Remaking a Leg
3,570
97
7
About: I like to get creative and use materials for their not intended purpose ! Working as a refinishing technician / painter dealing with high end cars ! Lots of fun spend 90% of my time outside and or tinkering ...
This Instructable shows how to remake a leg from a table or a vintage couch with silicon mold and fiberglass resin, possibilities are endless
The couch was bought with a broken leg with intentions to remake the leg to match the other front leg
This was all done at home in the driveway
Supplies:
Step 1: The Mold
I used a silicone 2 part 1 to 1 water based mix and mixed it up in a glass vase
put it on the leg in the glass vase propped with whatever i could find to meet my needs
let it set 12 min and then slipped off the mold
Cut the back into the silicon from the top of the leg and a bit of the bottom with a razor to carefully remove the mold from the leg then placed it bad into the vase to keep form
Step 2: Casting the Leg
I used bond brand Fiberglas resin from Canadian Tire. Its a 2 part mix with a catalyst hardener
Poured it into the glass vase with the silicon mold into it and let set
Then once hardend I removed the cast from the mold
and we have a replica of another leg
Step 3: Drilling
I drilled 3 inches into the resin cast leg and instead a threaded rod cut to the length I needed
Poured in some more resin in the negative space to make it stay in place
Did the same with the wood leg, drilled it out and used resin to hold it in place until the next step
Step 4: Filling in the Void
After all the resin has set up I used bondo brand short strand fiberglass mixed up and put in the space left from the wood leg to the cast
Used a plastic bag wrapped around the leg and the cast to make it more cylindrical as it sets up to make it easier to sand
Step 5: Carving and Sanding
I used a dremel with a diamond cutting disc to outline and make lines more deep
Then sanded with a 40 grit to shape it better
Having the cast on the bottom and the original broken leg on top made it easier to sand the lines in between
Step 6: Final Sanding and Paint
Finished my sanding and then painted it with a gold spray paint close to the original colour
Good to go
    • Arduino Contest 2019
    • Classroom Science Contest
    7 Discussions
    gollumses
    2 years ago
    TAKE YOUR SHOES OFF WHEN YOU'RE SITTING ON FURNITURE! HAHAHA Very nice instructable. Never thought of casting a broken leg. I usually go the long route, and remake the leg out of wood. Next time I break my leg, I may just amputate and recast the stump! ;-)
    deluges
    2 years ago
    Wonderful!
    Riotjam
    2 years ago
    awesome dude, love it!
    tytower
    2 years ago
    Well that's one way and successful it seems .Why not make the leg longer and the join exact and avoid all the shaping? I suppose you cast from the back left leg so this will only work if all legs are the same which is not often the case that I have seen.
    tytowertytower
    Reply 2 years ago
    Oh I see now you cast the front left leg and turned it round so that's why you had to make it look right with carving .Looks good
    JmsDwh
    2 years ago
    Nice job, very cool way to save an antique from the trash.
    newtonza
    2 years ago
    Good job dude. Looks pretty good.
