Realistic Flickering Flame Effect With Arduino and LED's
117,550
149
38
About: Hi, my name is Mike and I am from London, England. I really like to make things and in particular like to do creative things with Arduinos and electronics. Other hobbies include astrophotography and sailing....
In this project we will use 3 LED's and an Arduino to create a realistic fire effect that could be used in a diorama, model railway or a fake fireplace in your home or put one inside a frosted glass jar or tube and no-one would know it wasn't a real candle inside.
This is a really simple project suited to beginners.
Supplies:
Step 1: Step 1 - Wire Up the LED's
Wire up 3 LED's. Use 2 x Diffused Yellow and 1 x Diffused RED. You can increase the number of LED's if you wanted a larger or brighter display. Consider the use of transistors if your amperage will go over that which can be supplied by the Arduino.
Use resistors that suit your particular type of LED.
Step 2: Enter the Code
Enter this code:
// LED Fire Effect
int ledPin1 = 10;
int ledPin2 = 9;
int ledPin3 = 11;
void setup()
pinMode(ledPin1, OUTPUT);
pinMode(ledPin2, OUTPUT);
pinMode(ledPin3, OUTPUT);
void loop() {
analogWrite(ledPin1, random(120)+135);
analogWrite(ledPin2, random(120)+135);
analogWrite(ledPin3, random(120)+135);
delay(random(100));
Step 3: Upload and Run
Upload the code to the Arduino and run it. You will now have a pretty realistic flame/fire effect from the LED's. Bounce the light off a white card or a mirror to achieve the full effect.
Step 4: Video of the Effect
Video of the effect. The colours and the effect don't show up very well in the video. In real life it is a very effective flame effect. Give it a try.
    • Party Challenge
      Party Challenge
    • IoT Challenge
      IoT Challenge
    • Arduino Contest 2019
    38 Discussions
    rastita
    5 years ago on Introduction
    Hi! thanks you very much... i was coding something very complex and you gave us a very simple but efective candle efect ;)
    Instead of a full Arduino, i used an ATTiny85, and added a swich...
    Thanks a lot!
    LightsActionrastita
    Reply 3 years ago
    Do you have a circuit diagram by any chance?
    metalhead8711rastita
    Reply 3 years ago on Introduction
    hi rastita. this is a very awesome project you created. im interested how you wired it. it. code uses two leds but i see four. lol unless the others are just there. i see you connected leds with resistors on pins 5 and 6. your battery case looks like it takes two 1.5V batteries. AA or AAA? truly and awesome project.
    rastitan71
    Reply 4 years ago on Introduction
    Yeah! for shure.... but it´s almost the same than the original :)
    But only using 2 leds, instead of 3...
    // LED Fire Effect
    int ledPin1 = 5;
    int ledPin2 = 6;
    //int ledPin3 = 11;
    void setup()
    //pinMode(ledPin3, OUTPUT);
    void loop() {
    analogWrite(ledPin1, random(80)+35);
    //analogWrite(ledPin3, random(120)+135);
    delay(random(100));
    n71rastita
    Actually there could be 3 random flickers + 2 random fading using PWM on pins 0 and 1 with bursts to simulate little flame with occasional crackers. :-)
    Thanks for the great Instructable! Saved me a bunch of time writing the code myself!
    AKIREEV
    1 year ago
    A simple, yet convincing flame effect!
    Used it with two 8 mm LEDs (red and orange, but may switch red with something else, not sure yet) and AtTiny85.
    I have used two bright LEDs with clear cases, these were the brightest, but had to sand them with sandpaper (fine grit) to make lighting more even.
    Thank you very much!
    payams2
    1 year ago
    thanks a lot, i done it for myself and join to its realistic fun's. i want just modify it a bit for adding some random wind effects
    DylanS63
    2 years ago
    Can I make this exact circuit but with LED strips that run 12v?
    I want to make a flicker box that can simulate fire for my short films, the only problem with normal ones you buy in stores, they are really really expensive :(
    I appreciatie any answer.
    Dylan
    sergiolrmartins
    3 years ago
    Thanks for the simple but efective code.
    I included the randomSeed(392113) command in the Setup function
    and change the analogWrite commando to analogWrite(ledPin1, random(0,255));
    just to make it more effective and cleaner.
    and
    GuyH13
    3 years ago
    Thanks, I borrowed your approach for a project I'm doing with my son's Minecraft torch from Thinkgeek... enhanced it as a part of my main loop so that it also incorporated a random timer controlling the flicker. Not the most elegant code but it ended up looking very cool!
    Just posting an excerpt of the code, but as you might guess the elapsedTimeSinceOn is millis() now - millis() when the torch was turned on (button press):
    if ((torchLEDState == TORCH_FLICKER) && (elapsedTimeSinceOn % lastFlickerDelay == 0)) {
    // let's make the torch flicker
    if (DEBUG) { Serial.println("8 - running flicker routine"); }
    int brightness = random(10);
    int duration = random(10);
    switch (brightness) {
    case 0:
    case 1:
    case 2:
    case 3:
    case 4:
    case 5:
    analogWrite(torchLED_pin, random(120) + 50);
    break;
    case 6:
    case 7:
    analogWrite(torchLED_pin, random(120) + 85);
    break;
    case 8:
    case 9:
    analogWrite(torchLED_pin, random(120) + 135);
    break;
    switch (duration) {
    case 0:
    case 1:
    case 2:
    case 3:
    case 4:
    lastFlickerDelay = 100;
    break;
    case 5:
    case 6:
    lastFlickerDelay = 200;
    break;
    case 7:
    case 8:
    lastFlickerDelay = 500;
    break;
    case 9:
    lastFlickerDelay = 50;
    break;
    Heyup
    3 years ago
    not tried this yet, too busy at moment, but the effect looks really good. well done and thanks for sharing
    John :)
    a_wrek
    3 years ago
    Hello, when i try to upload the code to the arduino i get this error message.
    Collect2.EXE: error: Id returned 5 exit statusError compiling.
