner Zeller RGB LED Matrix library.
  • type; cd rpi-rgb-led-matrix-master/bindings/python
  • type; sudo apt-get update && sudo apt-get install python2.7-dev python-pillow -y
  • type; sudo make build-python
  • type; sudo make install-python
  • type; sudo python setup.py install
  • type; cd ..
  • type; cd ..
  • type; cd ..
  • or type; cd /home/pi/rgb-32x64
You should now be back to your project directory.
Step 16: How to Disable the Sound Driver
Follow these steps to prevent the snd_bcm2835 driver from being loaded
The Linux prompt should be similar to this; pi@StretchLite:~ $
  • type; cat <
The prompt changes to >
  • type; blacklist snd_bcm2835
  • type; EOF
The prompt changes back to; pi@StretchLite:~ $
  • type; sudo update-initramfs -u
Reboot your Pi
  • type; sudo reboot
After the reboot, you will have to re-login to your Raspberry Pi. If you are using Putty then you will need to close the session and start a new one.
  • type; lsmod
Look for snd_bcm2835. if it is present then try again. You should not see snd_bcm2835 when you type lsmod
Step 17: How to Make a Python Script Run When the Raspberry Pi Boots Up
To run any Python script, program or shell script on power up, you need to edit /etc/rc.local. Before you can edit
/etc/rc.local you have to change its permissions to allow you to save it after you make changes.
Type; chmod 777 /etc/rc.local
To make it executable, type; /etc/rc.local enabled
Now you are ready to edit it. Open it in your editor of choice. Add the following two lines just above the exit 0 line;
sudo python RGB-32x64.py
Save your changes and exit the editor.
The first line; cd /home/pi/rgb-32x64 changes the current working directory to where the Python script for this project was copied to. The second line; sudo python RGB-32x64.py invokes supervisor privileges (sudo) to run the Python interpreter (python) and tell it to load and run the Python script (RGB-32x64.py) for this project.
If you want to run a different script on start up then change the path in the first line to where your script is located. Then change the second line to have the name of your script. The sudo command is only required by the RGB-32x64.py script because the Henner Zeller RGB Matrix library requires supervisory privileges to run. You may not need it to run a different script.
Step 18: Assemble the Hub75 Interface Board, Minimum Build
If you bought the Adafruit Hub75 HAT or plan on hand wiring your own board then you can skip this step. The pictures above show the top and bottom sides of a minimum build board and a fully built board. The minimum build board has only the bare minimum parts needed to connect your Raspberry Pi to a Hub75 RGB LED matrix display. The fully built board has the optional 3.3V regulator circuit and the optional I2C, Console and GPIO headers. You can build the minimum board, the full build or something in between. It is up to you. The top of the board has the 3.3V regulator pads and the pads for IC2. The bottom of the board has the pads for IC1. Before you start, you should decide what optional parts you want to add and have all the parts on hand. I find that it is easiest to assemble a board from the lowest height components to the tallest components. Therefore, I always start with the surface mount parts. Resistors, capacitors and integrated circuits are first. Top or bottom first does not matter. Be sure that the little dimple that marks pin one of the 74HC245 ic is oriented as shown in the pictures.
If you add the AS1117-3.3 regulator then you must also add the two 10uF capacitors. Make sure that the black line on the capacitors is oriented as shown. The black line is the positive side of the capacitor. One of the + signs for the capacitors was obliterated by a feed through next to the capacitor and the other is hard to see due to it ending up on top of some other text. The negative sides of the capacitors share a common trace on the top side of the board. If you mount the capacitors backwards then you will hear a load pop and see smoke when power is turned on.
If you are not adding the voltage regulator circuit then you will need to add a wire to short the two holes of J10 together (first picture above, red circle on the left). This allows the 3.3V from the Raspberry Pi to power any added peripherals.
J11 is used to select a 32 row or a 16 row display. You can either solder a wire that shorts the center hole to the appropriate side for your display (first picture above, red circle near the middle) or add a three pin male header and use a shorting jumper to make your selection (third picture above, red circle near middle). Do not leave this open, a 32 row display will not function properly without the 32 row jumper in place.
The 2x10 socket goes on the bottom side of the board. Optionally, you could use a 2x8 male header mounted on the bottom side of the board and connected to the RGB matrix using the gray cable that came with it. If you are using a full sized Raspberry Pi you should do this. the 2x8 header should be centered in the 2x10 hole pattern such that there are two unused holes on each side of the header.
The two 20 pin socket strips mount on the top side of the board. They are where you plug in your Raspberry Pi. If you bought the Adafruit 2x20 GPIO female header then solder it to the top of the board.
Tip: I find it helpful to plug in a couple of spare male header strips into the socket strips at right angles to them. This helps to stabilize the socket strips, keeps them vertical and keeps the proper spacing. I use extra socket strips to do the same when adding male headers. I always solder one pin and then check to make sure that the header is aligned and vertical before soldering the remaining pins. It is far easier to heat one pin and adjust the header than it is to try and re-align a header that has all of the pins soldered.
The two pin terminal block can mount on the top or the bottom side of the board. If you are using a full sized Raspberry Pi then it must go on the bottom side. I found that on the display that I am using, one of the small screws that hold the display together rubbed against the terminal block when it was installed on the bottom side. You can either ignore it or clip off the screw or mount the terminal block on the top side. Optionally, you can eliminate the terminal block and just solder wires from the holes to the power plug on the display.
Step 19: Assemble the Hub75 Interface Board, Options
The first two pictures above depict a fully assembled Hub75 Interface Board with all options added.
Because the voltage regulator circuit has been added, J10 is left open (red circles on left side).
A three pin male header has been soldered into J11 (red circle in middle) and a shorting jumper has been set to select a 32 row display.
Three rows of nine pin male headers have been added for the unused GPIO pins. I like to use black for the ground row, red for the 3.3V row and yellow for the GPIO signals. You can use any colors you like.
Three rows of four pin male headers have been added for the I2C breakout. The red headers are 3.3V.
A three pin male header was added for the Console (Serial) port.
This board was assembled with the two pin terminal block on the bottom side.
The last two pictures are of a minimum build board with triple row right angle headers in place on the top and/or the bottom side.
If you are not using a Raspberry Pi Zero W then you might want to consider triple row, right angle post strips for the unused GPIO and/or the I2C breakouts. If you are using a Raspberry Pi Zero, these can be mounted on the top or bottom of the board. Using the right angle headers for the GPIO breakout will prevent any interference with the WiFi dongle and USB adapter. The I2C headers do not interfere with a Raspberry Pi Zero, so you can use vertical headers mounted on the top of the board. If you are using a full sized Raspberry Pi, you should use right angle headers mounted to the bottom of the board. This will allow access to the headers when the Raspberry Pi is attached. You could substitute a 2x8 post strip header for the 2x10 socket and connect to the RGB LED display using the gray flat cable that came with the display. Just make sure that you connect pin one to pin one. Solder the 2x8 header centered in the 2x10 layout. Their should be two unused holes on each side of the 2x8 header.
The two pin terminal block can mount on the top or bottom of the board. If you use a full sized Raspberry Pi then it must go on the bottom.
FYI: The top side of the board is the side that has the pads for the AS1117-3.3 regulator, C1, C2 and IC2.
Step 20: Prepare the Power Harness
The first picture above is a picture of the power harness that came with my RGB LED Matrix display. There are two, four wire power plugs, each with two red and two black wires. All four red wires are twisted together and soldered to a single red wire that has a spade connector on the other end. The same was done with the black wires. I am not cascading two displays, so I only need one, four wire power plug. Therefore, I decided to cut the red and black wires of one four wire power plug from where there are soldered together. The result is shown in the second picture. The third picture shows the power harness and a red/black pair wired into a power jack. The fourth and fifth pictures show an alternate method to get power for the Hub75 interface board. Instead of adding two wires to the power jack, a red and a green wire are soldered to the RGB LED Matrix's power header. These wires would then be attached to the terminal block on the Hub75 interface board, with the red wire going to +5V and the green wire to GND.
The sixth photo shows the power harness with the power plug and the extra red/black pair attached to the Hub75 interface board, with the red wire going to +5V and the black wire to GND.
The last photo is a closeup of the terminal block. showing the red and black wires wired to +5V and GND.
The important points here are to use all four of the wires of the power harness to carry power to the display. This will limit the voltage drop in the cable when the display is drawing maximum current. The other point is to provide a source of +5V and Ground to the Hub75 interface board. The Raspberry Pi will get its power from the Hub75 interface board when it is plugged in. The wires to power the Hub75 interface board do not need to be as heavy as the wires to the display because the Hub75 interface board and Raspberry Pi together only require a few hundred milliamps, assuming you are using a Pi Zero or W.
Step 21: Putting It All Together
Now you have all of the pieces, let's put it all together.
  1. Plug the Hub75 interface board with the power cables connected into the input connector on the RGB LED Matrix display. The Raspberry Pi connector should be towards the edge of the display as shown in all of the pictures.
  2. If you are adding the optional BME280 environmental sensor array then this would be a good time to attach it to the Hub75 interface board. The first three pictures above show the BME280 attached using four female to female jumper cables. The BME280 has an I2C interface so it is wired to one of the I2C breakouts, Gnd to Gnd, 3.3V to 3.3V, SDA to SDA and SCL to SCL. Note that this is not a one-to-one cable, the SDA and SCL positions are not the same on the Hub75 interface board as they are on the BME280.
  3. The third photo shows a Raspberry Pi W plugged into the Hub75 interface board. The fourth photo shows a Raspberry Pi Zero with WiFi dongle and USB adapter plugged into the Hub75 interface board. Note that a minimum build was used with the I2C header pins added.
  4. Plug in your power supply and plug the power supply into a wall socket (mains power).
  5. In about 30 seconds your sign should light up and start scrolling messages.
Note: The unused GPIO pins, I2C and Console pins all use 3.3V levels. Connecting 5V signals to these pins will damage your Raspberry Pi. Use only 3.3V peripherals or provide external level shifters.
Step 22: Where to From Here
You have just finished making a fairly complex project. Congratulations, you are now the proud owner of a Raspberry Pi based 32x64 RGB LED display. You can sit back and enjoy the fruits of your labor...or dive right in and give your scrolling sign more things to do. Maybe you want to add some Python code to follow someone on Twitter and display their tweets. You could experiment with using it as a graphics display to play Pong or Tic-Tac-Toe or Breakout or Othello. How about running a game of life simulation or just a mess of pretty blinking lights. Let your imagination run free. Have fun and enjoy.
If for some reason your display did not light up then go back and check your wiring. If you hand built a Hub75 interface board then make sure that you wired it correctly and/or that there are no solder shorts on your board. Make sure that everything is plugged in correctly. You can also try to manually start the python script by using Putty to SSH into your Raspberry Pi and typing;
cd /home/pi/rgb32x64
followed by; sudo python RGB-32x64.py
If this gets your sign running then something is wrong with the auto startup. Go back to step 17 and double check your work.
    • Woodworking Contest
      Woodworking Contest
    • Classroom Science Contest
    • Party Challenge
      Party Challenge
    24 Discussions
    LechJ1
    Question 8 days ago on Step 1
    Hello
    There are new matrices that are unwilling to work with this software. Please give the names of integrated circuits on which the colored matrix is made?
    are there 24 x -FM6124
    4 x -TC7258
    3 x -74HC245
    youbehca
    23 days ago
    Has anyone done this lately? I had a running demo using the Henner Zeller files...and the demos worked fine...but I really wanted what this project offered. So I put the files on my already running setup, and it worked but the display was configured wrong...so I looked at the docs, and entered the correct values for rows and panels...but this projects files ignore all settings but font apparently.
    ...some time passes...
    Ok I got it working...my solution was to use the Adafruit software installer annotated here... https://learn.adafruit.com/adafruit-rgb-matrix-plu...
    I downloaded their software and ran their setup app. That got my panels working correctly on a clean setup (brand new Pi image).
    THEN I downloaded just this article's software.
    Finally to modify the software for any different panel setup you have to edit the 'samplebase.py' file that is in this article's software. Specifically line 14 for rows, line 15 for daisy chained boards, and 18 for brightness.
    I changed the default in the text, and the default= entry... in my case.
    self.parser.add_argument("-r", "--led-rows", action="store", help="Display rows. 16 for 16x32, 32 for 32x32. Default: 16", default=16, type=int)
    self.parser.add_argument("-c", "--led-chain", action="store", help="Daisy-chained boards. Default: 4.", default=4, type=int)
    self.parser.add_argument("-b", "--led-brightness", action="store", help="Sets brightness level. Default: 50. Range: 1..100", default=50, type=int)
    I would like to thank the author for the ground work, and I hope my info helps others.
    BigjBehryoubehca
    Reply 16 days ago
    You are welcome.
    I am glad to hear that you made a similar device and that you were able to figure out how to make the changes that you wanted to make.
    youbehcaBigjBehr
    Reply 9 days ago
    My example...Now I want it to display calendar events or other things...
    resmithn
    Question 5 months ago
    Hello,
    The program executes with exceptions below. No weather info is displayed and message that no Headlines. Any help on resolving these issues is appreciated.
    Thank You.
    NTP: Mon Dec 3 09:02:02 2018
    Reading options file
    Creating Weather thread
    QOD Thread
    Making New Bottom List
    Get Weather
    Parsing from: https://news.google.com/news/headlines?gl=US&ned=us&hl=en
    Updating weather informationBME280 not found, check wiring
    Press CTRL-C to stop sample
    Quote of the Day
    Parsing Weather info
    Updating forecast information
    Unhandled exception in thread started by <function getWeather at 0x75ec7f70>
    Traceback (most recent call last):
    File "RGB-32x64.py", line 802, in getWeather
    list += getForecast()
    File "RGB-32x64.py", line 848, in getForecast
    wd = parseWeather(wlist[0], 1)
    IndexError: list index out of range
    Parsing Headlines from Google or Yahoo
    ===== Headlines =====
    Found 0 headlines
    ^CExiting
    BigjBehrresmithn
    Answer 5 months ago
    I have had a chance
    to look into the issue with the weather information not working. From
    what I can tell, Python has decided to not work correctly. The
    weather information is obtained by sending a data request to the
    OpenWeatherMap site. The data request contains the zipcode and
    country that you want the weather for and your OpenWeatherMap account
    key. The zipcode/country and account key are read from the
    options.ini file and stored in variables. The getWeather() thread
    uses these variables to create the data request that is sent to the
    OpenWeatherMap site. The following statement in getWeather() forms
    the data request;
    url =
    http://api.openweathermap.org/data/2.5/weather={}&APPID{}’.format(weatherZip,
    weatherKey)
    Python is supposed
    to replace the curly braces with the contents of the weatherZip and
    weatherKey variables. At one time this worked. What I am seeing now
    is that the data request is not being created correctly. From the
    testing that I have done it appears that the ampersand that follows
    the first set of curly braces is causing Python to mess up the final
    string. If I remove the ampersand then Python forms the data request
    string properly, except it does not work because OpenWeatherMap
    requires the ampersand. This is a Python issue that I cannot fix. You
    can see the failure by adding a print url statement after the
    statement above. The string printed by Python does not follow
    Python’s rules for string formatting.
    I do have a
    workaround. Comment out the statement above and add a statement that
    assigns a literal string to the variable url. The literal string
    should contain the zipcode/country and your account key. For example,
    assume your zipcode is 14502, your country is the USA and your
    account key is 1234567890. The statement that you add would be;
    url =
    http://api.openweathermap.org/data/2.5/weather=14502,US&APPID1234567890
    This will work. You
    need to do the same thing to the getForecast() thread. The only
    difference is that ‘weather’ is replaced with ‘forecast’ to
    obtain the forecast data.
    url =
    http://api.openweathermap.org/data/2.5/forecast=14502,US&APPID1234567890
    I have not looked
    into the issue you are having with the headlines. I suspect that
    either the url that you are using has changed or the formatting of
    the returned data has changed rendering my parsing code useless. You
    can test this by using your web browser. Enter the url for the news
    feed into the url bar of the browser. The web page returned will have
    the news or you will get a 404 error indicating that the url is
    invalid.
    If I get some free
    time I will look into the headlines problem. I also noticed that the
    quote of the day and the jokes were also not working. These could all
    be related to the issue of Python not resolving string formatting
    properly.
    resmithnBigjBehr
    Reply 5 months ago
    Thank You for the reply and for creating this project. I did some research and actually submitted a support request to APIWeather. Their reply/recommendation was to remove the curly brackets{}. That worked as you pointed out in your reply.
    Regarding the news feeds: The Yahoo link still works as written. I checked the Google/AP links in a browser and they are not links to XML data, only links to plug into an RSS feeder app. The Yahoo link is still XML data. So that is reason for No Headlines for Google/AP. I found that an ABC News link is XML so modified the AP Parser function to use that url. I used <title> and </title> to set the POS/Key variables and then after set, did some adjustment , i.e., +3 and -9 to get rid of extraneous characters. Not all RSS XML is the same. So, it is working just fine. Thank You again for your efforts.
    Regards,
    Robert
    youbehcaresmithn
    Reply 20 days ago
    For me everything works but the news...never mind...it took a while but eventually 70 headlines were parced
    MikeM781
    Question 1 year ago
    Greetings. One last follow up question/comment on the updated forecast code. I see that it's pulling the forecast +3 hours and +24 hours. I live in Michigan, USA, a location that often has wide temperature swings. Some days it gets hotter through the course of the day, other days it can get cooler. If I review the "tomorrow" forecast right now ,it will return a high temperature corresponding to 9am eastern (about 20F below the forecasted high for the entire day). I'm going to see if I can figure out how to take the existing code and data collected, and pull a min/max temp for the entire forecasted day. Until then, I'm going to surpress the forecast output, because the wife is already asking who is correct (the scrolling sign or Alexa).
    Also I've made some slight changes to the top line..now it shows hours:minutes in roman numerals for 20 seconds, static display near the left edge (accomplished by first setting a new pos1 location, then slowing the pos1 counter to 0.001). After 20 seconds, a fast scroll (pos1 +=3), and then the day and date (minus the year..as it doesn't fit in in 128 columns).
    Future plans: I'd like to get just the current outdoor temp to show on the top line, static, for 20 seconds as well. To do this I need to better understand the toplist and bottomlist code functions. I've also found an API for stock prices. Using the weather API code as a great template, I may try to add an extra bottom list line that parses and displays a few company high, low, current stock values for the day.
    This will be my last posting for awhile on this project. Again, my thanks for sharing your code and for all your help.
    MikeM781
    Question 1 year ago
    This is a follow up to my question and comments posted yesterday. This program is now working well for me, after the following steps: 1. I believe the options.ini file as written (part of the download package), contains a few variables without a 't' or 'f' assigned. That throws the original "string index out of range error". Once I edited the .ini file appropriately, the file reads, but does not load any values, hanging up on the first line, which is "military=t". It appears that the "value" field returns null, and there is something wrong with the following code: value=s[1][:len(s[1])-1]. According to the comment line, this is intended to strip away the trailing spaces/line, and return either "f" or "t". However, a null value is returned. I decided to simply set value=s[1], and it worked like a champ, reading in all the setpoints from the .ini file. I'm not good enough in python to understand the problem in the value line of code, so I leave that to others to explore. Nor am I understanding why this line is needed, since the program seems to execute just fine without the extra attempt to clean up line spacing. In any event, this is a fantastic program..I've got the jokes working, the newsfeeds, the weather API, quote of the day. My thanks again to the author for posting!!
    BigjBehrMikeM781
    Answer 1 year ago
    Mike,
    New RGB-32x64.py has been posted to GitHub. New version fixes issues with options.ini, using military time format and does weather forecasts. Enjoy
    MikeM781BigjBehr
    Answer 1 year ago
    Downloaded the new main file and options file and worked perfectly right out of the gate. Thanks!
    BigjBehrMikeM781
    Answer 1 year ago
    Mike,
    I took a look at what you said. The options.ini file as
    downloaded from GitHub does indeed have the 0x0Ds missing from each line (only
    the 0x0A is present). I reposted the original file (with 0x0D & 0x0A) and
    downloaded it again only to find that the 0x0Ds had been stripped out !!! This
    must be something that GitHub is doing.
    Very strange. If I download as a zip file from the
    repository the 0x0Ds are stripped out. If I push the repository to my computer
    using GitHub Desktop the 0x0Ds are in the file.
    I am going to look into a proper fix for this issue and then
    upload a new Python script. I will let you know when the new code is up.
    MikeM781
    1 year ago on Step 22
    Thanks for such a quick and detailed reply! I inserted your except indexerror: code and sure enough: "error in options.ini:military=t" . I tried experimenting with the ini file by adding a line space, moving the order (I put temperature=t in line 1). It still gives me the military line error. The good news is it no longer throws the string index out of range error, and the program works! I just changed the code to reflect c=4 for my longer chain of boards, and it's currently scrolling the time and hopefully it's parsing some data. Now I just have to get those temp sensors....and insert my roman clock code. Thanks again! Mike.
    BigjBehrMikeM781
    Reply 1 year ago
    Mike,
    I am glad that it is working for you. I had a thought this
    morning, you may be having the problem because of the editor that you used to
    edit the options.ini file.
    Options.ini is a plain text (ASCII) file. It assumes that
    each line of the file is terminated with a carriage return(0x0D) and a linefeed
    (0x0A). Most programming languages convert the CR/LF combo to what is referred
    to as a newline character (in ‘C’, ‘\n’ or linefeed only). When a text file is
    read the CR/lf is converted to newline and when written the newline character
    is expanded to CR/LF.
    Editors like MS Word or WordPad do not do a proper job of
    working with plain text files. This is due to them being paragraph oriented and
    not line oriented. They may display the text as lines, but the actual file does
    not have CR/LF as line terminators.
    The Python script reads in the options.ini file and parses
    it into an array of lines and then processes then line by line. When it parses
    out the value variable, it assumes that there is a newline character at the end
    of the line and removes the last character in the line. If your editor did not
    put a proper plain text end of line at the end of the ‘military=t’ line then
    the last character would be the ‘t’ and not a newline character. Therefore the ‘t’
    was removed instead of the newline, resulting in the problem you are having.
    If you have some way to view the options.ini file as hex
    characters you can verify this. I suggest that you try using a different
    editor. Maybe Notepad or Notepad++. I use a free text editor named PSPad.
    Google it and try it out. It has the ability to display the options.ini file in
    hex mode or in text mode. It also has many features that make it a great editor
    for programming. Or look into Visual Studio Code. It is also free and is a very
    nice editor for coders.
    I hope this helps.
    PS I have a newer version of the Python script for the
    scrolling sign. I was having some trouble with the Python library used with
    Open Weather Map so I deleted it and wrote my own parser. A side effect of this
    is that the scrolling sign can now do weather forecasts. I also made some
    improvements to the jokes and headlines. I dropped the stock ticker out because
    the Python libraries were not working properly and I no longer needed it. Are
    you interested in the updated code ?
    MikeM781BigjBehr
    Reply 1 year ago
    Originally I had not edited or even opened the .ini file. I merely downloaded it and installed it in the directory along with the other files from your program. You are correct that there is no CR in the file as downloaded. It comes in as one long line, although when I viewed it (in nano), it formats, so I didn't catch this problem. It's clear when I load it in notepad, and also I see in this PSPad program the CR ascii codes are missing.
    Yes, I would be eager to see any additional code or changes you would be willing to share. I've been tinkering with this project for a few months. I started in C++, until I realized python was easier (at least, it has been for me). I also had some trouble early on running your code, as I had updated my Pi to Python 3.something, and when I tried to run at that level, I had module errors due to changes in coding nomenclature. When I run it at the default (version 2.7 I believe), it worked just fine. I believe there is a way to automate changes from 2 to 3, but I don't see the need. You probably flagged the python level requirement somewhere and I missed it. Like any good engineer, I rarely read the instructions...
    I'm still trying to wrap my head around parser functions and the different way the code is executed and displayed on the matrix. Displaying my roman clock was straightforward, I just made an array with a sleep timer and a cron job to start at 6am each day, with the variables synced to this time. Then another cron job in the evening to shut it down. Displayed as a text string. Then I made the mistake of using examples of new feeds with images converted to .PPM files, for headlines. I got this to work as well, but it seems I had less control over the scroll position, and I was unable to figure out a way to blend the two displays into one. Thankfully you posted your code with a more sophisticated, and elegant solution.
    Regards
    Mike.
    MikeM781
    Question 1 year ago
    Greetings. First of all, this is an excellent set of build instructions. Well done. For my particular build, I'm using an Adafruit hat and a matrix that is 32x128. When completed, I'm installing it over top of an ugly cold air return in the middle of my livingroom wall (with a gap for airflow of course). My goal is to have the time displayed in the top half, stationary, in hours:minutes, using roman numerals (because..why not?), along with current weather conditions. The bottom half will be a news scroll. Before discovering your build, I had completed the clock and news scroll functions separately, but my approach isn't allowing me to integrate and display the data simultaneously. Clearly your code has accomplished this feat, so I had hoped to first get it running, and then to make small changes in information collected and displayed, so my roman clock would show. I also need to spend time on the weather sensor portion, which I had not planned to do until I saw your build. Right now I'm stuck at the same point as "Xavier"...same error codes when I try to run. I saw your reply to him regarding the .ini file. I've downloaded this file multiple times, and placed it in the same directory without modifications. Same result (error codes) each time. I did confirm an 'f' is in the military time field as written. Do you have any other suggestions to get past this roadblock? Thanks in advance. Mike.
    1 answer
    BigjBehrMikeM781
    Answer 1 year ago
    I have attempted to reproduce the error you are seeing. I
    changed my options.ini file to have ‘military=t’. This ran without a problem. I
    then changed it to ‘military=’. This caused the exact error that you are
    having. Please check your options.ini file and make sure that you have at least
    one character after the ‘=’.
    The problem is that the variable ‘value’ is ending up as an
    empty string. You can add the line; ‘print len(value)’ after the line ‘value =
    s[1][:len(s[1]) – 1’. If you see that value has a length of zero then your
    issue is that options.ini does not have any characters after the equals sign in
    one of the true/false lines.
    You could change truefalse(str) to add a test for an empty
    string.
    def truefalse(str):
    if len(s) > 0:
    s = str[0].lower()
    else:
    s = ‘t’ # or ‘f’ for default to false
    return ‘t’ == s
    This
    does not fix the root cause of the problem you are having, but will effectively
    hide it. You will be able to run without crashing, but will always get the
    default value that you set.
    A
    better fix would be to trap the exception you are having and print the line
    that caused it. After the lines ‘except IOError:’, print “Falure reading
    options file”’ add;
    wxcept
    IndexError:
    print ‘Error in options.ini: ‘ + line
    Let
    me know if this helps.
    Xavier5
    Question 1 year ago on Step 22
    Hello, I followed the tutorial but with a rpi 3 and a hat adafruit. when I run with sudo python RGB-32x64.py I get that : NTP: Thu Feb 1 13:21:56 2018
    File "RGB-32x64 .py", line 1451, in
    setup()
    File "RGB-32x64 .py", line 1400, in setup
    readOptions('options.ini')
    File "RGB-32x64 .py", line 318, in readOptions
    military = truefalse(value)
    File "RGB-32x64 .py", line 279, in truefalse
    s = str[0].lower()
    IndexError: string index out of range
    can you help me ?
    xavier
    1 answer
    MikeM781Xavier5
    Answer 1 year ago
    I have exactly the same result and question as Xavier. Any advice appreciated.
