Remote Control Toyota (Mechanics)
81,408
287
56
Building a machine that will be capable of operating gas/brake and wheel was not an easy obstacle to overcome, using some borrowed equipment, I managed to build a working frame that can be easily dismantled from my wife's car. (mine is manual gear so I though that it will be TOO complicated...)
In purpose to control the pneumatics I needed to supply 24V to the valves, (see electronics page) that will press gas whenever I want the gas to turn ON and will take the piston back when I leave the stick, I did the same with the brake ( ON/OFF FWD - BCK)
Controlling the wheel was using an electric window motor that I dismantled from an old car, connected to some strings (from my daughter's game), 12V Supply, and a wood plate that is connected to the wheel with zip ties.
The Aluminum profiles (ITEM) are good for adjustments, which is required to for in car adjustments. the whole machine can be removed from the car within 5 minutes.
Step 1: Remote Control Toyota (Mechanics)
Controlling the wheel was using an electric window motor that I dismantled from an old car, connected to some strings (from my daughter's game, 12V Supply, and a wood plate that is connected to the wheel with zip ties.
The Aluminum profiles (FESTO) are good for adjustments, which is required to for in car adjustments. the whole machine can be removed from the car within 5 minutes.
Step 2: Remote Control Toyota (Electronics)
The electronic circuit (illustrated) needed to take the signals from the receiver and process it in the Arduino and the send the commands out to the valves/motor.
the problems were that the valves operate with 24V DC So I used a MOSFET transistor and circuit I found here (bildr.org).
and the other problem was that I needed to operate the 12V DC motor BOTH WAYS - so I  found out that only transistors will not do the job - so I added a two ways relays (each transistor activates relay that operate the motor in different directions).
SO I needed 5[V], 12[V], 24[V] ... and air pressure ... what a hobby project !
Step 3: Remote Control Toyota (Control)
the control scheme for the project is that the signals from the remote control will received in the car, transferred into the Arduino micro controller and then processed into instructions (pulses) to the valves/Wheel. I wrote an Arduino sketch based on what I found here  (at Sparkfun) and made an addition to print the values to the screen for QA purposes.
I had really hard time trying to "clean" the garbage that my RC controller generated (I use an 20 years old transmitter and receiver, that was gives as a gift for my friend for his 10th birthday, it is so old that when you screw all 4 bolts of the casing, the transmitter stops working, if you remove 2 of them - it works again...)
I used an Arduino Duemilanova, (borrowed after I blown mine...)
The Arduino sketch is below:
// RC Toyota
// Controlling real family car by a remote control
// Aug 2013
// for more info see Http://www.KeerBot.com
int ch1 = 5; // Here's where we'll keep our channel values
int ch2 = 6;
int out1 = 8;
int out2 = 9;
int out3 = 10;
int out4 = 11;
int out5 = 2;
int out6 = 3;
boolean gas_operated = false;
boolean brake_operated =false;
int ledpin=13;
unsigned long time;
void setup() {
  pinMode(ch1, INPUT); // Input from Reciever channel 1
  pinMode(ch2, INPUT); // Input from Reciever channel 2
  pinMode(out1, OUTPUT);
  pinMode(out2, OUTPUT);
  pinMode(out3, OUTPUT);
  pinMode(out4, OUTPUT);
  pinMode(out5, OUTPUT);
  pinMode(out6, OUTPUT);
  pinMode(ledpin, OUTPUT);
  Serial.begin(9600); // Pour a bowl of Serials - (ha ha ha...)
void loop() {
time = millis();
  ch1 = pulseIn(5, HIGH, 25000); // Read the pulse width of
  ch2 = pulseIn(6, HIGH, 25000); // each channel
      Serial.print(time);
      Serial.print(";");
      Serial.print(ch1);
      Serial.print(";");
      Serial.print(ch2);
      Serial.print(";");
      if (ch1>1700 && ch1<2200) {
       Serial.print("2500"); // Reciever channel 1 UP signal
       digitalWrite(out1, HIGH); // Gas ON - gas piston FWD
       gas_operated=true;
      else if (ch1>1000 && ch1<1400) {
         Serial.print("1000"); // Reciever channel 1 DOWN signal
         digitalWrite(out2, HIGH); // Brake ON - Brake piston FWD
         brake_operated = true;
      else {
       Serial.print("1500"); // Receiver channel 1 IDLE signal
       digitalWrite(out1, LOW); // No Gas Off
       digitalWrite(out2, LOW); // No Brake Off
   //    if (brake_operated == true) {
        digitalWrite(ledpin, HIGH); // No Brake ON - brake piston BCK
        digitalWrite(out5, HIGH); // No Brake ON - brake piston BCK
     //   delay(1500);
      //  brake_operated=false;
        //digitalWrite(ledpin, LOW); // No Brake off
        //digitalWrite(out5, LOW); // No Brake off
        //if (gas_operated==true) {
         digitalWrite(ledpin, HIGH); // No Gas ON - gas piston BCK
         digitalWrite(out6, HIGH); // No Gas ON - gas piston BCK
        // delay(1500);
        // gas_operated=false;
         //digitalWrite(ledpin, LOW); // No Gas off
         //digitalWrite(out6, LOW); // No Gas off
      Serial.print(";");
      if (ch2>1700 && ch2<2200) {
       Serial.println("2500"); // Reciever channel 2 RIGHT signal
       digitalWrite(out3, HIGH);
      else if (ch2>1000 && ch2<1400) {
         Serial.println("1000"); // Reciever channel 2 LEFT signal
         digitalWrite(out4, HIGH);
      else {
         Serial.println("1500"); // Reciever channel 2 IDLE signal
         digitalWrite(out3, LOW);
         digitalWrite(out4, LOW);
     //delay(50); // I put this here just to make the terminal window happier
Step 4: Remote Control Toyota (Assembly)
So, now I had all components and I needed to assemble them in our family car, I Took them all out to and began the work:
  • Machine (mechanics, pneumatics)
  • Air compressor  (for pneumatics air supply) - located in the baggage...
  • 5V,12V,24V power supply,
For more of my stuff see my site:  http://www.KeerBot.com
The assembly was quite quick, the adjustments for the pistons and the wheel mechanism assembly were the hard part, but after some tries it wet well, as can be seen:
Step 5: Remote Control Toyota (Thanks)
Yoni M. - for the Arduino and support
Sharon E. - for initial electronics
Cobe M. - For tech Support.
Kobi C. - For support with remote hack
Roni Z. - Relays tip.
Yaglush - for everything !
Step 6: RC Car (old Times Laugh...)
Just for the laugh and memory - the first RC Car I made - few years ago...
Arduino Contest
Finalist in the
Arduino Contest
Remote Control Contest
Second Prize in the
    • Epilog X Contest
      Epilog X Contest
    • Comfort Food Challenge
    • Cardboard Challenge
      Cardboard Challenge
    56 Discussions
    welderhero
    5 years ago on Introduction
    So make it cheap, and or self contained, and or reusable and or nearly indestructible. Fairly quick to install and sell it to the department of defense to clear land mines (ied's) ahead of troops and convoys. Way cheaper that a bazillion dollar armored vehicle with out the loss of life.
    Mark620welderhero
    Reply 5 years ago on Introduction
    Cheap + ease seem to be missing from military spending.
    A tank can be taken out with 2 small trucks with remotes and a rpg...
    of course at that rate of attrition you would need many cargo ships full of them :p
    welderheroMark620
    I would guess there more or less junk cars in that part of the world that run well enough for the job. Where ever the cars come from The cost benefit ratio would be high on the benefit side.
    t800
    Very nice project, well done: voted for you ;-)
    bremus
    Cool project, but its probably the most dangerous inscrutable I've seen. Please don't take the car out of park with the wheels on the ground. :)
    darman12
    Doesn't this fall under the "don't try this at home" warning on Mythbusters? :P I won't tell Adam or Jamie.
    OruKun
    3 years ago on Introduction
    How much does parts cost total rough estimate? and Can I buy yours for 2.5x the cost you made it?
    rlitzner
    4 years ago on Step 3
    Hey man I was wondering if you can email me the instructions on how to convert a real car to a rc car
    wavegmrlitzner
    Reply 4 years ago on Step 3
    Man - It's all in the instructable....
    I can help if you ask specific questions
    rlarios
    I expected to see a video clip showing somebody driving the car remotely like Dr. Emmet Brown did in Back to the Future.
    berrymartin
    Great Job, your project is really amazing. The work is looking so cool. After seen this i got an idea. I've always wanted to do this with my Car but i think its extremely dangerous.
    imercury
    5 years ago on Step 2
    Great project - Having humans drive has never been a good thing - Looking forward to the bicycle version ?
    tiger12506
    Cool.
    A couple suggestions:
    http://en.wikipedia.org/wiki/H_bridge
    This will allow you to operate your 12V DC motor BOTH WAYS with just transistors.
    Being slightly more selective of your parts will simplify things a bit.
    I'm not familiar with the Arduino family, but I suspect that you can get one to run on 12V, or if not, then easily with a voltage regulator.
    If you cannot find valves that operate on 12VDC, then keep in mind that 12V + 12V = 24V, the idea being that with the above arduino change, you can get all three supplies from your car battery (fuse box in driver's compartment) just by having another 12V battery in series with your 12V rail to create the 24V rail.
    But, of course, it would be much easier to pick and choose 12V valves. Then your (awesome!) contraption can be supplied just by probing into the fuse box.
    wavegmtiger12506
    Thanks a lot for the info - I agree completely that using the car battery and another one will do the job, The general idea was to hack the car as minimal as possible (since it's my family car) and the valves and equipment I had was borrowed, so I couldn't be too picky.
    If this will ever turn to anything more serious - I will surely take your advise and implement.
    Have a great weekend! :)
