Repair Laptop Hinge Problem With JB Weld
10,276
34
About: Hi my name is David, I like to make things out of Wood, also like to take things apart and fixed them.
In this Instructable, I will show you how to repair hinges on a Laptop, where the brass inserts has broken from the bottom case.
Tools needed:
Screwdriver
JB Weld
Clamp
Plastic wedge or Guitar pick
stirring stick ( I used a piece of old credit card)
Stirring pad ( I used sticky note pad)
Pen ( to keep notes on screw locations)
Step 1: Removing Screws
First take Laptop battery out and set aside. Then start to remove the screws, try to remember there location or keep good notes. I am going to show how to take this Acer Laptop apart, yours might be different.
Step 2: Removed the Keyboard and Wires Under It
Now removed the keyboard and screws, wires underneath it. Be gentle with the wires.
Step 3: Hinge Good, But Bottom Case Bad
Note in these pictures that the Hinge is in good shape, but the brass inserts has pulled out of the bottom case
Step 4: JB Weld Time
Mix equal parts of JB Weld on sticky note and stir until it turns grey in color.
Step 5: Apply JB Weld
Apply mixed JB Weld in holes and insert the brass inserts with the screws still in, into the holes. Now use your clamp to hold the parts together. Let dry overnight
Step 6: Now Reassemble Laptop
After letting JB Weld set overnight, now you can reassemble Laptop
Step 7: Hinge Problem Fixed
Note in the Pictures I have put before and after photos of Hinge problem.
I hope this instructable can help somebody
Note this might not fix all Laptops, but I have been using JB Weld for years and it has done wonders.
    • Weaving Challenge
      Weaving Challenge
    • Organization Contest
    • Pie Contest
      Pie Contest
    3 Discussions
    kinneil
    3 years ago
    I put plasticmate in mine, looks messy but works great that stuff , my laptop was that cracked I could push enough in so I didn't have to UN screw laptop, I don't know where to get plasticmate as it was given to me , it goes soft in boiling water then u mold it to any shape goes rock hard plastic .
    davethewoodworkerkinneil
    Reply 3 years ago
    I have never used plasticmate, but you can get JB Weld just about anywhere, Walmart, Lowes, Home Depot and most Car parts stores. I have been using this stuff for 30 years, and keep finding uses for it.
    kinneildavethewoodworker
    Reply 3 years ago
    https://www.plastimake.com/ i found it now this stuff is awesome stuff , it so great they should do a competition with it.
