Robotic Drink Mixer
94,308
427
76
It's time to head back to college and that means lots of fun, parties, and EPIC TAILGATING!  (Go Razorbacks!)
BUILD A ROBOTIC DRINK MIXER!
This is a portable system that can mix over 5,000 drinks on demand from a laptop computer.  Build it and they will come!
Here is what the Robotic Drink Mixer is capable of:
Some of you may have seen my other instructable last year, BaR2D2, the mobile bar.  This is the long awaited drink mixer upgrade!  If you want to see the robot this can attach to, go here:
https://www.instructables.com/id/Build-A-Mobile-Bar-BaR2D2/
This system was built to replace the manual liquor carousel.  It has been an incredible upgrade and we have had a blast with it!
You can friend BaR2D2 on facebook:   bartwo dtwo
Supplies:
Step 1: Time to Order Parts!
The Robotic Drink Mixer uses a compressed air system to force liquids out of the ingredient bottles (air is forced into the bottles and a syphon tube allows the liquid to come out.  An electronic valve (solenoid valve) controls how much liquid comes out and when.
For my setup, I am using six ingredient bottles and six solenoid valves.  The bottles are about a liter each and have a standard neck thread like a plastic coke bottle (you can actually use plastic coke bottles).
The valves are 12 volt plunger-style solenoid valves (normally closed).  These were obtained at McMasterCarr for about $25 each.  I used part number #7877K313.  The air tanks are from ebay and were originally used in semi truck air horns.  You can use any air supply tank as long as it has enough volume to fully displace all the contents in your ingredient bottles.
I charge these tanks to about 75 psi and then using a regulator, reduce the pressure to 5 psi at the ingredient bottles. (any more than this is a waste...you get good flow at 5 psi and reduce air leaks).  Use a Schrader valve in your tank and then you can fill it using a regular air compressor or foot pump.  Use clear Tygon PVC tubing to connect everything on the low pressure side.  On the high pressure side, use pvc air line.
The regulator was purchased through SurplusCenter on the net for about $20.  I also got the gauges from there.  Again, you are basically just trying to get to about 5 psi at the bottles.
To make connections easier, I used acetal push-to-connect fittings. (McMaster Carr part #51055K14)  These thread into the valves and the Tygon tubing plugs into the fitting.  Size your tubing to match each connection.
To distribute the six air lines into the ingredient bottles, we used an aluminum manifold (McMasterCarr part #5469K151)  Thread your push to connect fittings into this as well.  The tops of the bottles that have the two air nipples were purchased through lazydrinker.com.
Step 2: Make Templates for Structure
The parts for the drink mixer are made from 1/8" aluminum plate.  Mine were cutout using the waterjet process.  This machine uses a high pressure water stream with an abrasive compound to cut the parts.  I used the services offered by Bigbluesaw.com to cut my parts.  You simply upload a file to their site and they mail you parts.
Other materials (plastics, wood) can also be used.  If you don't want to go to the expense of waterjetting, you can use a jig saw or band saw to make your parts.
My templates were made to accomodate 6 plastic bottles that are about a liter each.  Your bottles may be different, so make your parts according to how many bottles/size of them.
You can see my finished template for the base, bottle support, and bottle holders.  Also there is the valve support and the compressed air tank supports.
Step 3: Assembly Time!
The parts are assembled with 4 threaded rods and nuts (I used 5/16").  These allow you to slide the parts on and adjust them all for proper clearances on everything.
I made a plate that holds the six valves.  Drill and screw the valves to the plate.
Cut the threaded rods to 4 equal lengths (length depending on your bottles and height of desired machine).  Also,  cut six threaded pieces to use to hold the upper supports together.
For the base of the portable system, I used an oval shaped plaque I purchased from Michael's craft store.  This was sprayed with black texture paint.  The base provides a stable base.
I attached the manifold, regulator, and valves to the base plate.  Your install may be different.
Plumb up all your airlines.
Step 4: Electrical Connections
Now that we have built the structure and mechanical bits, it's time to wire it up.  The brain of the robotic bartender is the Lazydrinker circuitboard. (lazydrinker.com).  This board connects to a laptop via a serial cable.  The software was also obtained from lazydrinker.
Create a wiring harness for the valves.  They use a common ground.  The positive is run to a serial cable pin.  The pin designations are given via lazydrinker.
I also added 12 volt led lighting to accent the bot and provide light when my robot is running around in the dark at a party.
As for powering your Robotic Drink Mixer, you need a 12 volt power supply.  If you look around your shop or computer parts bin, you may find one from an old modem, computer, etc.  Just needs to have at least 1 amp (I would go with 4 if you can find one).
For BaR2D2's mobile usage, a custom Bluetooth receiver board was built (credit Jay Lueck).  This attaches to the lazydrinker board and allows wireless usage from my Dell PDA.
Step 5: Time to Party!
Now, fill up your ingredient bottles and pressurize the system.  You plug in your ingredients into the software and it generates a list of what you can make with them.  You are now in business!
A couple of usage notes - my system is designed for table top (or in my case also for mobile robot usage).  My items aren't refrigerated, but filled with cold ingredients, it will easily last all night.  If you want to use it again the next day, I would recommend putting the bottles in a cooler or refrigerator overnight.
Make sure to flush the system after each use or the valves will get clogged.  I recommend using bottle sanitizer used in home beer making.  Wash the bottles and flush the system and thoroughly dry everything so it will be good to go for your next party!
Have fun!....and of course the disclaimer:  drink responsibly, don't drink and drive, don't drink unless you are 21...blah, blah, blah.  Also, this is a pressurized system and MUST be treated with respect!  DO NOT build this system without a safety overpressure valve on your main tank!!! and do not fill them to more than the manufacturer's rated pressure.  Doing so creates an explosive situation!
You can see the full BaR2D2 robot in this video taken from a late night party in Atlanta a couple weekends back at Dragon*con.  It's always a blast to take it out!
Step 6:
Finalist in the
Back to School Contest
    • Woodworking Contest
      Woodworking Contest
    • IoT Challenge
      IoT Challenge
    76 Discussions
    mcsper
    1 year ago
    can it mix or stir drinks? that should be next if it can't.
    zodono
    8 years ago on Introduction
    Is there any particular reason you didnt put the solenoid valved on the pressure side of the bottle? this would have prevented the valves from needing cleaning as no liquids would flow through them, it would also mean the beverage bottles would not be pressurized unless dispensing, which would allow u to refill them without depressurising the system... or am i missing something?
    jamiepzodono
    Good question - but yes, it is important to put the valve at the point the liquid exits the machine... The reason is, if you don't have a valve there, then as soon as you tell it to stop pouring, it still has about 1/4" ounce + in the tube that will slowly just pee everywhere...also, it can create a syphon and actually make a slow dribble.
    The valve at the end makes for perfect metering of drinks. This is the way all the softdrink machines are at fast food places as well.
    Ross SonnyCjamiep
    Reply 1 year ago
    can you further more explain how is the connection and function of the air compressor?
    boosey
    4 years ago on Introduction
    I cannot locate the bottles or especially the double nipple fitting. Is there anyone who has found them lately? Lazydrinker does not sell parts apparently.
    przygoda
    6 years ago on Introduction
    What ingredients do you put in your bottles? I've almost finished building my robotic mixer and I have no idea what to put into the bottles to make as many drinks as possible
    DayBowBow
    Did you buddy ever make the control board that replaces the lazy drinker?
    tde1806
    I have just contacted Lazydrinks.com
    and he wrote back.
    that his not selling the lazydrinks board at this moment, so is there anyone who as another idea to make the robotic bartender.
    Tomas
    Denmark
    gigsgtoxtde1806
    I've built a "semi-system" using the LED-Wiz.
    I built basically this same thing but with an actual compressor and tank, knocked down to 6psi for 4 fluids. It takes a little more work on your part as there is no software, you have to create your own, but the basic premise is the same. I ended up bailing on the final construction because I couldnt get cola's to distribute properly.
    mvangordengigsgtox
    Reply 6 years ago on Introduction
    if you still have all those parts and software programmed for the LED WIZ I would be interested in taking those off your hands...
    jamieptde1806
    Short answer, yes - my friend will be rolling out a new circuit board and software design soon that will be available. Stay tuned... probably first quarter of new year.
    jamie
    jamieptde1806
    On another note - check out my latest project that is in the Humana contest. If you think it's a winner, vote and rank it highly. Thanks!
    https://www.instructables.com/id/Occupational-Therapy-DexterityCognitive-Aid/
    jsp5048
    7 years ago on Introduction
    Hey Jamie,
    My classmate and I have decided to build an automated drink maker for our senior project (we're electromechanical engineering majors). I actually had no idea prior to this that such inventions were already made, but this is pretty awesome stuff. Just had a few questions I was wondering if you could answer:
    -Roughly how much did this cost you in all? (we have a budget)
    -How long did this project take you?
    jamiepjsp5048
    All in, there is probably $1,500 in parts and machining. If you were just building a table top non robot version, it would be much cheaper.
    jamie
    mali28
    Do you build more for sale? and would you help a group of students to do one?
    Thank you
    Tekker
    Awsome write-up! I just couldn't find the types of dispensing bottles that you used, could you list the site/store where you found them? Thanks!
    jamiepTekker
    They are made by Silgan Plastics and are screw top 32 ounce bottles. Can't remember which website I got them from.
    jamie
