Rock Solid Pun
3,447
64
8
About: I love to make anything and everything and I will give anything a go.
This is a perfect quick and easy build for any pun lover. This paradoxical stone is a very satisfying make.
Step 1: Smash It!
I had a large piece of slate. I wanted the ornament to be small. To make it to a manageable size I carefully smashed the slate against a the base to a bird bath. You can break the slate on anything that is hard.
Step 2: Mark It
I wanted to write the text on 3 lines. You should divide the stone into 3 by measuring it and then marking it with a pencil.
Step 3: Writing
I found it easiest to write the text one line at a time in pencil. You should mark the stone very heavily so you can see where to engrave.
Step 4: Engraving
I used my dremel to engrave the stone. You should use dremel with diamond bur engraving dremel accessory. Then simply follow the text which you have written for yourself in pencil. Another handy tip is to use some water to wipe down the stone after engraved one line. This allows you to see where needs a deeper ingrave and also gets rid of any dust.
Step 5: Finished
Now you can put it on display and all your friends will see how punny you are! Hope you enjoyed this instructable!
    • Pie Contest
      Pie Contest
    • Organization Contest
    • Paper Contest
      Paper Contest
    8 Discussions
    seamster
    2 years ago
    I love stuff like this. High five from me! :)
    IndubitablySamjkimball
    Reply 2 years ago
    it didn't take long long at all probably about 20-25 minuets
