Remove Printing From Promotional Items
598
About: Building design/consulting in SE Minnesota. Resource based problem solver... in other words, I always take a minute to peek in construction dumpsters :) ---the way some have to workout everyday... i have to...
Receiving promotional items is always a treat. Companies provide these items so that you will have them in mind and so that others will see you using them.
If you find you don't want the branding know that in 5min you can simply remove the printing (often pretty cheaply done) by using a few simple tools.
Step 1: Materials
In addition to the corporate swag you plan to modify you'll need two simple ingredients...
  • Razor Blades - I use single blade razors because one purchase lasts a lifetime ---a 100 blade pack works out to <.10/blade
  • Scouring Pads - here I'm using the new 96Hex pads ---they are pretty amazing. The side with the dots is 5x strength the heavy duty scrubber on the back.
Seamster - instructables in house-pro provides a few recommendations in the comments:
  • Goo Gone - powerful stuff. seamster notes that goo gone should definitely be used outside. ---they also make a household version
  • Goof Off - a more mild product for removing sticky materials
Step 2: Scrapping Method
Scrapping is pretty simple. It's much easier to get the angle right (and more forgiving) than sharpening a knife.
  • Angle. Really any angle less than 45 degrees works fine. I'm at about 30 degrees.
  • Edges. Yes, it's useful to start at the edges.
Step 3: Steady
A steady clean motion is important. Here I'm simply rotating the bottle as I scrape. It can be tempting to wipe the blade across the entire surface but I find it easier to slowly work across and maintain a clean surface.
Step 4: Finishing + Enjoy
A scouring pad works well to finish the surface. For a stainless steel water bottle you really can't damage the material. You'll want to use caution if you are using a scouring pad on plastic or a softer surface.
Enjoy. You now have a nice clean bottle ---easy to add a favorite decal/sticker.
Thanks for reading - Jeff
---I like having a good collection of water bottles. Here's an earlier instructable on my favorite glass bottle.
Here are a few of my unfeatured instructables that I think are useful around the house:
    • IoT Challenge
      IoT Challenge
    • Fandom Contest
      Fandom Contest
    • Classroom Science Contest
    3 Discussions
    seamster
    6 months ago
    Ha! I'm glad I'm not the only one that does this. I tend to remove graphics from loads of stuff. When scraping isn't a good option, I'll turn to Goo Gone or other adhesive removers for dissolving certain types of paint. And a heat gun can help with stickers and vinyl. All in the name of enjoying objects ad-free! : )
    jprussackseamster
    Reply 6 months ago
    Thanks! I have some Goo Gone but haven't tried it on paint. Will give it a shot. Have you tried these intense scouring pads? Impressive. I regularly reach for the yellow/green ones but these are a serious upgrade.
    seamsterjprussack
    Reply 6 months ago
    I hadn't seen those scouring pads before. Will have to check them out. I said "goo gone" but when I checked the bottle I have it's actually "Goof Off". Pretty powerful stuff, gotta use it outside!
