Recycle Ceramics Into Awesome Mosaic Stepping Stones
33,035
48
I am a Middle School Art Teacher, and sometimes after a round of firing ceramics, there are pieces left over. Over the years, the pile gets bigger and bigger. One day, I decided to make a Mosaic! This is exciting, one, because I get to give the kids hammers and ask them to smash up pottery, and two, because I have never made a Mosaic! Let's do this!
Step 1: What You Will Need
Gather together ceramic tiles or pottery, a workspace where you can smash, a hammer, safety goggles, t-shirt, drawing board,  sharpie, bowls, tile mortar or mosaic adhesive,  dust mask, adhesive spreader, mosaic grout,  stepping stone,  mosaic grout sealer, sponge, knife,  waste can, and a sponge.
Step 2: Break Apart Your Pottery
Put on your safety goggles, place a piece of pottery into a t-shirt, and smash it with a hammer. Open up the t-shirt, after you feel it break, and decide how small you want the pieces. Monitor the size as you continue to hammer the pottery. When the pieces are small enough, place them into a bowl, and put the smashed, dusty bits into the waste can.
Step 3: Prepare the Board
Trace the stepping stone onto the board, using the sharpie.
Step 4: Sort the Pieces of Pottery
Sort the pieces of pottery. I put them glaze-side-up, in groups by color, and size. Be careful when you handle them, as they may be a little sharp.
Step 5: Design the Mosaic
Use the bits and pieces to come up with a satisfying design. This step will vary with each artist. Some folks will go from the outside in, and others will have to draw a bunch first, and still others will just jump in and do a fabulous piece.
It is sort of like building a puzzle. You will find that the edges may go together, or not. I don't recommend leaving too little or too much space in your mosaic, as there should be a place for the grout.
Step 6: The Tile Mortar
I got this 25 lb. bag of tile "thin-set" mortar at a hardware store, and it only cost around $10. It mixes up like concrete, just add water. The instructions are also featured on the bag. I wore a dust mask while handling it, just saying.
Step 7: Apply the Mortar
Using the mortar tool, spread a medium-thick layer of tile mortar over the surface of the stepping stone, and use the rake edge to make a pattern in the mortar.
Step 8: Transfer Your Mosaic
Transfer the pieces of mosaic from the board to your stepping stone.
Step 9: Cleaning Up the Mosaic
Using a piece of tile, gently press the mosaic to make sure the bits are seated in the adhesive. Wipe up the extra adhesive, and place somewhere to dry for 24 hours.
Step 10: Assemble Everything to Grout
Assemble a sponge, a paint mixer, a knife, and the board with your mosaic tiles on it.You will need to mix up some grout, let it sit for 10 minutes, and then stir it again, before you begin.
Step 11: Grouting
Make sure and get grout down in between the pieces of ceramic tile. I used an old knife.
Step 12: Spread Grout
Using a paint stirrer, I spread the grout over the whole mosaic, scraping off the excess.
Step 13: Scrape Off the Grout
Scrape off the grout, using an old knife, spatula, or what -have-you...
Step 14: Clean Off the Grout
Using first a sponge, then paper towels, clean off the grout, and polish the exposed tiles so they are shiny!
When cleaning up, try and scrape as much grout into the trash before you wash up, as it will clog drains.
Step 15: Seal and Enjoy
Let the grout cure up for 72 hours, and then seal your tile with grout sealer and enjoy!
    • Party Challenge
      Party Challenge
    • Woodworking Contest
      Woodworking Contest
    3 Discussions
    MelodyP7
    3 years ago
    Love this! Will give it a try.
    LizaM
    4 years ago on Step 15
    I love your idea, and thanks for sharing! However, I think it would take it over-the-top for a finished look to make the edges of the grout even with the edges of the stepping stone. Maybe a cardboard form could help? Have a great day!
    backflowteck
    6 years ago on Introduction
    Veary nice. Love how it came out. I would like to give this a try myself...
