Recycled Scanner Hack!
125,596
230
156
About: Tinkerer, hackster and prankster. Hit me up on Facebook: https://www.facebook.com/kipkayvideos/ Thanks for checking out my Instructables!
I found my old serial port, flatbed scanner and decided to do something useful with it. I have seen other scanner Instructables, like this one from jpitz31 and this one from trebuchet03 but nothing like what I had in mind. This is easy to make and versatile. Watch the Test Results in the video.
Supplies:
Step 1: What You Need...
1. A flatbed scanner. I used an HP 3200C. You can find them all day long at garage sales...
2. 1/2" clear vinyl tubing
3. 2 Project Enclosures (Radio Shack Model: 270-1801)
4. Switch
Step 2: Disassemble the Scanner
This scanner only had 2 screws and the top came right off. Save it if you want the glass out of it. Remove the carriage assembly off the steel rod. I saved the rod for another day.
Step 3: Remove the Lamp and the Inverter
Remove the Inverter by unplugging the (2) connectors and carefully remove the lamp. Save the AC Adapter, you may need this one.
Step 4: Prep the Housings...
I drilled 2 - 1/2" holes in the ends of the boxes, one small hole in one box for the ac adapter wires and a hole for the switch. I mounted the Inverter in the main box with hot glue. I also used a 6volt - 500Ma adapter instead of the original. (Some bench testing may be necessary to determine the exact voltage required to fully light, yet not blow the fluorescent lamp.) Run the wires from the ac adapter into the smaller hole in the box. Install the switch. Solder the negative ac adapter wire to one end of the switch and solder the other end of the switch to the black wire coming from the inverter. Solder the red wire from the Inverter to the positive side of the ac adapter. You should add some heat tubing and tie a not in the wires from the ac adapter to keep it from pull stress.
Step 5: Build the Lamp Housing...
Cut the 1/2" tubing to the size of the lamp. After threading the lamp connector into the box, plug it in to the Inverter. Slide the tubing over the lamp and about an inch into each of the two boxes and secure with hot glue...Now plug it in and test it out! I used velcro to secure it wherever I want to use it. Hope you enjoyed this Instructable.
    • Classroom Science Contest
    • Woodworking Contest
      Woodworking Contest
    • Fandom Contest
      Fandom Contest
    156 Discussions
    pdub77
    10 years ago on Introduction
    i just took apart my scanner and i found this. can anyone tell me what it is? tell me the truth. it's a flux capacitor, isn't it?!?! ; ) (the black and silver thing on the circuit board, not the whole circuit.)
    njmalhqpdub77
    Reply 2 years ago
    A flummoxed capacitor.
    bleachworthypdub77
    Don't believe the lies they tell you about it being a scanner, it IS a flux capacitor, now hot-glue it to the back window of a Dalorian and GO GO GO!!!!
    awang8bleachworthy
    I think you're being sarcastic but if you're not, well it ISN'T a flux capacitator. It's the actual scanning thingy. The lamp is just to light up the page so the thingy can "see" the page.
    pdub77awang8
    i don't want to be rude, awang8, but yes, we were employing a it of playful jocularity. everyone knows that flux capacitors are found in printers!!
    awang8mman1506
    Why would a flux capacitor be found in printers? It needs like... 1.21 Gigawatts of power. Well, what scans the page if that's a flux capacitor?
    mman1506awang8
    the bar adsorbs power from the earth and stores it powering the axon tube to adsorb the electrons of the ink,its simple really
    tomtortoisepdub77
    glue it in your car and if a cop pulls you over for speeding say you had to reach 88 MPH
    Argon27pdub77
     It's actually a surface mount flux capacitor for your more discrete time travel needs. :D
    Plasmanapdub77
    I have one of those in my scanner too, I think It is the actual scanner...
