Realistic Octopus Cake
6,673
90
58
Hey guys! So today I decided I wanted to make an octopus cake that looks as real as possible. I thought it would be a fun and challenging task that would be perfect for this competition. Hope you all enjoy!
The cool thing about this cake is that it's very customizable, you can pick any type of octopus to model it after and you can also very easily make it bigger or smaller. Let's get started!
Supplies:
Step 1: Supplies
Six 8" round cakes, any flavor (about 3 batches of cake/cake mix)
6 cups buttercream
4 lbs fondant (I used satin ice, but any brand will work, or even homemade)
A small amount of Gumpaste (optional, I only used it for the tips of the tenticles but that could also be done with fondant)
Fondant tools
Turntable
Powdered sugar/cornstarch
Oil/shortening
Fondant smoother
Fondant roller
Gloves (optional)
Serrated knife
Paring knife
Pastry wheel/fondant cutter
Offset spatulas
Airbrush and compressor (optional, you can always just hand paint it as well)
Airbrush colors if using
Food colors that match your chosen octopus ( I went with reds browns and yellows)
Vodka (for mixing paints)
Food writers (if you don't like painting fine details these are a great alternative)
Paint brushes (regular paint brushes are fine but just make sure you designate them for food only)
Paint pallet
Piping bags
Edible glue
Rice Krispy treats (store bought or homemade both work, I used a combination of the two)
18" cake board
Brown sugar for sand
Step 2: Prepare the Cake and Buttercream
For this cake I used Neapolitan but any flavor can be used. I always spray and flour my pans to ensure they come out perfectly every time.
I just used a standard homemade all butter buttercream to crumb coat the cake. Any recipe will work or you could also use store bought.
For the fondant I used satin ice because of time and because I usually make marshmallow fondant which is by nature much softer and wouldn't work as well for this complex of a design. You could definitely use any other brand or homemade fondant if you would prefer.
Step 3: Fill, Frost, and Carve
So to start you're going to want to put a little buttercream down on the board so your cake will stay in place. Put one cake down where you want the head of the octopus to be and cut off the top rounded part of the cake. Put a thin layer of buttercream and repeat with the next cake. You do not need to level the top cake because that will be carved anyways.
Next your going to need to cut the other three cakes into a moon shape. I just used my 8" pan to do this but cutting it to be about the length I wanted my front two tentacle bases to be. You will have a good amount left over but save that for later.
Once you have that done you are ready to start carving. I started by carving the center 8" to be more round, I then cut a v out of the moon cake and carved them down to the shape I wanted. Always start slow carving small pieces at a time until you get your desired shape.
After that I took the leftover cake scraps and put them in a bowl with some frosting to make a cake pop batter. I used that to make the eye structure and some of the tentacle. This is really helpful if you want rolled tentacle and to give you a base to build onto with the rice krispy treats.
The last step is to crumb coat the cake with a thin layer of buttercream making sure to cover everything.
Step 4: Tentacles
To make the tentacles I used a combination of homemade rice krispies and store bought. I found that the store bought worked best for the ends of the tentacles where as homemade provided a little more structure.
I just kept rolling out different sizes and lengths of rice krispy treats to make the tentacles, attaching them as I went until I was happy. To make them stick up I balanced them on other tentacles to give them more of a realistic feel.
I then covered all the tentacles in buttercream.
Step 5: Cover the Cake
To cover the cake I rolled out my fondant to a 19" circle about an eighth of an inch thick and carefully draped it over the octopus. I then took my paring knife and cut around the tentacles and smoothed the fondant around them and on the face.
After that i rolled out some leftover fondant to cover any parts I missed with the first covering. Using small pieces I filled in all the gaps and smoothed it with a little water to make the seams disappear.
Don't worry if the fondant isn't perfect. All of the imperfections will most likely be covered once you paint it and add all of the details.
Step 6: Paint the Cake
To give it the veiny type look I just used a fine paint brush with light brown food color that I thinned with vodka and started making random patterns. I also outlined where I wanted the front of the tentacles with the suckers to be so I could paint those separately. You could also do this with a food writer instead.
Next comes the airbrushing, or painting if you don't have an airbrush. As you can see I did several coats to get the color I wanted starting light and going darker to give it more depth.
Then I did the tentacles. I hand painted them because I wanted a cleaner line than I would get with the airbrush but you could definitely do it that way too. I went with I pale dull pink to start making it a little darker because I knew I was going to go over it. I then airbrushed the whole octopus with a yellowish brown to make it all blend together.
To make the eyes I dyed some fondant yellow and made two balls and stuck them in with edible glue. I also airbrushed those with the yellow brown that I made for the whole octopus trying to really highlight the edges.
Step 7: Final Details
To make the suckers I used a #12 tip and cut out a lot of tiny circles. I then attached them all with edible glue and used a ball tool to indent them.
For the eyes I used black food color thinned with vodka and painted a crescent type shape to make the pupils.
The last thing I did was adding brown sugar around the octopus to look like sand, and there you have it!
Step 8: Enjoy!
I hope you found this turorial helpful!
Deceptive Desserts Contest
First Prize in the
    • Classroom Science Contest
    • Woodworking Contest
      Woodworking Contest
    58 Discussions
    WUVIE
    2 years ago
    You are spectacular! Congratulations!
    Neepha
    3 years ago
    What a gorgeous labor of love. It must have been very hard to cut into!
    Quadrifoglio
    3 years ago
    Congratulations on your First Prize!
    The Juliart
    3 years ago
    Congratulations !! You did a great job! Jewels
    The Juliart
    3 years ago
    Meglymoo87
    3 years ago
    CONGRATS on winning first place! :)
    Rapturee
    3 years ago
    Incredibly Edibl-icious! Very well Done,,,
    Meglymoo87
    3 years ago
    You are a finalist on your very first 'ible! That's very impressive! CONGRATS and good luck! :)
    Quadrifoglio
    3 years ago
    "In the Deceptive Desserts contest we want you to bake something that makes people question whether they should take a bite or take cover!"
    Run away!!!!!!!!! Run away!!!!!!!!! Run away!!!!!!!!! (But click Vote first)
    That Redhead
    3 years ago
    So beautiful! A piece of art! Best of luck!
    Amaries
    3 years ago
    This cake is too beautifull to eat! You have my vote.
