Arduino Controlled Robot Lawnmower - Ultrasonic and RGB Sensors ( Arduino 控制機器割草機 - 超聲波和RGB傳感器)- Howard Taylor Robot Lawnmower - YouTube
5,728
66
22
About: I'm a maker and engineer... I make mad stuff... check out Dubious Engineering on YouTube
Tired of cutting the grass... so, developed a robot lawnmower!
Infinite detail on YouTube...
The whole playlist
https://www.youtube.com/playlist?list=PLeEfIf9twcK...
Introduction to the Channle
對割草厭倦了......所以開發了一台機器割草機!
詳細說明請見YouTube......
Part 30 of the lawnmower project - cutting grass!
Step 1: All the Parts... 所有零件
Here's a description of all the parts
  • Arduino Mega Arduino Mega 2560
  • Motors
  • Ultrasound sensors
  • RGB sensor
  • OLED display
  • Lithium ion batteries
  • Wheels
  • Wood
以下是所有部件的說明
  • 控制板
  • 馬達
  • 超聲波傳感器
  • RGB傳感器
  • 有機發光二極體顯示器
  • 鋰離子電池
  • 輪子
  • 木板
Step 2: Attach Wheels to Motors 將車輪連接到馬達
Attaching the wheels to the motors was tough going... 將車輪安裝到馬達上是費勁的...
Step 3: Making the Chassis 製作底盤
Here is the chassis made from wood and the first test of it moving around
這是由木板製成的底盤,並作第一次移動測試
Step 4: Fitting the Electronics 安裝電子產品
Planning and fitting the computer and sensors was tough going...
設計、安裝計算機和傳感器是棘手的...
Step 5: Modifications... 修改.......
Had to change the wheels out
必需更換輪子
Step 6: When It Finally Cut Grass! 當它終於可以割草!
Testing was great fun... and when it finally cut grass! Whoop whoop!
非常有趣的測試...且當它終於可以割草! 哇!
Step 7: PART 28 - BUILD UPDATE - NEW RAZOR BLADE CUTTER! 更新-換新刀片
    • Weaving Challenge
      Weaving Challenge
    • Tape Contest
      Tape Contest
    • Remix Contest
      Remix Contest
    22 Discussions
    diy_bloke
    1 year ago
    Great, now all it needs is an Ardupilot to make it follow a pattern :-)
    eqwipman
    1 year ago
    what are the specs on the motors and where did you get them? Also what is cutting the grass, I didn't see any cutter?
    eqwipman
    1 year ago
    I just saw the video of the hacksaw blade, sorry I missed it before. btw Good Job.
    DreamDabbler
    1 year ago
    Great! I've thought about making a robot lawnmower, wonderful to see someone actually did it. I'd probably use less computing power and use physical barriers or buried wire to keep it on the lawn, but I admire this more advanced approach. I wonder if a different cutting method or blade would work. Also, this seems to be crying out for a solar panel and circuitry to assist the batteries and recharge them when it's not running.
    freddie43
    1 year ago
    Nice one!
    I wondered if you could suggest some part numbers / specs / eBay links for the motors and wheels? This looks like my entry project in to Robotics!
    Thanks
    Kris82
    1 year ago
    I need a Weed mower as all of my grass is dying :( Great job Though.
    HowardLJTaylorKris82
    Reply 1 year ago
    Haha! - You need weed and feed from your local hardware store! - Then some grass seed to cover the bald patches! :-)
    Phantomjerret
    1 year ago
    Very neat idea, I thought about doing this awhile ago for a science fair project! It would be more helpful if you put more details in the steps instead of just links.
    p.s. the links didn't work for me
    HowardLJTaylorallangee
    Reply 1 year ago
    It uses an RGB colour sensor... please feel free to subscribe to my youtube channel for more info!
    Swansong
    1 year ago
    I wish I had something like this! I get a sinus infection every time I mow the lawn. >.<;
