Robo Blanket: Crochet a Blanket Using a Cross Stitch Pattern.
16,840
26
8
About: I am a domestic engineer, aka. a stay at home Mom. A former science geek, scenic carpenter, and quilter.
I like crocheting. I've been doing it since I was little. But just recently I've discovered how to crochet pictures. Now I'll show you how.
You will need:
Yarn in different colors.
A Cross Stitch pattern
A crochet hook. (I used size H)
You can get cross stitch patterns of anything, and you can even make your own.
I took a picture of the robot from here, and put it into Gimp. I used the mosaic filter to make it into a pattern.
Step 1: Following the Pattern
Here's my pattern. It's pretty simple. It's black and white with no symbols. I used my sticker in the corner as a color guide. I colored in each row with a colored pencil as I finished them. You could use a different color for each work session. I used different colors because my kids kept hiding my pencils.
You start the pattern on the bottom right hand corner. First row you go right to left, second row left to right, 3rd row right to left, etc. You should leave your tail on your piece until you are finished, that way you always know that that is the bottom right hand corner.
Note: I printed my pattern too small. When you print it make it big, so that you don't go crosseyed counting squares.
Step 2: Crochet Away
I did the whole blanket using the single crochet stitch. You can do any kind of stitch you want.
To change colors: (Look at the pictures)
Put you hook through the stitch. Instead of pulling the current color through, put the current color on top of your stitches, and grab a new color. Put the tail of the new color with the old color. Pull the new color through your stitch, and continue finishing the stitch.
In the video I show you how to change colors.
Step 3: Enjoy!
So now that you know how to change colors, you can make your blanket. Just follow the pattern. Each box represents one stitch. Change colors when you need to, and just keep going one row at a time. When I finished I crocheted a single row in black all the way around to make the border.
    • Classroom Science Contest
    • Woodworking Contest
      Woodworking Contest
    8 Discussions
    nimoz
    8 years ago on Introduction
    that's a great idea! I would never think to turn a picture into a crochet pattern. Crochet is just about the only yarn craft I can do, so this opens up a world of possibilities (and insanity!).
    thanks.
    it's hard to find a cros stitch pattern with not too many colors though.
    also, i have found ti works better if you change yarn colors with the last loop of the previous stitch.
    Momma_Bear
    10 years ago on Step 1
    I never learned how to crochet but I am INSPIRED by your video. Well done! Your calm simple explanation and great camera work make it seem so easy!
    mynameisjonas
    10 years ago on Introduction
    what a great idea! needless to say, five stars. and btw it looks like your kid's are catching the ible fever!
    canida
    Robot looks awesome! And thanks for the info on color changing - I always got confused about how to carry the other color along. Your video + still pictures were perfect. In fact, it might be worth breaking that out into a separate Instructable so people can find it when searching for "how to change colors in crochet". You've already got the material...
