Rechargeable (homemade) Power Bank (super Easy)
288,548
72
53
Step 1: Intro
This is my first tutorial so go easy on me xD. Ok I made this charger because tired of being with out music (ipod) on school.because my school does not have power plugs.
Step 2: Partss!
Ok we need: 3x ultrafire 3.7v batteries or 3x 4 volts batteries 1xcar cell phone charger 1x toggle switch Pair of cables 1x rca female plug (you will see its use later) Tools: Hot glue Scissors Black tape Pliers
Step 3: Building This
Now comes the good part.connect the 3 batteries in series if they are 3.7v they shoud give 11.1v out.now take apart the car charger.connect positive cable of batterie to center stem of the toggle switch.then connect the negative cable of the battery to the car charger and the rca female plug.connect the car charger positive cable to the right stem of the toggle switch and the positive cable of the rca female plug to the left stem of the toggle switch.
Step 4: Done
My name is Caleb Escobar Ríos from Puerto Rico.I hope this is of help to you.this is my first Instructable tell me how I did and comment if you dont understend or need help.thanks
    • Arduino Contest 2019
    • Tape Contest
      Tape Contest
    • Trash to Treasure
      Trash to Treasure
    53 Discussions
    olanrewajum1rgupta53
    Reply 4 months ago
    It is easier to charge all you need to do is to buy any charger of your choice and you will need to buy the same charging port of the charger so you will need to connect the charging port directly to the batteries (no I.c needed)
    ThuY7
    Question 1 year ago on Step 4
    Could i get video file of this project ?
    AdeyemoO
    2 years ago
    It need 11.1v and above to charge properly
    Calebescobar11
    2 years ago
    search me on facebook as Caleb Escobar and shows me your project
    Calebescobar11
    2 years ago
    JunJunA2 You can use this as your project but be careful
    JunJunA2
    2 years ago
    Can I use your idea of making a power bank for my Science Investigatory Project? And of course if you agree I'd give you credit for part of my work since it's just the idea of building it is the only part that I'd like to use. Is that fine with you? :)
    pbrammann
    2 years ago
    Brilliant! A proper regulator, modified calculations....
    A simple if not rudementary guide for energy cells. Good work!
    Calebescobar11
    2 years ago
    Bros and sis don't make this it could be dangerous because most 18560 batteries are not protected. I made this in a time that I was 12 and didn't understand much about the dangers of li ions. Hope nobody got hurt. Go search for another tutorial, this is no good.
    PushpithaD1
    2 years ago
    And how to find 5 V voltage regulator at home
    PushpithaD1
    2 years ago
    How to make power bank for 4000 milliampere battery
    AmolS15
    2 years ago
    I think something's will go wrong, as you are connecting cells in series so its voltage will increase current will be same i.e. capacity is 2200mA but rate of charge flow will be triple. I think you have to connect cells in parallel to improve capacity to 6600 mA and voltage will be acceptable to charge mobiles..
    KaushalVAmolS15
    Reply 2 years ago
    its not in series bro look at first
    tanefTrueB2
    Reply 2 years ago
    The capacity of an individual li-on of this type and size is more or less 2200mAh. In a series of three, the total comes out to around 6600mAh.
    TonyC166tanef
    Reply 2 years ago
    Series ups the voltage, not capacity.
    Parallel ups the capacity, not voltage.
    ArijitD6
    3 years ago
    Instead of rca for charging can't we add a microusb port ?
