Roasty, Toasty Slipper Rice Inserts to Keep Your Tootsies Warm
2,048
13
These inserts, made from scrap material and raw rice or buckwheat groats/whole buckwheat seeds, are so comforting and roasty, toasty to keep your tootsies warm in your slippers.
I have made two different varieties  - one for the sole of your slipper, to wear while sitting (it is a little uncomfortable to walk on the inserts and raw rice) and the other to lay on the top of your toes (which you can wear while walking around).
Additionally - similar inserts could be made to insert into your mittens.   Just had another idea - the inserts could be slipped inside your boots too!
Supplies:
Step 1: Materials Needed
Scrap material - flannel or felted wool work especially well
Scissors
Thread
Sewing machine
Funnel
Raw rice or whole buckwheat seeds or buckwheat groats (do not us buckwheat hulls)
Step 2: Creating Your Inserts
Trace your foot (sole) on a piece of paper.  Cut two soles from the pattern - flipping the pattern over so you are creating a right and left sole.
Similarly, trace the top of your foot on a piece of paper.  Cut two tops from the pattern - again flipping the pattern over so you are creating a right and left top.
Step 3: Cutting and Sewing Inserts
For double thickness, turn fabric inside out with right sides together.  Pin left sole and right sole pattern - as well as the left and right top patterns,  to the wrong side of the fabric and cut.
Pin and straight stitch 1/4 " around, leaving a 1" opening.  It would be a good idea to stitch again just to be sure the seams are secure and rice grains aren't able to escape in the future.
Turn all inserts right side out.
Step 4: Filling Your Inserts
Fill your inserts with a comfortable amount of rice or whole buckwheat seeds/buckwheat groats.
Stitch opening closed - again, consider stitching twice.
Step 5: Ahhhhh -- Enjoying Your Inserts
All done!
Now insert your inserts into the microwave.  As each microwave is different, and the amount of rice or buckwheat used is different, heat on high for 1 minute and continue heat testing until just right for you.  Use caution!
The rice or buckwheat should retain the heat for up to 40 minutes.
Now insert your inserts into your slippers - ahhhhhhh!
    • Classroom Science Contest
    • Arduino Contest 2019
    • Gardening Contest
      Gardening Contest
    2 Discussions
