Rope Bridge Bookshelf
195,921
1,382
81
About: I like to make things for the internets. I also sell a pretty cool calendar at supamoto.co. You'll like it.
The rope bridge bookshelf lets books have a relaxed home when they're not being read. It can be rough being opened and left in all sorts of locations during the reading process and the books have earned a nice break.
Step 1: Supplies
Materials
  1. Statlig board from Ikea
  2. Ekby Bjarnum shelf holder pair from Ikea
  3. paracord
  4. steel washers
Tools
  1. Miter saw
  2. Drill press
  3. Lighter
Step 2: Chop
Using the miter saw, cut the wood into several pieces. With the board I had I got:
  • 2x 2.5" pieces
  • 11x 2" pieces
Step 3: Drill
Using the drill press I drilled out pairs of holes in all of the pieces. I clamped a couple of pieces of wood to the drill press to make sure that all of the holes would be aligned correctly.
Step 4: Start the Paracord
Cut off two lengths of paracord and singe the ends with your lighter to prevent fraying. Tie a knot in one end and start feeding it through the pieces of wood.
To make the knots extra secure, use the lighter to melt the knot into a gooey mass.
Step 5: Washers
String the cord through all of the pieces of wood, using the steel washers as spacers. I used three for each gap.
Step 6: Add the Bracket
Use the included hardware that came with the Ekby Bjarnum to attach the bracket to the wood.
Step 7: Hang It Up!
Find a nice spot for your bookshelf and install it! I used a few drywall anchors to keep everything nice and secure.
Now find some books that deserve a nice rest and put them down on it.
    • Gardening Contest
      Gardening Contest
    • Trash to Treasure
      Trash to Treasure
    • Tape Contest
      Tape Contest
    81 Discussions
    duskworm
    1 year ago
    This is so simple but so awesome.
    (ouch, that sounded pretty cringy...)
    ScottB231chronocide67
    Reply 2 years ago
    Mine would love it too... if only they could fit... >(^-^);<
    ScottB231
    2 years ago
    Very imaginative design! Very well executed!
    I was thinking of a series of shelves arranged as wall art, and the rope bridge would compliment the design wonderfullly!
    Hey, I just discovered your shelf and really like it. Very cool!
    Have you built a shelf double the length? If so, how well did it work? What did you learn to make it work.
    One obvious thing I can think that will be a challenge is the weight. Drywall anchors probably are not strong enough to hold, but maybe locating wall studs so that it can be screwed in security.
    dan3008
    4 years ago on Introduction
    Ah, Just when I was looking for an aesthetically pleasing shelf to put a few books and computer games on, I find this :D
    Thankyou :)
    Here is my Rope Bridge Shelf :)
    https://www.instructables.com/files/deriv/F2S/5LZQ/H7997RK6/F2S5LZQH7997RK6.THUMB.jpg
    I used 5mm steel wire for more strength.
    Thank you for this helpful project!
    clogden21
    8 years ago on Step 7
     i LOVE THIS it would make a cool cat bed if you put carpet on the top of it.
