Repurposed Copper Tubing Bracelet
10,409
185
10
Create a beautiful textured copper bracelet from a copper pipe.
Step 1: Gather Your Supplies
**Before you begin, please note that working with flames and tools can be dangerous. Please take the necessary precautions :)
For this project, you will need:
-Heat Resistant Work Gloves
-Protective Eyewear
-Dust Mask
-6 inches of Copper Pipe (Feel free to use more or less depending on if you want a cuff or a bangle)
-Pipe Cutter
-Annealing Pan (or some other non-flammable surface)
-Butane Torch
- Basin with Water
- Pliers
- Rubber Mallet
- Bracelet Mandrel
- Anvil
- Dapping Punches
- Hammer
-Paper Towels
-Steel Wool
-Sand Paper
Step 2: Measure and Cut Copper Tube
Measure the length of tubing that you would like to work with and cut using a pipe cutter.
-Tighten your blade around the copper tube. Make sure that the wheels below the blade are cradling the pipe. Twist two complete times around the tube, and tighten the cutter. Continue this until you have cut through your tubing.
Step 3: Anneal
Put on the appropriate safety wear (goggles, gloves) and place your tube into the annealing pan, holding one side with a pliers for easy turning. Anneal the copper with your torch, making sure to turn the pipe so the entire surface gets heated.
Step 4: Quench
After your tube has been annealed, place it into the basin full of cold water. This process is called "quenching" and cools the metal down after being heated.
-After you quench your copper, dry off it off with a paper towel.
Step 5: Lightly Flatten Tube
- LIGHTLY hammer the ends of the copper tube so it will lay flat on the anvil. Once this is done, LIGHTLY flatten the rest of the copper. Leave about a quarter inch of depth to prepare for texture.
Step 6: Add Texture Using Dapping Punches
-Add texture to the copper by hammering your dapping punches.
-There is no specific pattern, get creative and have fun!
*TIP* Rotate the dapping punches while you are hammering to create a deep texture.
Step 7: Repeat Steps 3, 4, and 6 Until You Are Happy With the Texture
-Continue, Annealing, Quenching and Dapping until you are happy with the texture of your bracelet.
Step 8: Anneal Until Red Hot & Quench
-Anneal your copper until it is red hot. This is very important as you will be forming your bracelet in the next step. The hotter your copper gets, the easier it will be to form around your mandrel.
-Quench your copper one last time
Step 9: Form Your Bracelet
-Wearing the appropriate gear, (eye protection, gloves) form your copper tube around the mandrel by using a rubber mallet. Start at one end of the tube and work your way to the next.
*NOTE* -If this step is really difficult, your copper needs to be annealed more. Go back to step 8 :)
Step 10: Remove Scale and Sand
-Once your bracelet has been formed (HOORAY!) use steel wool *wear a dust mask, your lungs will thank you* to remove any scale that has developed on your bracelet.
-If there are any sharp edges on your tube, sand them off with sandpaper
Step 11: Viola! You Are Finished!
Bracelet Challenge
Runner Up in the
Bracelet Challenge
  • Warm and Fuzzy Contest
  • Organization Contest
  • Sweet Treats Challenge
10 Discussions
SirCooksalot
3 years ago
I'm going to make this tomorrow, I've got copper left over from some candle holders and a lamp I made for gifts... Copper pipe is awesome crafting material, $10 for 10' and it looks beautiful. Now I'll share some knowledge with you in return- it's VOILA, not viola. A viola is an instrument. I see it misspelled everywhere. Lately I'm seeing 'genera' instead of genre too, don't know where that's coming from, but anyhoo...thanks for the cool ible!
My family lives in a very old house, so there are a lot copper pipes that we have to take out one at a time. Bracelets and jewelry are a great idea! Great job! Love it!
