Roubo Frame Saw
9,875
50
About: I have been working with wood since I could stumble into the shop with my dad. About a year ago I moved into a house with no space for a full shop so I decided to take up all hand tool wood working. That sta...
I made a frame saw a year ago. It worked fantastically, but one day I dropped it and busted out one of the mortises. Oh well it is just a good reason to remake this one even better. A frame saw is the traditional way of resawing lumber. This one is meant for one person but some of the larger ones are designed for two people to run.
Tools Needed:
#4 Hand plane setup for smoothing: http://amzn.to/2hc6LQZ
Scrub or foreplane: http://amzn.to/2hUHD0p
Squair: http://amzn.to/2ia9M3Z
Marking Gauge: http://amzn.to/2i0jvHx
Panel saw: http://amzn.to/2hjAura
Marking knife: http://amzn.to/2hPHf34
Chisel Set: http://amzn.to/2i26mzX
Block Plane: http://amzn.to/2ikkaqg
File set: http://amzn.to/2l0czdB
Long-nosed marker: http://amzn.to/2lExV1e
Dovetail Saw: http://www.highlandwoodworking.com/veritas-doveta...
V-Tool: http://amzn.to/2kf8OjO
Carving kit: http://amzn.to/2kf8Wjb
Supplies Needed:
Frame saw kit: http://www.blackburntools.com/new-tools/new-saws-...
White Oak: or whatever wood you want to use.
Boiled Linseed Oil: http://amzn.to/2hPEUVO
Past Wax: http://amzn.to/2inlN23
wood glue: http://amzn.to/2kEeTHc
Step 1: The Frame Saw Kit
I built this saw with a kit I bought from BlackBurn Tools and am in love with the kit. I purchased the 32" size kit as that is easy enough for one person to run by themselves. http://www.blackburntools.com/new-tools/new-saws-and-related/roubo-frame-saw-kit/index.html in this case, I am actually reusing the kit that I used in my last one.
Step 2: Laminate Lumber for Beams
You will need stock about 1 1/4" thick. Unfortunately, I did not have enough of it on hand to make this so I need to laminate two 3/4" thick pieces. I flattened one side of both pieces with a scrub plane and number 4. then enough glue is added and the two boards are clamped and set aside to dry. after the glue cures the stock can be flattened and smoothed on both sides.
Step 3: Trace the Pattern
In my case I used the old frame saw to trace out the pattern I wanted to follow, but you can download the pattern at Balckburn tools where the kit came from. With a paper pattern, I find it easiest to just glue it to the stock and cut out to the pattern.
Step 4: Shape the Beams
I start by making a series of relief cuts down to the marking line. if the grain is running well I will use a mallet to snap off the large chunks. A large chisel can make quick work of bringing it down to the line. In some cases a turning saw is useful, but most all of the work is done with a chisel and mallet for me.
Step 5: Shape the Handel
For the handle, I will use a chisel to do the majority of the shaping. Then I will come in with coarse rasps and then a coarse file and then a fine file and finish the surface with a very fine file.
Step 6: Insert Pressure Plate
On one end of the beam, there needs to be pressure plate inserted for the screw to push against. I set the plate on the beam where it should go and then trace it out with a marking knife. Next, the waste can be removed with a chisel down to the depth so the plate is flat with the surface of the beam.
Step 7: Shape the Two Stretchers
The two stretchers that separate the two end beams are about 1 1/4" square and made to match the length of the blade you chose. it is a simple prosses of ripping them down and mill them to dimension. I made them 1" longer than needed for a 1/2" tenon on either end of the beam.
Step 8: Cut the Tenon
I use a marking knife to mark out a half inch long tenon that is 1/3 the width of the stretcher. then use a back saw to cut them to shape.because these are so small I chose to use a dovetail saw.
Step 9: Cut Mortise
In either end of both beams, there needs to be a mortise cut to fit the tenon. I start by chopping either side with a chisel to sever the fibers, the come in with a smaller chisel to remove the waste. Kepp testing the fit and make sure the stretcher seats all the way down to the beam. Be very careful now to blow out either side of the mortise.
Step 10: Add Some Carving
A little bit of carving can make the whole difference in the world. I added a bit of carving to both beams. and total it added about 1 hour of work to the task but was so worth it in the end. For this, I just used a V-Tool to follow a line. With 15 minutes of practous, you can do this too. It is so much easier than it sounds.
Step 11: FINISH IT!!
For the Finish, I used Boiled linseed Oil and paste wax. It just feels great for a hand tool. then you can put it together and have some fun.
    • Epilog X Contest
      Epilog X Contest
    • Trash to Treasure
      Trash to Treasure
    • Pie Contest
      Pie Contest
    3 Discussions
    pfred2
    2 years ago
    I was encoding celtic knots earlier for my CNC machine. I didn't engrave one yet, but I plotted one. How'd you like to carve this? I think it would make my eyes go buggy.
