Rubik's Cube Solver
190,273
570
197
So here's a project I've been working on for a while...
This robot that can solve a Rubik's cube using Arduino.
I learned how to solve a Rubiks cube last year, and I was also into Arduino, so eventually I ended up with an idea to make my own Rubik's cube solver.
Like many people searching for "Rubik's Cube Solver" on Google, one of the first robots I found was the Tilted Twister design by Hans Andersson:
I looked around at some other Rubik's cube solvers, but I liked that design because of it's (relative) simplicity, so I built a similar version of it with popsicle sticks, an Arduino and 2 servos.
In the end, my robot takes about 20 minutes to enter the cube state and solve.
Supplies:
Step 1: Materials
Electronics:
- Arduino UNO R3
- 2 servos (I used Hitec HS-311's)
- wires
- USB cable
You can get all of these parts from any robotics store. I got them from canadarobotix.com
Hardware:
- popsicle sticks
- wooden skewers
- thin plywood
- wooden wheel (skewer must fit inside the hole)
- hot glue
- paper towel roll
Software:
- Arduino IDE - (Algorithms in C++)
- Python 2.7+ and Tkinter - (GUI)
- Pyserial
Step 2: Electronics
Wiring up the servos to the Arduino is pretty straightforward
1. Connect the yellow (signal) wires from the push and rotation servos to pin 6 and 9, respectively.
2. Connect the positive and negative wires to the 5v power source and ground. Sometimes the servos had jitters, so I think a few capacitors could have smoothed out the current.
Step 3: Mechanical Design
I looked at a few designs but settled on the Tilted Twister because it only required 2 servos to operate, which wasn't as complex mechanically as other robots such as the Cubestormer.
So here's how the mechanism basically works:
1. A platform holds and rotates the cube.
2. The arm pushes and holds the cube.
When I first tried to build the solver, I tried to follow building instructions here:
But I was pretty lazy and didn't follow the instructions, so I made a wooden replica with a few tweaks.
I haven't documented every step of the build process, but I think you can reproduce the tilted twister design with a few tweaks:
1. Slanted sticks to prevent the cube from snagging.
2. To build the arm joints,
- I drilled a hole into ends of the popsicle sticks.
- I cut out 2 cm of a wooden skewer.
- I inserted the skewer into the sticks
- Glued wooden wheels that act as washers on each end.
Honestly building the physical solver was a lot harder and complex than I expected, so if you have any questions on how I built the solver, just ask.
Step 4: Arduino Sketch - Cube Solving Algorithm
[Code: https://github.com/matt2uy/Cube-Solver]
So basically the code I wrote uses combinations of pushes, holds and platform rotations to apply algorithms to the cube.
There are 3 main parts of my code: the algortihm, GUI (enter cube state) and the serial communications
Let's start with the Arduino sketch. It basically uses algorithms to manipulate the cube colours:
1. There are 6 char arrays represent each face of the cube.
2. Using a basic layer by layer method of solving the Rubik's cube, I made a function, cube_decide(), that goes through each stage or the cube solving process.
3. Within each stage, such as cube_decide_cross() (solving the cross), the program would check for specific locations of colours in the cube, and if an algorithm was matched with the condition, cube notation like 'U' (Up) or entire algorithms, like fix_cross_instance_1() would be run.
4. The cube notation and algorithms control the servo functions, such as push_cube() or rotate_one().
Here's a basic overview of the code structure (layers of abstraction):
Cube Decide functions < Cube Algorithms < Cube Move functions < Servo functions < Move Function
One major breakthrough I had was that I actually simulated the cube's movements in the program. The program reassigns the values in the arrays to simulate and cube rotation. This way, the program can simulate the cube move before it physically executes it.
Step 5: Python GUI
I needed a better way of entering the cube state than directly typing them into the Arduino sketch, so I got the idea of creating a GUI from this robot:
Because I'm new to making Tkinter GUI's (Graphical user interface) and didn't want to make one from scratch, I found a tic tac toe GUI here: http://www.dzone.com/snippets/gui-tic-tac-toe-less...
Then I turned the 3x3 array of buttons into something resembling a cube and added a few buttons. I also added buttons that would change colour each time they were clicked. Finally I made 5 more windows that would pop up one after the other, and transfer the colours entered into a local array in the script.
However, I really slapped the code together in a mess, since I simply copy and pasted 6 separate windows, with almost identical functions. Any suggestions on how I could clean up the code are welcome!
Step 6: Connecting It All - Serial Communications
Once the algorithm in the Arduino sketch and the python GUI were ready, I needed something something that would use the cube state collected from the GUI and transfer it to the Arduino sketch. After the sketch receives the data, it can put the cube state through the algorithms and physically solve the cube.
To do that, I used a library called Pyserial, which helps my python script communicate with the Arduino over a serial interface.
Basically, this is how I coded the the serial communication:
1. After the cube colours were entered in the GUI in Send_Cube_State.py, I converted the data into a string
2. Used a 'handshake', which in this case the Arduino tells the computer it's ready, then the computer transfers the data to the robot.
3. The Arduino converts the string received into chars, which are assigned to arrays in the sketch.
4. Now that the cube colours have been successfully transferred from the computer to the Arduino, the cube colours can be put through the algorithms and solve the Rubiks cube.
Step 7: How to Use
If you're trying to build the robot yourself, or just trying out the code, here's a checklist to help you out:
1. Download and install these packages and applications
- Arduino IDE (http://arduino.cc/en/Main/Software)
- Python 2.7 (Tkinter is included) (https://www.python.org/downloads/)
- Pyserial (https://pypi.python.org/pypi/pyserial)
2. Download the source files here: https://github.com/matt2uy/Cube-Solver
3. Copy and paste Cube_Solver.cpp on to the Arduino IDE.
4. Plug the Arduino in and upload the sketch.
5. Right after uploading, take note of the serial port number at the bottom right corner. (See picture above)
6. In Send_Cube_State.py, change the address in line 18 to match the number on the IDE. (See picture above)
7. Open the command prompt (Windows) or terminal (Mac/Linux)
8. Go to the directory where you put the source files in:
- using the command 'cd', for example:
- cd 'path/to/Cube-Solver'
9. Run the .py script with: python send_cube_state.py
10. If you see a series of 'y's being print on the screen:
- wait about 5 seconds
- Exit using ctrl-c or command-c
- Repeat step 9 again.
- There should be a GUI that shows up.
11. Enter the Cube colours in the correct orientation:
Colour in Front | Colour on Top
1. Yellow | Blue
2. White | Green
3. Blue | White
4. Red | White
5. Green | White
6. Orange | White
12. Put the cube inside the solver in the orientation seen here: http://goo.gl/tSqSpp
13. Click 'Solve!'
14. If that didn't work:
- Copy and paste Cube_Solver_No_GUI.cpp on to the Arduino IDE
- In line 32-54, enter the cube colors in the same convention as in step 11.
- Do step 12
- Upload the sketch on to the Arduino.
8 People Made This Project!
  • Party Challenge
    Party Challenge
  • IoT Challenge
    IoT Challenge
  • Gardening Contest
    Gardening Contest
197 Discussions
AainA1
Question 5 weeks ago
rotate one two and three are not working properly
TahirI8
6 weeks ago on Step 3
sir!i am a bscs student and have slected this rebot as my DLD project pleas give me the complet details that how you build this structur pleas I am waiting for your reply
Mark12342
7 weeks ago on Step 7
Does anyone know how to change the angles for the push arm?
salmitastarsET2018
Reply 4 months ago
did you find out how long it takes to build/solve?
12345y
9 months ago
How can u enter the cube state without the python gui?
Gcools93Technovation
Reply 2 years ago
It all depends on the solve and the algorithm input into the computer. Sometimes it can take up to 120 moves. Other times it can take 5-10. And it also depends on the speed of the servo's turning. So it will vary quite a bit.
UjwalM
Question 9 months ago on Introduction
how much will be the components cost?
GhanshyamN1
Question 9 months ago on Step 5
Plz tell how did u prepared the 3×3 arrats for input
GhanshyamN1
Question 9 months ago on Step 3
Plz add a time lapse on how to build the physical structure plz
Bharath mano
Question 10 months ago on Step 7
Please tell me the full details on how to build the structure of
vrung2323
Question 11 months ago
when I try running the program send_cube_state.py, the error "no module named serial" comes up. any ideas on how to fix? i have pyserial 3.4 installed and idk what to do
JorgeS215
Question 1 year ago on Step 4
1.tengo una duda en uno de los giros el servo que sostiene el cubo queda un poco inclinado y al hacer el empuje el el otro servo no concuerda me gustaria si me puedes ayudar
RahulM123
1 year ago
Any Cheap servo I can replaced with your guided servo?
KshitijA9
Question 1 year ago on Step 1
Can i use sg90 servo to built this.... or any other cheaper than hs311
winnerciro
Question 1 year ago on Introduction
Hi i’m Ciro an italian boy and i want to Made the same robot. Do you have any drawings of the robot? For answering this is my email : ciro199920@gmail.com
juanBB
Question 1 year ago
Friends some of you have all the codes it is impossible to download, I am a university student and I am ECUADOR, you can help me with that, please if thanks. This is my email: elperfil1993@gmail.com
